Speedy3D support in DOSBox
Reply 80 of 83, by sharangad
ripsaw8080 wrote on 2024-05-06, 21:09:
Which thread(s) are you locking? FYI, SDL has its own thread for audio, and SB sound generation might be using DMA, but you can probably use SDL_mutex locks to avoid collisions there.
I have a separate thread to handle Rendition DMA transfer within dosbox. SDL_mutex? I'll check it out thanks.
https://www.youtube.com/@sharangadayananda
Reply 81 of 83, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Have you looked at the DMA callback in sblaster.cpp as an example for handling the transfer data?
Reply 82 of 83, by sharangad
ripsaw8080 wrote on 2024-05-07, 03:14:
I'll check it out. Had a few other things to sort out. It never went even occurred to me check out the sound blaster code.
Reply 83 of 83, by sharangad
That worked fabulously well. Thanks!!! I get a bit of audio stutter now every once in a while.
