Reply 860 of 1061, by darry
TehGuy wrote on 2022-04-15, 21:50:darry wrote on 2020-10-29, 01:58:This Orpheus specific driver looks like it is based on the reference pv2860.zip driver set, so I tried to install that instead and it works fine for me, AFAICT (the only change I made is a registry key to enable digital output).
Digging up a 2 year post, but what did you end up changing if you remember? I'm trying to activate the SPDIF out so I can run my rig through my DAC and onto whatever else i need
You should be able to get the key name from the INF file or modify the inf and reinstall the driver.
Re: Orpheus Soundcard: a new DOS soundcard with SPDIF/OPL3/MPU support
@keropi @marmes Maybe that info should be added to http://www.pcmidi.eu/orpheus.html . Sorry if it's already there and I missed it .
