Reply 8260 of 53268, by tayyare
Stojke wrote:
But scsi is more cool 🤣
^This!..🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8261 of 53268, by CelGen
133MHz wrote:
Today I unearthed this beauty of a system amongst a pile of boring Pentium 4 boxes at my usual flea market:
-Everex 386-
You bum! I've been looking for one of those for years. The last one I came across had the mobo switched out and that made the front display inoperable. I got the matching ISA cards and external QIC tape drive that matches up with the machine.
Reply 8264 of 53268, by PhilsComputerLab
keropi wrote:
^ use them to easier connect led/power/reset cables to mobos?
Awww, you got it straight away 🤣
I remember an Asus Core 2 Duo board coming with something like this:
Most useful idea ever 🤣 Mucking around with front header panel cables in a tight case is such a PAIN.
YouTube, Facebook, Website
Reply 8265 of 53268, by hard1k
That bit of hardware is called ASUS Q-Connector: http://event.asus.com/2012/mb/tco_qr/pages/Su … -Connector.html
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 8266 of 53268, by PhilsComputerLab
Yes. Well turns out the pins are not thick enough 😒 And too short.
Might need to shop around a bit more.
Reply 8267 of 53268, by 133MHz
CelGen wrote:
-Everex 386-
When I opened it up the first time I noticed that the front display cable was unplugged from the motherboard. My OCD wanted to make me plug it back in but I noticed that the connector on the motherboard had no indication of which way around pin 1 is, so I left it alone for the time being. Later when cleaning it up I also noticed some sort of cloudy spot inside the display assembly, so I believe it's possible that some previous owner blew up the display by connecting it backwards. 🙁
I'm afraid to try it without being absolutely sure. I really hope that cloudiness is just dirt and not from a blown component.
The Asus Q-Connector thing is a good idea in principle, but IME it tends to come loose and erratically disable your front panel. Had to troubleshoot a couple of machines where this was the culprit of no power, no lights, etc. Hot-gluing it down would totally defeat the purpose. 😵
http://133FSB.wordpress.com
Reply 8269 of 53268, by Artex
BOING!
Reply 8270 of 53268, by F2bnp
keropi wrote:
Damn!
Reply 8271 of 53268, by skitters
keropi wrote:
http://i125.photobucket.com/albums/p55/restqp/temp1/WP_20150710_001_zpslxkroi1j.jpg […]
How do you use those?
I found a picture of the card here
(from this auction)
But how does it connect to the main video card?
I don't see any sort of connector like the Voodoo 2 uses.
Or is everything done through the motherboard slot?
Reply 8272 of 53268, by Artex
Yup, all over the PCI bus.
Reply 8273 of 53268, by kithylin
Could multiple of these be used together in the same system?
Reply 8274 of 53268, by Artex
Do you mean multiple PCX2s for a bigger performance gain? Or an combination of different cards with different drivers?
Reply 8275 of 53268, by RacoonRider
PCI bandwith kills off the performance of one, why would you want several?
That picture on the box is a perfect representation of m3D. Having a huge potential, yet doomed, like a clever child with leukaemia.
Reply 8276 of 53268, by Artex
Awful analogy but I agree on your PCI bandwidth statement. Unless he's looking to run a PCX2 and a PCX1 in the same system.
Reply 8277 of 53268, by PeterLI
I have another ValuePoint 325T en route. A little banged up but with spare parts to rebuild some others I have.
Reply 8278 of 53268, by ODwilly
Picked up a Compaq Presario 2800 Laptop. 40gb hard drive, 512mb of DDR 266 (need to find a pair of 512's to max it out) 1.8ghz Pentium 4 M Willamette cpu and ATI 7500 Mobility graphics with 64mb of dedicated memory + 64mb stolen from the system ram. My new work laptop,replacing a Thinkpad 770 😀 Review of the Compaq can be found here: http://www.pcmag.com/article2/0,2817,668920,00.asp EDIT: (better review) http://www.anandtech.com/show/907
Reply 8279 of 53268, by SquallStrife
Fuck dude. That's dark. 🙁
