Reply 860 of 896, by Peixoto
- Member
KainXVIII wrote on 2021-07-28, 10:02:Download link is no longer working?
Its fixed. Thanks for letting me know
Hey Peixoto,
"Some of the games supported can be seen here or here"
The second "here" link no longer works, it says file is in a trash at Google Drive. Could you fix this AND update that text file with the most recent game list?
Thank You!!
Terep wrote on 2021-12-30, 10:07:Hey Peixoto, […]
Hey Peixoto,
The second "here" link no longer works, it says file is in a trash at Google Drive. Could you fix this AND update that text file with the most recent game list?Thank You!!
It's up again and up to date
How do I use this with Steam games ? I need to start through steam to get the Steam overlay for Steam controller. Cheers.
I have a problem playing Tomb Raider II with Peixoto patch. I'm playing the GOG version of the game that normally runs through DOS box if Peixoto is not used.
It has previously worked on my other Windows 10 x64 machine without issue. I've now installed the same Tomb Raider II on a Windows 10 x64 laptop and have followed the same process. It's a pretty fresh Windows 10 install.
However, now when I try and launch the game through Peixoto I get an error: "Unable to find or load Peixoto\Program\AutoHotkey.dll-126". I can confirm that the DLL is there and it does not look like my antivirus (Windows Defender) is blocking it. I've installed various C++ Redistributables in case that was the issue but have had no success. I've since tried Tomb Raider I and III and I get the same issue.
Any ideas would be welcome.
Thanks
Hello Guys I'm trying to play Die By The Sword, but I'm having some issues. The first one is that in the Menus loading screen there are some lag/slodows, like it can't load the texts.(is that something that I can fix in the Peixoto settings?)
And the second one, In the Quest and Tournament Mode I can't go through, I click on them and it tells me to click ALT+F4 to Exit.
I hope there is someone can help to solve this problem, this is a game I discovered when I was 8 by my uncle and never had the opportunity to play it.
Thank you so so much
xBR and SuperSampling are creating terrible seams. Is there a fullscreen filter only for the backgrounds in Resident Evil 1 (1996) ?
I'm using this with Martian Gothic and it works great, but my D: drive disappears after I quit the game, and then I have to reassign the drive letter. Any ideas?
NEO117 wrote on 2022-05-21, 07:36:I'm using this with Martian Gothic and it works great, but my D: drive disappears after I quit the game, and then I have to reassign the drive letter. Any ideas?
On the latest update, I had included a file I should have. It is fixed now. Re-download and it won't unmount your d:\ drive
Hello Peixoto,
I've a problem with tomb5 ... transparent part of the upscaled textures is replaced by black color. Is there a solution? Thanks
scan72 wrote on 2022-05-25, 22:59:Hello Peixoto,
I'm not sure how to get this patch to work for Blade Runner.
I set it to target the shorcut that GOG created.
The game uses scummvm to launch with additional command lines.
If I set it to the actual scummvm.exe will it still launch Blade Runner properly?
I also have on idea how to change the targeted executable for the patch.
scan72 wrote on 2022-05-27, 21:12:
Sparktank wrote on 2022-05-29, 03:16:I'm not sure how to get this patch to work for Blade Runner. I set it to target the shorcut that GOG created. The game uses scum […]
The game uses scummvm to launch with additional command lines.If I set it to the actual scummvm.exe will it still launch Blade Runner properly?
As mentioned in the patron page: support is only offered to supporters.
Not going to lie. It's pretty steep price for support in Canadian currency.
There are other issues I'm having but it's useless to even think of using the mod anymore. Or even recommend it to anyone.
You are butthurt that a random person, that already gave his time to make the patch, wont take another 30min of his/hers time just for you, so you can play your video game?
Loop this statement. Then apologize to peixoto for being an idiot.
Sparktank wrote on 2022-06-02, 17:46:Not going to lie. It's pretty steep price for support in Canadian currency.
Half an hour wage is not a steep price to get support from the developer of the program for a month.
Hello people I have an issue, would be very glad if someone had a solution. I use the patch for Half Life Steam version and it works flawlessly, only issue is I want to play the mod They Hunger with it, and the mouse doesn't work correctly with mods. The fix for that is to put -noforcemaccel -noforcemspd -noforcemparms commands in the launch options, but I can't seem to figure out how to use launch commands with this patch. I created a shortcut and worked from there, have put in the commands but they don't work.
Thanks in advance
Help! When i open a game with Peixoto patch there is this error: Unable to find or load: C:\Users\(username)\Desktop\Peixoto\program\autohotkey.dll-193
WHY???
Peixoto wrote on 2017-03-27, 03:55:Moved here: https://www.patreon.com/user?u=44312848
Please visit that page if you need support
hello did you moved the patch on patreon??
