Reply 900 of 986, by PC@LIVE
- Oldbie
I was looking for an S.7 motherboard among the MBs, yes that's right, but although most are grouped, with the indication of each card, there are others that are instead in a box 📦, without it being written what the content is.
So sometimes I find motherboards, which I repaired or started to repair, or boards that after a component replacement intervention, have not given signs of life, so after some time ⏱, they are re-examined in search of a solution, hoping to make them work again.
Some time ago, I don't know exactly how long, but it could be a couple of years (?), I replaced several capacitors on an S.478 motherboard.
This is one of the first models with VIA chipset and DDR RAM, so P4/400, the card is a "AZZA P4M2-MVB", as mentioned above, I replaced several electrolytic capacitors, except for one of the SACON 3300uF 6.3V, well today as a surprise 😱, I discovered that that one also needs to be replaced, you can see a bulge at the top, and this is a sign that it needs to be changed.
I should have a spare capacitor, I would like to use a Nichicon equal to the other six, from memory I don't remember if this motherboard has been tested or not, however we will have to wait for the replacement of that capacitor, to do a start-up test.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
