Reply 920 of 1165, by PC@LIVE
- Oldbie
I have some 486 waiting to be repaired, one was bought 30 years ago, it only worked for a couple of days, and went to service a couple of times, without them having to solve the problem (freeza shortly after starting up), I kept it, and several years ago, I tried to turn it back on.
Honestly, I don't know if the motherboard returned from the assistance is the same one I had sent, that is, if they changed my motherboard with another (?).
Doing the boot tests, I tried the CPU in another PC, and it was broken, putting the one working, I saw the first BIOS screen on video, and then it crashed, every subsequent attempt showed nothing more.
I update the current configuration, instead of the Cyrix DX2-80 (5V) mounted on an intermediate socket, I tried other CPUs, with an AMD DX2-66 I saw the BIOS screen on the video, then an Intel DX-33 and finally an SX-25.
The RAMs are 30 PIN, four of 1 MB each (NEC 2+1 chip), but in this card it is also possible to use a 72 PIN RAM, or both types.
On the paper manual, there are various combinations, in the 30 PIN ones, there are some strange 512 KB and 2 MB modules, but it could be a translation error (at least I think), and all the jumpers are set correctly.
The motherboard is still almost like new, there is only a slight dust, observing it I notice a trace in the battery area, oxidized green, I will have to investigate to understand where it goes, I see that it passes under the BIOS chip, maybe that could be the problem (?).
Unfortunately it will have to be scratched, to make the COPPER underneath appear, fortunately the warranty has expired, since 01/1996!
If I find an interruption, the problem of not starting could be solved, for the original problem, I don't think it was caused by the Cyrix CPU, which maybe started to fail, because with the AMD it happened again ️
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
