Reply 80 of 86, by Sombrero
ElectroSoldier wrote on 2024-02-22, 18:39:
Joseph_Joestar wrote on 2024-02-22, 09:40:
ElectroSoldier wrote on 2024-02-22, 09:11:
I also have a device manager that has no exclamation marks but performance in some/most games is poor compared to a P4 system.
Is your system using a VIA chipset with an AGP graphics card by any chance? There's a known bug with certain VIA chipsets which halves AGP performance under Win98. Also, using more than 2GB RAM cripples Win98 on some chipsets, including the Intel P35 which I'm using.
Otherwise, I don't really see how a Core 2 CPU can be slower than a Pentium 4, assuming both are running at similar clocks.
VIA with a PCIe slot and a 7600GS.
I had massive issues with PCIe 6800 GT with every driver I tried on Win98SE which led me to conclude NVIDIA 6x.xx - 8x.xx drivers sucked hard. I had issues even under Win2k. Only 93.71 under WinXP worked well with almost everything.
Meanwhile ATI X700 has been chugging along just fine under Win98SE, even though those cards have their own shortcomings too.
Reply 81 of 86, by Joseph_Joestar
Nvidia 7000 series cards aren't so great for Win9x gaming. The drivers that they require are simply too new, and many games will exhibit unusual issues, including low performance.
Try something from ATi's X800 series with Catalyst 6.2 instead. It will likely be more stable. Though VIA's chipset quirkiness might play a role as well.
Reply 82 of 86, by ElectroSoldier
Joseph_Joestar wrote on 2024-02-22, 19:47:
Yeah Ive seen that but I cant seem to get the GF 6200 I have working.
I did the team red thing the first time around, I was wanting to use team green this time.
Reply 83 of 86, by ElectroSoldier
Its not a 7600GS its a 7100GS.
Its been a couple of weeks since I was messing about with it... But the idea is the same.
Like I said I think its super situational to get Win98 to work properly on a 775 board because most of them dont work properly.
Reply 84 of 86, by DarthSun
ElectroSoldier wrote on 2024-02-23, 17:34:
S775? By default, the modded X58 drivers are excellent, they contain the appropriate ones. But this is only the base, RyZen/7900xx is also excellent, obviously the secret is to install 98 properly. It is a bit complicated, but here, in the domestic retro topic, I have already explained in detail what, why and how.
The correct routine had to be present from 1998 to the present day, obviously a retired Win98 expert knows that.
343.61 KiB
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 85 of 86, by The Serpent Rider
X58 is way more appropriate:
1) Floppy support
2) Full legacy CSM
3) True PCI
4) Access to dISAppointment on some motherboards.
Reply 86 of 86, by DarthSun
The Serpent Rider wrote on 2024-02-23, 21:19:
X58 is way more appropriate: 1) Floppy support 2) Full legacy CSM 3) True PCI 4) Access to dISAppointment on some motherboards. […]
1) Floppy support
2) Full legacy CSM
3) True PCI
Of course, the X58 is a better friend to the W98, I'm only motivated by the challenge of even newer machines.
