Poor performance on a 7900GS + Pentium D
Reply 82 of 94, by pentiumspeed
That 332Mhz is DDR 667 and this XPS 400 only supports up to DDR2 667 which is correct due to service manual on Dell website, due to based on Intel 945P. You'll not get much performance with demanding games using any of the P4 based processors even 3.8GHz.
https://downloads.dell.com/manuals/all-produc … anual_en-us.pdf
I suggest getting Optiplex 760 instead which supports DDR2 800 and C2D support up to 3.33GHz 2 core (E8600).
Cheers,
Great Northern aka Canada.
Reply 83 of 94, by cyclone3d
Still .. the CPU-Z bench scores are showing about 1/10th of what they should be according to the CPU-Z database.
Something is screwy.
The Sisoft Sandra scores look ok from what was posted.
Can you run the Sisoft cache/RAM benchmarks and post screenshots?
Also, what CPU usage are you seeing when HL2 is running?
Did you install updates for XP?
For funsies I could set up a Pentiun-D 3.4Ghz system and run some tests... I think I have a 3.4Ghz.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 84 of 94, by ENunn
cyclone3d wrote on 2020-07-08, 01:39:
152.2 KiB
175.68 KiB
167.58 KiB
165.06 KiB
At least 45-50%.
Not all, I'm running WSUS right now to get all those installed.
Go crazy 😜
I am probably gonna buy an Optiplex 775 and just place my GPU in that one, I found one on eBay for $50 and it seems to have a pretty beefy CPU (Core 2 Quad Q6600). I'm still gonna see if I can get this machine working until the end though 😀
the
Reply 85 of 94, by cyclone3d
Sandra scores look fine... hmmm.
45-50% means it is pretty much maxing out one core.
If you run higher resolution does the fps go down at all?
YMF7x4 Guide
Reply 86 of 94, by ENunn
cyclone3d wrote on 2020-07-08, 02:28:
Yeah a little bit, not much though. 3-5 fps difference maybe? Ran it at 1280x1024.
the
Reply 87 of 94, by ENunn
Just a final update, I said screw and bought another Dell. Core 2 Quad, same GPU, PSU, and RAM since I just swapped it out from the old one. It performs much much better.
I do have some issues though. I got a sound card, an X-Fi Xtreme. Pretty good card. Tried out FarCry and for the life of me, audio doesn't even want to work most of the time. If I fire a gun or go outside all audio dies until I reboot or close Far Cry. One time it just started popping when I went outside and was fine once I paused the game, then it stopped and so on. Another time my mouse just gave up and everything froze. Not sure why that is. Could be the thermal paste though, I ran out of thermal paste when I was changing everything so I only got to apply a little bit unfortunately. I'll get that swapped out once I get my new paste. Audio seems to work fine everywhere else though.
Speaking of my CPU, how's this for the scores in CPU-Z? Is it normal speeds? Probably not.
70.37 KiB
the
Reply 88 of 94, by pentiumspeed
Get these ram from ebay, any of of these; your third-party memory could be failing giving problems. This is reason why I refuse to purchase gamers' memory, I use these OEM brands exclusively in my computers and had no issues.
Also check your hard drive's SMART attributes by download small program called gsmartcontrol and run it and report back.
https://www.ebay.ca/itm/4GB-2x-2GB-DDR2-PC2-6 … QgAAOSwyWFeB-IM
https://www.ebay.ca/itm/Samsung-M378T5663QZ3- … fkAAOSw6Sper37p
https://www.ebay.ca/itm/Samsung-4GB-2X-2GB-PC … KQAAOSwxS9ch1tO
https://www.ebay.ca/itm/Hynix-4GB-2X2GB-PC2-6 … r0AAOSwUsxbJtkk
https://www.ebay.ca/itm/Elpida-4GB-2X2GB-PC2- … IsAAOSwGu9evwZI
Reply 89 of 94, by ENunn
pentiumspeed wrote on 2020-07-14, 02:07:
The PC did come with 4GB of Hynix DDr2 667MHZ ram, just swapped the Corsair with the OEM. Seems to be a little better however it didn't fix my audio issues with Far Cry.
I tried to run gsmart but it gives me a "dwmapi.dll not found" error
the
Reply 90 of 94, by darry
ENunn wrote on 2020-07-14, 01:50:
Just a final update, I said screw and bought another Dell. Core 2 Quad, same GPU, PSU, and RAM since I just swapped it out from […]
X-Fi Xtreme Audio is an X-FI in name only . It is not based on an EMU 20K1 or 20K2 chip . It has no hardware acceleration . Does Far Cry allow disabling environmental audio and/or audio and or "hardware acceleration" for audio ?
Reply 91 of 94, by ENunn
darry wrote on 2020-07-14, 05:01:
something about eax but i disabled it and there's no difference
the
Reply 92 of 94, by ENunn
Another update: using my on board audio works fine. Guess it's a card issue. Gonna pick up a Titanium and probably save this card for digital audio capture through Toslink. Thanks for the help everyone!
the
Reply 93 of 94, by pentiumspeed
Awesome.
Order 4GB of OEM DDR2-800 memory as I suggested so you can run at 800 properly. Better is big progress indeed.
Cheers,
Reply 94 of 94, by lordmogul
You asked for it so...
Put my LGA775 build on the same clocks for a little check. (9x266, DDR2-667 CL5)
17.93 KiB
Seems about right. The Xeon is slightly faster, but mostly because Penryn is a tad faster than Conroe.
As a sidenote, I also did a run with the 4.1 GHz I usually run on it:
17.97 KiB
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
