Reply 9240 of 58690, by Lukeno94
Put a new screen in my Powerbook G4 - that now works fine. Ironic that the old girl came apart again with no troubles, yet my crappy Acer Aspire V5-531 was a nightmare. Pro tip: do NOT buy an Acer "thin and light" laptop. The build quality is atrocious, and so is the design.
Reply 9241 of 58690, by torindkflt
Found a WD FileCard 30 for a good price on eBay, I'm gonna use it in my AT&T PC 6300 to replace the Seagate I used to have in there (which unfortunately self-destructed). This'll also allow me to put the second floppy drive back in the system since it doesn't use a bay.
The attachment IMG_20151007_191600518.jpg is no longer available
The attachment IMG_20151007_191608457.jpg is no longer available
The attachment IMG_20151007_191624064.jpg is no longer available
BTW, does anyone happen to know the CHS parameters for this drive? I need to low-level format it, but without this info I won't be able to properly configure it. I know it's actually a Tandon drive, but looking up that model number brings up a 21MB drive, not 30MB.
Reply 9242 of 58690, by pojo
dirkmirk wrote:
How much was that If you dont mind me asking, looks like an interesting device but the price is always tooooooo high.
About 10 EUR.
Too bad it did not came with passive ISA backplane 🙁
Reply 9243 of 58690, by tayyare
http://maben.homeip.net/static/S100/disk/spec … ive%20Specs.pdf
4 heads, 615 cylinders and 17 sectors. And yes, it is a 20MB MFM drive. The funny thing is, according to what I find, WD30IFC-1 should have a 30MB RLL drive on it. I think HDD is replaced. Please be aware of the fact that, a RLL controller is able to format a MFM HDD with 50% more capacity than advertised, (26 sectors instead of 17 if I remember correctly), but formatting a MFM drive with RLL encoding is NOT GOOD for your data reliability.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9244 of 58690, by easy_john
There is no such thing as a RLL drives.
All MFM drives can be formatted as MFM, or as RLL.
All you can talk about - that some drives is officially labelled to support write data with RLL encoding, but physically it's absolutely same device.
P.S. may be the only early MFM was buided with not good surface, and may have higher error rate, if RLL encoding is used. But for most MFM drives there is no affect.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 9245 of 58690, by tayyare
My mistake in wording. You are correct. But the thing I wanted to say is still same. The drives are physically same, but some (early, not RLL certified(?) ones) are sometimes not good enough to have 26 sectors instead of 17, and that results in data corruption (had that problem in my ST something 40MB MFM drives in the past, when the wise guy (which is me) formatted them with RLL encoding to 60MB).
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9246 of 58690, by torindkflt
Does reformatting an MFM drive as RLL change the number of cylinders? I thought doing so only changed the number of sectors per cylinder. I ask because FDISK 3.3 reports 939 cylinders, even after low-level formatting (It never asked me for the CHS parameters, so I presume it just reused the old parameters). I partitioned and formatted the drive under 3.3, then booted into 6.22 and ran ScanDisk with surface scan, no errors found. FDISK 6.22 reports a capacity of 30MB. I then installed the AT&T DOS 3.3, and it seems to be working perfectly fine. Only time will tell though if this remains so.
Obviously I cannot be 100% certain since this is flimsy reasoning, but the professional manner in which the power cables were ziptied together leads me to believe this drive was likely the original (They're not ziptied in the photos because I removed the drive from the bracket for power testing before installation). Perhaps this is one of the few MFM drives that can tolerate RLL formatting with no issues?
Reply 9247 of 58690, by Artex
Got some REAL goodies today folks! 😎 😎 😎
Finally, a Gravis UltraSound ACE Rev 1.0 ISA (Boxed) (1994). Now if I could just find a boxed PNP or Extreme version....
How about a New-Old-Stock Yamaha MU10 (Hello!Music! MAC Packaging) (NOS) (1996) ?!?! Basically the module version of the well-known DB50XG daughterboard.
Reply 9248 of 58690, by Skyscraper
I just won this very nice SUPERMICRO S2DG2 dual Slot-2 board. 😀
The price ended up ~11 Euro + rather expensive 20 euro shipping from the UK but I think 31 euro total still is reasonable if not cheap.
I have never owned a Slot-2 system so its a new platform for me. 😀
The sellers image of the SUPERMICRO S2DG2
The attachment SUPERMICRO S2DG2.JPG is no longer available
Reply 9249 of 58690, by Skyscraper
I bought a 286 two weeks ago because I wanted the case for a 486 build as I reused exactly the same model of case for a 486 build close to 21 years ago.
The 286 was made by a company named Moretec and had all its original parts. How can I be sure that its the original parts? Look at this image!
Matching numbers! 😀
The attachment Moretech_286_12_original_parts.JPG is no longer available
I will keep all the parts so I can restore the 286 just as it was, It needed the battery replaced anyhow so I dont feel bad for dismanteling it.
Some people wanted to know who made the case, it has lots of Moretec stickers on it and the PSU is also branded Moretec, I doubt Moretec did either the case or PSU though.
Reply 9250 of 58690, by ODwilly
Bought one of these: http://www.ebay.com/itm/252006128840?_trksid= … K%3AMEBIDX%3AIT anybody have any idea if it will support a Pentium D? In any case this looks like a great platform to build an overkill 9x box around or a solid XP/7 machine if you so desire.
Reply 9251 of 58690, by Gamecollector
No.
Pentium 4/Celeron D only.
Reply 9252 of 58690, by brostenen
That ACE is a nice purchase... Keyword = The RAM upgraded. 😜
Reply 9253 of 58690, by ODwilly
Gamecollector wrote:
No.
Oh well have a 3.0ghz Cedarmill chip to throw in it at least, one of the nice 65watt ones. $15 shipped can not really complain that is for sure! Have a 5950 Ultra to pair it with
Reply 9255 of 58690, by Artex
keropi wrote:
[goodies listed]
damn man, you get all the shiny stuff! 🤣 🤣 🤣
Hahah! You KNOW this! 😀
Reply 9256 of 58690, by retrofanatic
Lol...Artex is always a hard act to follow.
Great finds Artex!!
Here is my sad addition (next to your finds) for this week to my retro collection.
A simple 386 motherboard with AMD 386-SXL 25 CPU and 4MB RAM . Missing the co-processor 😢 , but no big deal, will still make a nice retro system for WC and old sierra games one day.
Paid $10 for it as part of a complete desktop system.
The attachment 386-1.jpg is no longer available
The attachment 386-2.jpg is no longer available
Reply 9257 of 58690, by carlostex
@Artex
Nice finds! I also have a boxed Gravis Ultrasound ACE. I also have a MAX, but i would really like a boxed classic.
The compact MU modules are awesome.
Try playing some XG midis with it and you'll see it really shining. It's already good in games but XG stuff is just beautiful.
Reply 9258 of 58690, by Artex
Great finds Artex!!
Thanks! I don't always post retro stuff, but when I do, I make it count! 😎 Go big or go home right?!
carlostex wrote:
@Artex Try playing some XG midis with it and you'll see it really shining.
I'm very excited to hear some actual XG stuff - I love the GM output of the DB50XG but never actually tried any XG material!
Reply 9259 of 58690, by boxpressed
72 CPUs/FPUs arrived today. Mostly Intel 386 & 486. About $100 for all of them.
Pics in this thread: Rare CPUs
