Reply 860 of 29879, by Godlike
Now question to 286/386 users. What kind of card this is?
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Bottom card looks like a Soundblaster Pro 2. Top card is a VGA/EGA card, probably OTI-067 or ET4000AX.
Definately no...this is kinda older equipment. Remember this picture is taken out of 286 16Mhz
Who has used Paint as a bad photoshop job on that picture? 🤣
wrote:Who has used Paint as a bad photoshop job on that picture? 🤣
ME 😈 this is quick surgery in pain(t), actually this item is for sale and there was sellers name on it, so I won't use this photo without his permission, so just use it without his name, just to show what's question about 😀
It is a VGA card... My EV-673 is just like that at the back. VGA had a 9 Pin connector when it first came out. Others used it as a means to connect with other devices (don't ask me what, I've never figured it out). Some cards even did have output for an EGA monitor as well though, so it could be any of the above.
The DIP Switch is used to set refresh rates or resolution or some such... Can't remember because mine is working so I just leave it alone.
Yes, the card with dip switch will be 100% VGA, the 9pin output for monochromatic monitors and conventional 15pin VGA connector as well. I like this! Curious what's exact model of it! Other card is far from SB Pro2, I know that this 286 comes from Germany, so anyone from that country will maybe discover it easier with finding proper names to those extension cards
I'd say an ET3000 for the video card.
Second the ET3000. Only ISA card I could find on vgamuseum.info with two different D-Sub outputs and a (blue) block of DIP switches between them, see http://vgamuseum.info/index.php/component/k2/ … -tseng-et3000ax
Cirrus seem more common in European machines to me.
Going with a Cirrus 510/520 or 610/620 by the age the connectors imply. There was certainly a model with that layout, though I remember it being a red dip switch.
wrote:I'd say an ET3000 for the video card.
wrote:Second the ET3000
Well done! Tseng ET3000 this is it, 512kB memory, EGA and VGA. Start like it for my scrap 286 build, because I don't have monochromatic screen right now or any 9pin to 15vga adapter..i saw somwhere on the web actually easy scheme for adapter but will be easier to buy proper card.
Anyone will try of discover name for the audio card?
wrote:VGA had a 9 Pin connector when it first came out.
I've never heard of VGA using a 9pin connector. Do you have any examples of this? It is my understanding that when IBM originally developed the VGA standard and the first cards, they specifically chose a more dense connector because 1) VGA signalling with V/H-sync required more than 9 pins, and 2) to prevent someone from inadvertently plugging in an analog 0.7V VGA display into a 5V TTL CGA/EGA/MDA source and frying their video hardware.
wrote:Anyone will try of discover name for the audio card?
Hmm... too generic. Both SB 1.x/2.0 as well as SB Pro uses brackets with identical port spacing. We'd need to see more.
wrote:wrote:Anyone will try of discover name for the audio card?
I have a Vibra 16 with that same type of back panel, so it really doesnt narrow it down at all.
Dos: AMD 386 DX40 | 8MB RAM | SB Vibra 16
Dos: AMD 586-133|32MB RAM|2GB CF|2MB S3 Virge|AWE32-8MB
WinME: Athlon-500MHz|512MB|2x80GB|SB Live|Voodoo 3 3000 16MB
Win10: i7-6700K|16GB|1x250GB SSD 1x1.5TB|AMD Fury X
wrote:wrote:wrote:Anyone will try of discover name for the audio card?
CT????
@QBiN; unfortunately no pictures of inside, this auction and no specs of picture of inside
On old compaq (a real beauty - and a very smart construction....) without any life
Without drives and power...
Mainboard....
The heart of gold
and finally: tadaa (i was able to replace some power cells to get access to the bios and also replace the hdd with an other old one out of my collection , but i'm not happy yet, because the drive's parameters the bios offers does not fit exactly to the replacement-drive and i do not know, how to set them manually)
there is still work to do (additional: the floppy is not working (transmission belt is gone))
errare humanum est
wrote:wrote:wrote:I have a Vibra 16 with that same type of back panel, so it really doesnt narrow it down at all.
CT????
I will find out after work tonight for you.
Excellent, thank you
Got a heap of LS120 disks this week at a good price. Today I transferred all the 286s 52meg hdd files to an LS120 disk using xcopy. One of a number one backup option.
wrote:Excellent, thank you
CT2501-TDQ
I should read up on it and see if its one of the ones with the hanging bug I guess...
wrote:wrote:VGA had a 9 Pin connector when it first came out.
My first Vga monitor had a 9 pin D connector on the monitor end of it's detatchable cable. I suspect it was so a suitable cable could be attached to other computer types such as the Acorn A3000s.
Here's a link to 9 pin vga pin out http://old.pinouts.ru/VideoCables/9to15VGA_pinout.shtml 9 pins are all that's needed for VGA.
Also a bit of further reading http://www.dansdata.com/gz061.htm
