Reply 9220 of 57731, by brostenen
foey wrote:
Received a ATI Rage Fury MAXX today.
They just look so nice. Really awesomme to look at.
Reply 9221 of 57731, by foey
Yeah they do look great. I've just installed it and dam those fans are whiny!
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 9222 of 57731, by CelGen
Skyscraper wrote:
More stuff from the bundle with random stuff I bought.
I need help identifying this one, IBM video card.
What a curious board. Two different types of memory expansion, SLT chips and headers for a paddleboard.
I think it's MCAmafia who has a great little utility you can put on a bootable floppy and it compares the card ID to a list of known MCA cards to tell you what the board is.
Edited: It's "IDMCA" and I've attached a bootable floppy image of the utility.
Reply 9223 of 57731, by HighTreason
And you can bet I am going to open it... Damn, that is going to feel good!
I am hoping to replace the ISA 3C509 in my U5S system because it is a bit on the slow side. Only problem I can see is that it may not like the fast timings I currently have but they make very little difference in real-world performance when lowered a little. Otherwise it doesn't really matter because it was not very expensive and will be nice to keep on the shelf until I do find a place to use it.
EDIT: Oh, almost forgot. I grabbed this for my Athlon XP system too;
Yeah, now that is a real RAID controller.
Reply 9224 of 57731, by Skyscraper
CelGen wrote:
What a curious board. Two different types of memory expansion, SLT chips and headers for a paddleboard. I think it's MCAmafia wh […]
Great, I will download that utility when I get home 😀
I do not have a MCA system at the moment but that is just a question of time, I used to have an IBM 55SX but I think I will get something more fancy than that.
Reply 9225 of 57731, by sf78
seob wrote:
That case looks a lot like my fujitsu case.
Yes, it's the exact same mold they used with the 486/Pentium. Finnish assembled machines were branded "MikroMikko (MicroMike? 🤣) and those sold or assembled outside Finland were either ICL or Fujitsu. I also like the case and the quality of parts and the amount of integrated ports. Too bad the compatiblity isn't that great compared to your average clone. I've had many problems trying to configure different sound cards and getting some hardware tests to run correctly. These machines were cleary not ment to be experimented with.
Reply 9226 of 57731, by Indrid Cold
Finally I've received this great dock for my IBM ThinkPad 370C - this gem is DOCK II 3546 (www.thinkwiki.org/wiki/ThinkPad_Dock_II_(3546)) and literally transforms this 486 laptop in a desktop computer with ISA slots, IDE, SCSI, speakers, etc. - in great conditions and fully functional, with internal PSU, among other things:
caricare immagini
invia immagini
invia immagini
hostare immagini
free image hosting
host image
Reply 9227 of 57731, by vmunix
Skyscraper wrote:
I made an useful investment :) […]
I made an useful investment 😀
I have two working dual Pentium Pro boards which should support 1MB cache CPUs, One ATX "AIR P6NDI" and one AT "Tyan S1662 Titan Pro". I also have a finished NT4 system with a PR440FX ATX board but it officially only supports 512KB cache CPUs which it already runs overclocked at 3.5x70=245MHz. Trying to overclock 1MB CPUs to 233 or 245 MHz on the Intel board would be risky and at 200 or 210 MHz I dont think they would be an upgrade at all.
As a coincidence I found an auction with 4 Pentium Pro 200 MHz 1MB cache CPUs. 2+2=4...
I've got a Tyan S1662 and also a couple of P6 200/1M though I already used this board with the 200/512 and had problems with the PSU connectors to the mobo, basically the plastic melted so I ended up soldering the cables with most current (the red ones I think +12) directly into the board, never dare to try the 1M ones they are heaters and don't think the heatsink+coolers for the 512K can handle it.
If you ever try it please share how you did it.
Trailing edge computing.
Reply 9228 of 57731, by Bullmecha
CPUs -
6 - 2.8 P4
1 - 3.0 P4
1 - 3.2 P4
Hard drives -
5 - 80GB satas
1- 40GB sata
RAM - (3200, 4200, 5300, 6400)
DDR2- 256 x 2
DDR2- 512 x 13
DDR2 - 1GB x 6
Full Dell Optiplex GX520
Full HP RP5700
All for $40 bucks !!! Luv it
Just a guy with a bad tinkering habit.
i5 6600k Main Rig
too many to list old school rigs
Reply 9229 of 57731, by ODwilly
Pair of these for free. One will replace a dead Geforce card in a dual core machine and the other one will end up as a spare for something else. Edit: X1550 256mb
Reply 9230 of 57731, by Skyscraper
Perhaps your VRM modules couuld not handle the load and therefore the amount of current on the 5V rail skyrocketed? The PSU could also be the issue as you need ~30A on the 5V rail, and if the PSU cant handle it the voltage will drop and the current (and heat) will rise.
I think even if the 1MB CPUs takes ~50W each and the VRM modules are not very effective the AT connector should be able to handle the load without melting, at least if the case has good airflow. My VRM modules look beefy enough even if I doubt they officially support the 1MB CPUs and although my most powerful AT PSU only is specced at 300W with 25A on the 5V rail thats a worst case scenario where one of the two PSU modules has failed so it should be able to provide up to 50A as long as both modules are working.
Its perhaps best I keep the fire extinguisher nearby just in case.
Reply 9231 of 57731, by alexanrs
Thanks to my recently acquired TL866CS I could finally diagnose my 486's non-working external cache. I nailed it down to a busted 32kx8 SRAM chip used as TAG RAM, so I bought replacements! Managed to gind those nationally and for very little money, which is even better! And yes, I already installed one in my 486 and now the DX2-66 is a happy camper with external cache =)
The attachment TAG.jpg is no longer available
Reply 9232 of 57731, by pojo
Bought this cool SBC untested. If it works, maybe I could have a 486 inside my slot1 machine 😁
Reply 9233 of 57731, by ynari
niiiiice. Even better, it's ISA, so maybe you could have a 486 inside a 286 😉
I wonder if it's for Intel PC systems, at all, though - what model is it?
Reply 9234 of 57731, by HighTreason
SBCs don't really work that way. They are effectively going to try to run the ISA BUS in reverse. Did often wonder if I could use risers to make a couple of small backplanes at the bottom of a full-size case running a µATX or ITX mobo though.
So yeah, the system generally expects to have a backplane with no logic on it. Most of the time anyway, there are differing designs.
Have wanted to get an industrial machine for a while, probably will next year. I did enjoy working with them back when I had to do that, especially how it was possible to upgrade a 286 to an Intel P4 Celeron by replacing a card. I believe an Atom SBC is still available for ISA backplanes from one company but I do not remember which right now.
Reply 9235 of 57731, by pojo
Aha, maybe not the best idea to plug it into an active ISA slot then. Perhaps the board can be powered using a standard PSU?
I do have an Amiga 3000 with passive ISA backplane slots but I don't think it's going to fit in there.
Reply 9236 of 57731, by easy_john
Yes. Both mobos can't start in this case.
Yes.
Yes, you can install SBC mobo in Amiga 2000-4000, but you can't control this PC from Amiga (you need a brigeboard for this), but this works like two separate machine in one case.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 9237 of 57731, by dirkmirk
How much was that If you dont mind me asking, looks like an interesting device but the price is always tooooooo high.
Reply 9238 of 57731, by easy_john
486 sbc you can find about 100$ on ebay, if you have time to wait.
Most important thing, to have a vlb/pci video card is soldered on same board, or you faced with very slow external isa video. It's not critical for router or modem pool (for what usually sbc used), but important for old-gaming.
Reply 9239 of 57731, by brostenen
Bought one of these for my SCSI drives, in order to have a 15000rpm 9.4gb RAID-1 setup in a future build that I am thinking of.
http://www.ebay.com/itm/SCA-80-Female-to-68-P … =item235698762a
The build will be based on an P2B-S or an P2B-DS, some sort of Pentium-III and 512mb Ram.
It's all in the planning, based on what hardware I have left to build with.
