DOSBox Game Launcher (DOSBox Frontend)
Reply 861 of 2180, by rcblanke
Thanks. The wizard will most likely need a lot of tweaking still to make it really user-friendly, but for the moment I hope that especially novice users will find it a useful feature.
Reply 862 of 2180, by gbbbs
@rcblanke
any chance to implement run external programs ? like xppader ... ?
one question btw,
why if i consult moby games for infos, dont show all screenshots on the right side ? they show me many screenshots and cover arts but not all ... in wich priority works the search ?
Reply 863 of 2180, by rcblanke
Maybe, but no priority at the moment.
Can you give me an example of such a case? What game title did you search ?
Reply 864 of 2180, by rcblanke
Hi all,
A small update (0.73g) to fix some minor issues I've found:
* Fixed game 'prepare' to switch to the target drive correctly
* When browsing inside a .ima file, treat a missing boot sector signature to be non-fatal (like DOSBox does)
* synchronized translation files (some are quite a bit behind, hint hint 😉 ).
* properly close streams after reading 7-zip gpa
* Remember some of the last-used settings in the add game wizard
All the latest files
To upgrade, grab the dbgl.jar as usual.
This will most likely be the last test-build unless more serious issues pop up.
Regards,
Ronald
Reply 865 of 2180, by Neville
rcblanke wrote:
Hi all, […]
Hi all,
Regards,
Ronald
I plan to update my Spanish translation as soon as a stable version appears. Of course, if no further changes are to be made to the texts, I can start as soon as you want.
Reply 866 of 2180, by rcblanke
Thanks Neville, I expect no further changes to the texts, please go ahead!
Reply 867 of 2180, by Neville
Are the language files from your website updated? I can't see the lines to translate the new wizard, or the filters.
Reply 868 of 2180, by rcblanke
Please take this one Neville. The additions are around line 700.
Reply 869 of 2180, by Neville
Ah, OK.
Reply 870 of 2180, by kolano
rcblanke wrote:
Hi all,
Ronald,
Do you think that will fix an issue I've been seeing, where DBGL has trouble seeing files off of my network drive post boot-up?
Currently, I seem to need to browse to the relevent location before things are seen. Likely related to needing to run DBGL as Admin due to prior issues with Windows UAC (User Access Controls) preventing DBGL from writing files in it's directory.
Reply 871 of 2180, by Neville
Spanish translation updated. I may still review it later, but just in case...
Reply 872 of 2180, by kolano
kolano wrote:
Ronald, […]
rcblanke wrote:
Hi all,
Ronald,
Hrm, it does not.
So, the current rundown is, under Windows 7 (and likely Vista) /w UAC on, trying to run the DBGL results in a DB error. Seems related to Windows preventing write access to the files used.
The solution Windows provides to that issue is to run an application as an Administrator (not a very good solution, but I'll try to keep my UAC griping minimal), which enables them to read/write files at will. However, Windows apparently considers additional security restrictions on network resources, and doesn't transfer them between users. Due to that, existing network drive mappings are not shared with the Admin user. They need to be explicitly re-established, simply browsing into the folders in a file dialog does so, but it's irksome.
The alternate solution to this issue is to not launch DBGL from the default "Program Files" or "Program Files (x86)" folders. So, for now I have an additional "Program Files (UAC Off)" folder, which seems to avoid the nonsense.
Reply 873 of 2180, by rcblanke
Good point, Kolano. The
is correct. I might have to look into that sometime to make it more flexible, but without loosing the portability of course.
Reply 874 of 2180, by kolano
You may also want to provide a note regarding that on the DBGL homepage.
Reply 875 of 2180, by rcblanke
Just did, thanks.
Reply 877 of 2180, by rcblanke
Interesting, I had no idea that the VirtualStore mechanism looks at file extensions. Unfortunately, it seems that HSQLDB (the database engine) does not allow configuration of the file extensions used 😒
Reply 878 of 2180, by collector
Is there a way to redirect to the user's %AppData%? I guess that if so, you would also want to make it configurable to use either absolute paths (for hard drive installs) or relative paths (for portable purposes).
Reply 879 of 2180, by gbbbs
rcblanke wrote:
Maybe, but no priority at the moment. […]
Many games ...
example Realms of the haunting :
but it have much more cover arts :
http://www.mobygames.com/game/dos/realms-of-t … nting/cover-art
