Reply 80 of 98, by zuldan
- Member
4xtx wrote on 2022-05-02, 02:01:Here's 2 for the collection.
The ES1938MI is currently being used in an EPIA-ITX based project
On the E1938-202 PCI card, do you know what the jumpers do?
zuldan wrote on 2024-04-30, 08:24:4xtx wrote on 2022-05-02, 02:01:Here's 2 for the collection.
From recall it was to enable amplification for passive speakers
4xtx wrote on 2024-05-03, 10:53:zuldan wrote on 2024-04-30, 08:24:4xtx wrote on 2022-05-02, 02:01:Here's 2 for the collection.
That’s what I thought it was for but why do you need 2 jumpers for that. That’s a lot of combinations for something that’s on/off. Weird.
You need to do it twice because there's two channels. It's not a "logical on/of" but you route each channel through an amplifier or not. Feel free to do only one jumper - you'll see you'll have only one side amplified. Doing it with a single jumper would've required more components and added costs.
elszgensa wrote on 2024-05-03, 11:57:You need to do it twice because there's two channels. It's not a "logical on/of" but you route each channel through an amplifier or not. Feel free to do only one jumper - you'll see you'll have only one side amplified. Doing it with a single jumper would've required more components and added costs.
Ok that makes perfect sense. Thank you!
Hi guys! Which one Solo-1 version would you recommend to purchase?
Main interest - ESFM, Win9X, clean recording from Line-out.
Thank you!
P.S. It seems that they are almost the same, but nonetheless...
And by the way, do I understand correctly that the ESS Solo-1 is the ONLY PCI card with ESFM capabilities?
Uh. Yeah those look to be technically identical. If you want black connectors, and the silkscreen to say "1.1" go with A; B and C for colors and "1.10" silkscreen, or in other words - get whichever's cheapest. Or you could wait a bit for another model to show up, one with a wavetable header (even if unpopulated) - you might not care now, but may change your mind later.
Thanks for the advice! One more question: does it make sense to buy an ISA m/b + ESS card for better ESFM quality? In other words, does the Solo-1 have the same analog audio output as its ISA counterparts? (AFAIK there is no any S/PDIF version of the ESS card, which might be a better option)
Can you use a yamaha wavetable with this card (wavetable header present) in pure DOS games? I know the card works well in dos.
No hanging notes bug or some such?
Retro PC warning: The things you own end up owning you.
This sound card is driving me crazy. You obviously need the right PC (mainboard). No matter what I do, the sound card always ends up on IRQ10. Therefore not usable in DOS. But I have a question about that. How do you get the game port activated? No jumper, no software config?
elszgensa wrote on 2024-05-19, 00:18:Uh. Yeah those look to be technically identical. If you want black connectors, and the silkscreen to say "1.1" go with A; B and C for colors and "1.10" silkscreen, or in other words - get whichever's cheapest. Or you could wait a bit for another model to show up, one with a wavetable header (even if unpopulated) - you might not care now, but may change your mind later.
There is also one difference that may not be important, but anyway - variant 1 has a chip labeled "SOLO", the other variants only have a bare chip without the word "SOLO". Is this related to some chip revision or something?
You're right, I totally missed that. Whoops. To save you the trouble of rotating those photos, they're H808, K390 and K350 revisions. The K revisions might be worse unless paired with an EEPROM? Probably a good idea to re-skim this thread.
ux-3 wrote on 2024-05-19, 12:35:Can you use a yamaha wavetable with this card (wavetable header present) in pure DOS games? I know the card works well in dos.
If it has a wavetable header, it should work fine with any wavetable daughtercard.
I have an ESS Solo-1 that I added a wavetable header to and I've tested with dozens of games, and for the most part there were no issues.
I reported my test results in this thread: ESS Solo-1 DOS Compatibility Testing on Multiple Systems
Shponglefan wrote on 2024-05-19, 22:20:If it has a wavetable header, it should work fine with any wavetable daughtercard. […]
Thanks. Looking at your signiture, I looked a bit into your 486-33 thread. I am finalizing mine at the moment - at least I hope so. (Solo-1 question was for a different model).
Wavetable header works 100% bug free.
What do you think of THIS card? It's a very strange revision.
The owner says he was unable to install drivers for 2K/XP. Sometimes the card was defined as "ES1969" and sometimes as "ES1946_1938".
Hello,
Try cleaning the PCI connector. From the photo, it seems dirty or maybe damaged.
Hi!
I dumped the EEPROM from LWHA331D60 (Soundboard D66) with ES1938S K260 chip. There is almost nothing inside the file. Just "F8DF" hardware ID string.
Have fun!
