Reply 900 of 958, by Mumak
- Oldbie
Grzyb wrote on 2025-01-01, 17:40:My Celeron still pretends to be a Pentium II...
I have uploaded version 6.2.6. Please let me know if it fixes the problem.
Mumak wrote on 2025-01-01, 20:27:I have uploaded version 6.2.6. Please let me know if it fixes the problem.
Looks OK now...
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Thanks for the feedback.
HWiNFO for DOS thinks my AWE64 Gold is a PAS.
Has there been any thought to adding a BIOS image copy feature to HWINFO? If you do implement it, an option to save as EVEN/ODD (two file) could be helpful for some people.
zuldan wrote on 2025-03-08, 01:41:HWiNFO for DOS thinks my AWE64 Gold is a PAS.
Can you provide the HWiNFO Debug File so I can check it?
feipoa wrote on 2025-03-08, 01:53:Has there been any thought to adding a BIOS image copy feature to HWINFO? If you do implement it, an option to save as EVEN/ODD (two file) could be helpful for some people.
In the past HWiNFO was shipped with small utils to dump some data including BIOS image (but not even/odd). They can be downloaded now here: https://www.hwinfo.com/files/old/
Mumak wrote on 2025-03-08, 07:39:Can you provide the HWiNFO Debug File so I can check it?
Managed to spend some more time on this. It's a very strange bug.
I ran HWiNFO today and it worked perfectly, BUT...
I then closed the app and ran it again but this time I got the Microsoft Sound System.
Here is the debug file for when it detected the Microsoft Sound System.
It's a bit tricky to replicate. I can't do it everytime but when the bug does occur, I go into Mainboard info then Video info and finally Peripherals info. Let me know if you need anything else.
Hi, I've been using HWiNFO for as long as I can remember, and I'm really happy it's still being maintained!
That said, I just wanted to report a small bug: HWiNFO reports the Sound Blaster 16 DSP version as 4.4, when it should actually be 4.04.
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
Dusko wrote on 2025-08-08, 03:38:Hi, I've been using HWiNFO for as long as I can remember, and I'm really happy it's still being maintained!
Thanks, will be fixed in the next version.
HWinfo DOS. RyZen+7900GS+SBLive / Native DOS run.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
The DOS version is not designed for such later systems. It intentionally lacks support of these systems to maintain a low footprint.
Mumak wrote on 2025-08-08, 11:41:The DOS version is not designed for such later systems. It intentionally lacks support of these systems to maintain a low footprint.
Of course, I know, I just added it as an interesting fact that it can detect a few things well even from this.
It would be nice to provide clear statement about recommended versions for various hardware categories.
Something like:
"for 16-bit CPU - use HWiNFO16
for 32-bit CPU - use HWiNFO for DOS
for 64-bit CPU - use HWiNFO for Windows"
There's no eaxct margin where to use HWiNFO for DOS or HWiNFO32. I'd say:
For 16-bit CPU (8086-286) - Use HWiNFO16
For 32-bit CPU (386+) - Use HWiNFO for DOS; for systems capable running W2k/XP use HWiNFO32 for Windows
For 64-bit CPU - Use HWiNFO64 for Windows
For ARM64 (Windows) - Use HWiNFO ARM64
It runs fine under Win98 on the 7.02 madness machine.
Yes, HWiNFO32 supports Win98 too but you'll usually get better results under Win2k/XP
Yes, a great program!
I have a mania for running the older operating system on the latest computer, which is why I like that it runs on Win98 as well.
Mumak wrote on 2025-03-08, 07:42:In the past HWiNFO was shipped with small utils to dump some data including BIOS image (but not even/odd). They can be downloaded now here: https://www.hwinfo.com/files/old/
Well it would be nice incomporate it Gui menu, it would be nice to add Videobios dumping too, because its need for Linux KVM vios part through and Linux versio is problematic.
Newer system and memory footprint, its solvable with better management.. you can probably split data and load and unload them on the fly one by one during detection, its not actually rocket science.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Attempting to get video info on a Diamond Viper VLB results in graphics corruption that changes to different-looking corruption after exiting the application and executing other apps with various video modes. Power cycled to fix.
X-vesa seemed to work ok.
I wonder if it has to do with the Viper using an Oak chip for vga compatibility and a Weiktek P9000 for the VESA modes. Something similar happens when running a pre-version 6 of univbe on my system.
Example of screen after selecting video info while inside hwinfo:
