HWiNFO for DOS resurrected !
Reply 920 of 938, by Mumak
This is most likely caused by clash with detection of another chip. I'd need to see the HWiNFO Debug File.
Reply 921 of 938, by CkRtech
My apologies
VidMode=3 DispComb=8 HWiNFO v6.2.6 Flushing disk caches ... […]
VidMode=3
DispComb=8
HWiNFO v6.2.6
Reading Data ...
DetectCPU - 486
FPUtest=3
Check Cx
Check IBM
Not IBM
Get freq
FreqCPU: 689-17
Cache 1K: 21.6 -> 21.6
Cache 2K: 40.0 -> 40.0 = 1.85x
Cache 4K: 76.8 -> 76.8 = 1.92x
Cache 8K: 153.0 -> 153.0 = 1.99x
Cache 16K: 480.7 -> 480.7 = 3.14x *L1*
Cache 32K: 958.0 -> 958.0 = 1.99x
Cache 64K: 1914.0 -> 1914.0 = 2.00x
Cache 128K: 3826.0 -> 3826.0 = 2.00x
Cache 256K: 7678.0 -> 7678.0 = 2.01x
Cache 512K: 41105.0 -> 41105.0 = 5.35x *L2*
Cache 640K: 51380.0 -> 51380.0 = 1.25x
Check FPU: int
Checking DDC
Checking: Matrox MGA-I, -II, -64
Checking: S-MOS
Checking: ARK
Checking: Alliance 3210
Checking: SiS
Checking: Tseng
Checking: Cirrus (BIOS)
Checking: Cirrus (io)
Checking: Headland
Checking: Cirrus (old)
Checking: Ahead
Checking: Chips & Tech.
Checking: Trident, IIT
Checking: Avance Logic
Checking: Weitek
Checking: Sierra
Checking: ATI
Checking: Western Digital
Checking: OAK
Checking: Yamaha 6388
Checking: MediaVision MVV452
Checking: Diamond
Checking: HGS
Checking: Genoa
Checking: Everex
Checking: miro
Checking: Cardex
Checking: ELSA
Checking: AT&T DEB
Reply 922 of 938, by Mumak
Thanks. It's not easy to determine remotely which check is causing it. Can you please run "HWINFO - r" - that should automatically produce a report file
Reply 923 of 938, by CkRtech
HWiNFO v6.2.6 █████████████████████████████System Information█████████████████████████████ ║ […]
HWiNFO v6.2.6
║ Main Processor: IntelDX2, 66.6 MHz ║
║ Math Co-Processor: Internal ║
║ Bus Type: ISA ║
║ Mainboard Model: Soyo Premium G2 ║
║ Mainboard Chipset: SIS-85C471 ║
║ First Level Cache: 8 KBytes ║
║ Second Level Cache: 256 KBytes of Asynchronous SRAM ║
║ System Memory Size: 640 KBytes ┐ ║
║ Extended Memory Size: 23,552 KBytes ├ Total: 24 MBytes ║
║ Shadow+Special RAM Size: 384 KBytes ┘ ║
║ Machine Type: IBM PC AT ║
║ Computer Name: Unknown ║
║ BIOS Manufacturer: Award Modular BIOS v4.50G [09/26/94] ║
HWiNFO v6.2.6
████████████████████████████More CPU Information████████████████████████████
║ CPU ID: 04320000 (Method 1) ║
║ CPU Stepping: A0/A1/A2; AMD - ? ║
║ Number of CPU Cores: 1 ║
║ Number of Logical CPUs: 1 ║
║ Instruction TLB: N/A ║
║ Data TLB: N/A ║
║ CPU Update Revision: N/A ║
║ Multi-Processor System: Not Present ║
║ P.I. ROM: Not Present ║
HWiNFO v6.2.6
██████████████████████████████████Bus info██████████████████████████████████
║ Bus Type Bus Number ║
║ ISA PnP - ║
║ ISA/VLB - ║
HWiNFO v6.2.6
███████████████████████████Plug-and-Play Devices████████████████████████████
║ CSN 1: ESS ES1868 Plug and Play AudioDrive ║
║ CSN 2: 3Com 3C509B EtherLink III ║
HWiNFO v6.2.6
████████████████████████Plug-and-Play Device Details████████████████████████
║ Device ID: ESS1868 ║
║ Device Serial Number: FFFFFFFF ║
║ Device Version: 1.0 ║
║ Subdevice ID: ESS0000 ║
║ Subdevice ID: ESS1868 ║
║ Subdevice ID: ESS0001 ║
║ Subdevice ID: ESS0002 ║
HWiNFO v6.2.6
██████████████████████Plug-and-Play Subdevice Details███████████████████████
║ I/O Port(s): 0800-0FF8 ║
║ Logical Device ID: ESS1868 ║
HWiNFO v6.2.6
║ Configuration type: Preferred ║
║ Configuration type: Acceptable ║
║ Configuration type: Sub-optimal ║
║ Logical Device ID: ESS0001 ║
HWiNFO v6.2.6
║ Supported DMA(s): 1 ║
║ Supported DMA(s): 0, 3 ║
║ Supported IRQ(s): 5 ║
║ I/O Port(s) (fixed): 0220-022F ║
║ I/O Port(s) (fixed): 0388-038B ║
║ I/O Port(s) (fixed): 0330-0331 ║
HWiNFO v6.2.6
║ Supported IRQ(s): 5, 7, 9, 10 ║
║ I/O Port(s): 0220-0240 ║
║ I/O Port(s): 0300-0330 ║
HWiNFO v6.2.6
║ Supported DMA(s): 0, 1, 3 ║
║ Supported IRQ(s): 5, 7, 9, 10, 11, 12 ║
║ I/O Port(s): 0220-0280 ║
HWiNFO v6.2.6
║ I/O Port(s): 0800-0FFE ║
HWiNFO v6.2.6
║ I/O Port(s): 0800-0FFC ║
HWiNFO v6.2.6
║ Compatible with: PNPB02F (Gameport Joystick) ║
║ Logical Device ID: ESS0002 ║
HWiNFO v6.2.6
║ I/O Port(s) (fixed): 0201 ║
HWiNFO v6.2.6
║ I/O Port(s): 0200-020F ║
HWiNFO v6.2.6
║ Compatible with: PNP0600 (IDE/ESDI Hard Disk Controller) ║
HWiNFO v6.2.6
║ Supported IRQ(s): 12 ║
║ I/O Port(s) (fixed): 0168-016F ║
║ I/O Port(s) (fixed): 036E-036F ║
HWiNFO v6.2.6
║ Supported IRQ(s): 10, 11 ║
HWiNFO v6.2.6
║ Supported IRQ(s): 10, 11, 12 ║
║ I/O Port(s) (fixed): 01E8-01EF ║
║ I/O Port(s) (fixed): 03EE-03EF ║
HWiNFO v6.2.6
║ I/O Port(s): 0100-01F8 ║
║ I/O Port(s): 0300-03FE ║
HWiNFO v6.2.6
║ Device ID: TCM5095 ║
║ Device Serial Number: 24329F9E ║
║ IRQ select 0: 5 ║
║ I/O port: 300 ║
║ Subdevice ID: TCM5095 ║
HWiNFO v6.2.6
║ Compatible with: PNP80F7 (3Com 3C509/B EtherLink III ISA Adapter║
║ Supported IRQ(s): 3, 5, 7, 9, 10, 11, 12, 15 ║
║ I/O Port(s): 0210-03E0 ║
HWiNFO v6.2.6
███████████████████████████ISA and other devices████████████████████████████
║ 3Com 3C509(B)-TPO EtherLink III Adapter ║
║ Promise PDC20230-C/PDC20630 VLB IDE Controller At port: 01F0 ║
HWiNFO v6.2.6
██████████████████3Com EtherLink III Network Adapter Info███████████████████
║ I/O Base: 300 ║
║ IRQ Level: 5 ║
║ Ethernet Address: 00A024329F9E ║
║ Date of Manufacture: Oct-11-1995 ║
║ Serial Number: 6CD329F9E ║
║ Boot PROM: Not Present ║
║ NW Driver Optimization: Windows & OS/2 Client ║
║ Max. Int. Disable Time: 500 us ║
║ Link Beat: Enabled ║
║ Transceiver Type: Auto select ║
║ I/O Synchronous Read: Not Capable ║
║ Plug-and-Play: Capable ║
║ Full Duplex: Not Capable ║
HWiNFO v6.2.6
█████████████████████████████Memory Information█████████████████████████████
║ Row Size Type ECC Speed Module Manufacturer and Type ║
HWiNFO v6.2.6
██████████████████████████████BIOS Information██████████████████████████████
║ Segment Size BIOS Extensions ║
║ C000h 32K ║
║ BIOS Message: REV CK-1 ║
║ Flash BIOS: <Skipped> ║
║ BIOS32 services: Not Present ║
║ Plug-and-Play support: Not Present ║
║ APM support: Not Present ║
║ ACPI support: Not Present ║
HWiNFO v6.2.6
█████████████████████████████Video Information██████████████████████████████
║ Video Chipset: OAK OTI-087 ║
║ Additional 3D Chipset: WEITEK POWER P9000 ║
║ Video Card: Diamond Viper VLB ║
║ Video Memory Size: 256 KBytes of DRAM ║
║ Video Card Bus: VLB ║
║ Video RAMDAC: BrookTree Bt485 TrueColor ║
║ Video BIOS Manufacturer: Diamond ║
║ Video BIOS Version: 3.13 ║
║ VESA Support: Not Present ║
HWiNFO v6.2.6
█████████████████████████████Drive Information██████████████████████████████
║ Controller Device Connected ║
║ IDE ──┬─ Primary ─────┬─ Master E-IDE Device ║
║ │ └─ Slave E-IDE Device ║
║ ├─ Secondary ───┬─ Master <Empty> ║
║ │ └─ Slave <Empty> ║
║ ├─ Tertiary ────┬─ Master <Empty> ║
║ └─ Quaternary ──┬─ Master <Empty> ║
║ └─ Slave <Empty> ║
║ SCSI Disk device ║
HWiNFO v6.2.6
███████████████████████IDE Drive Physical Information███████████████████████
║ Fixed Disk Controller: Enhanced IDE (ATA-4) ║
║ Fixed Disk Capacity: 2,014 MBytes (2,111,864,832) Bytes ║
║ Fixed Disk Geometry: Bytes/Sector: N/A, Bytes/Track: N/A ║
║ - Logical: Cylinders: 4,092, Heads: 16, Sectors/Track: 63 ║
║ - Current: Cylinders: 4,092, Heads: 16, Sectors/Track: 63 ║
║ Cache Buffer Size: 128 KBytes ║
║ Sectors per Interrupt: Total: 0, Active: 32 ║
║ Controller type: Not Specified ║
║ Disk Model: ST32110A ║
║ Firmware Revision: 3.11 ║
║ Serial Number: XV083188 ║
║ Native Command Queuing: Not Present ║
║ Disk Type: [√ Fixed] [x Removable] [√ Magnetical] ║
║ Disk Features Present: [√ DMA] [√ LBA] [√ IORDY] [√ IORDY disableable]║
║ Max. PIO Transfer Mode: PIO: 4 ║
║ DMA Transfer Modes: SW: - (-), MW: 2 (2), Ultra: 2 (2) ║
║ Transfer Rates [MB/s]: DMA: 16.7, PIO+IORDY: 16.7, PIO-IORDY: 8.3 ║
║ S.M.A.R.T. Feature: Present, Status: Enabled ║
║ Security Mode: Not Present ║
║ Removable Media: Not Present ║
║ Power Management: Present, Status: Enabled ║
║ Advanced Power Management:Not Present ║
║ PACKET Interface: Not Present ║
║ Write Cache: Present, Status: Enabled ║
║ Look-ahead: Present, Status: Enabled ║
║ Host Protected Area: Not Present ║
HWiNFO v6.2.6
║ Fixed Disk Controller: Enhanced IDE ║
║ Fixed Disk Geometry: Bytes/Sector: 600, Bytes/Track: 57,600 ║
║ Sectors per Interrupt: Total: 0, Active: 0 ║
║ Controller type: Dual Ported, Multiple Sector Buffer, Read Cache║
║ Disk Model: WDC AC22100H ║
║ Firmware Revision: 10.07H11 ║
║ Serial Number: WD-WT3611071991 ║
║ DMA Transfer Modes: SW: - (-), MW: 2 (2), Ultra: - (-) ║
║ Transfer Rates [MB/s]: DMA: 16.7, PIO+IORDY: 16.7, PIO-IORDY: 12.5 ║
║ S.M.A.R.T. Feature: Not Present ║
║ Power Management: Not Present ║
║ Write Cache: Not Present ║
║ Look-ahead: Not Present ║
HWiNFO v6.2.6
║ Cylinders: 974 ║
║ Heads: 255 ║
║ Sectors: 63 ║
║ Capacity: 7,640 MBytes ║
HWiNFO v6.2.6
║ Cylinders: 994 ║
║ Heads: 16 ║
║ Sectors: 63 ║
║ Capacity: 489 MBytes ║
HWiNFO v6.2.6
██████████████████████████Peripherals Information███████████████████████████
║ Floppy Drive(s): 1.2 MB 5¼", 1.44 MB 3½" ║
║ PCMCIA Adapter: Not Present ║
║ Sound Card: ESS ES1868 AudioDrive ║
║ Serial Port (COM1) UART: 16550A/AF/AFN/C/CF with FIFO ║
║ Serial Port (COM2) UART: 16550A/AF/AFN/C/CF with FIFO ║
║ Serial Port (COM3) N/A ║
║ Serial Port (COM4) N/A ║
║ Parallel Port (LPT1): 4-bit port (SPP) + ECP ║
║ Parallel Port (LPT2): N/A ║
║ Parallel Port (LPT3): N/A ║
║ Super IO Chip: SMC FDC37C666GT ║
║ Keyboard Controller: N/A ║
HWiNFO v6.2.6
██████████████████████████Serial Port Information███████████████████████████
║ Modem: Not Present ║
║ PnP Device: Present ║
║ Device ID: Genius Easy Mouse ║
║ Serial Number: ║
║ Device Class: MOUSE ║
║ Driver ID: PNP0F0C ║
HWiNFO v6.2.6
║ PnP Device: Not Present ║
HWiNFO v6.2.6
███████████████████████████Parallel Port Devices████████████████████████████
║ Hardware Key: No Hardware Keys Found ║
HWiNFO v6.2.6
██████████████████████████████Test CPU Errata███████████████████████████████
║ 32-bit Multiply: √ OK (80386) ║
║ POPAD Bug: √ OK (80386) ║
║ INSB Bug: √ OK (80386) ║
║ STOSB Bug: √ OK (80386) ║
║ MOVSB Bug: √ OK (80386) ║
║ BSWAP √ OK (80486) ║
║ FDIV Bug: <Skipped> (Pentium) ║
║ FIST Bug (Dan-0411): <Skipped> (Pentium Pro) ║
║ AMD-K6 (DRx) Bug: <Skipped> (AMD-K6) ║
HWiNFO v6.2.6
███████████████████████████████IRQ Assignment███████████████████████████████
║ IRQ Source Status Device ║
║ 0 USED System Timer ║
║ 1 USED Keyboard ║
║ 2 USED Slave 8259 Interrupt Controller ║
║ 3 USED COM2 ║
║ 4 USED COM1 ║
║ 5 PnP/ISA USED 3Com 3C509B EtherLink III ║
║ 6 USED Floppy Disk ║
║ 7 USED LPT1 ║
║ 8 USED Real-Time Clock ║
║ 9 USED Rerouted IRQ2 ║
║ 10 FREE <seems to be free> ║
║ 11 FREE <seems to be free> ║
║ 12 FREE <seems to be free> ║
║ 13 USED Coprocessor ║
║ 14 USED Primary IDE Channel ║
║ 15 FREE Secondary IDE Channel ║
HWiNFO v6.2.6
███████████████████████████████DMA Assignment███████████████████████████████
║ DMA Source Status Device ║
║ 0 FREE <seems to be free> ║
║ 1 FREE <seems to be free> ║
║ 2 USED Floppy Disk ║
║ 3 FREE <seems to be free> ║
║ 4 USED Cascade ║
║ 5 FREE <seems to be free> ║
║ 6 FREE <seems to be free> ║
║ 7 FREE <seems to be free> ║
Reply 924 of 938, by Mumak
Hmm, looks like the OAK chip was properly detected.
Can you try to disable the "Check Video RAMDAC" option in settings if that wil lhelp?
Reply 925 of 938, by CkRtech
Same result.
By the way - rebooting results in a black screen. I have to cold boot to get everything back.
Reply 926 of 938, by Mumak
Well, I guess I will have to get such a card and run tests...
The only alternate way would be to create a special HWiNFO version which would require a key press prior to each VGA chip test (HWiNFO displays at the bottom of screen which chip is tested) so you could capture the moment when it goes wrong..
Reply 927 of 938, by CkRtech
I'll do whatever I can to help.
Reply 928 of 938, by PC@LIVE
Hello, I recently worked on a couple of 486 ISAs, and I wanted to try your program HWINFO 626, I loaded it into a bootable CF with DOS 5, and then I transferred it to the disk of one of the two PCs, but when I try the HWINFO16 version, it works but there is less info, if instead I run HWINFO, the PC crashes on the CPU Reset screen [Method 1], this only happens for the Mainboard info, while everything else works, unfortunately I am forced to turn it off, in order to continue, I tried to create a file, but it's only a few bytes.
Maybe if you have suggestions I'll try again, the motherboard is an AT Industrial PINE PT-2068.1 with Intel i486SX25 at 33 MHz.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 929 of 938, by Mumak
PC@LIVE wrote on 2025-11-20, 15:32:
You can disable the CPU Reset Method 1 option in Configuration.
Reply 930 of 938, by PC@LIVE
Mumak wrote on 2025-11-20, 16:46:
Ok Thank you very much, now it works, I memorized the setting and created the files, if you need them I attach them here.
It currently does not recognize the motherboard, which would be a PINE PT-2068.1, which is the same as the MB457 present on TRW.
These days I will try other 486 cards, eventually if you are interested, I can try it and create the files.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 931 of 938, by Mumak
Sure, I'm interested in any reports.
Reply 932 of 938, by PC@LIVE
Here are the files extracted from the MB PINE, they're inside the zip file.
I'm adding the TRW link to show the board, and the main BIOS screen.
I'll need to upgrade the CPU later; currently, I have an i486SX25, but I've been running it at 33 MHz.
https://theretroweb.com/motherboards/s/powertech-mb457
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 933 of 938, by Mumak
Thank you. I will add detection of this mainboard and chipset.
Reply 934 of 938, by PC@LIVE
Hi, yes, no problem. If you're interested, I have the files from a QDI Advance10T with a P3S-1266, and other Slot1 PCs, from which I can extract information.
However, on the P3S-1266, the program works fine, but on the PINE 486 iSX25, it seems like it didn't detect the sound card, even though there are currently no drivers, and I haven't been able to verify whether it works.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 935 of 938, by PC@LIVE
So, I booted up a PIII 500 Slot 1, the motherboard is an OLIDATA OLI-BX, basically the same as the ASUS P2B, and I created the files I'm attaching.
If you'd prefer, I can collect some of them, rather than posting them one at a time. I'll try booting up a few more PCs in the next few days and post more files.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 936 of 938, by Mumak
PC@LIVE wrote on 2025-11-22, 15:14:
Thank you. It's OK to upload them one by one. And btw, the older ones (pre-PCI era) are most interesting because detection of such systems is much tougher.
Reply 937 of 938, by PC@LIVE
Hi, today I ran your program on a PC that I just finished exhuming, but version 6.26 doesn't show the motherboard model, I also tried version 3.05, and that one doesn't recognize the MB either, so I created the report files, but I'll be able to send them to you in a few days, because I'm trying other PCs, and now I can't.
I put some pictures, I don't know if maybe you need them, to start the corrections that will be present in the Ver. XX of your program.
I wanted to ask you if maybe you could put the Benchmark that was present on the Ver 3.05, at least for me it would be interesting to be able to compare the values, between the various PCs that I have in my collection.
I forgot, the motherboard is an equivalent to a PCCHIPS M725, Slot1 format AT, if you need to know more, you can find a lot of info on TRW, including various BIOS and the manual.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 938 of 938, by Mumak
I will add them mainboard when you provide the report+DBG files.
Sorry, there are no plans for adding a benchmark.
