Reply 9260 of 57733, by carlostex
Artex wrote:
I'm very excited to hear some actual XG stuff - I love the GM output of the DB50XG but never actually tried any XG material!
This post has a file attachment with some XG stuff from Mediatrix:
YMF-71x cards (OPL3SAx) software alternative
Also try Fields of Gold by Sting:
The attachment Fields_Of_Gold.zip is no longer available
Reply 9261 of 57733, by Artex
Thanks carlostex!
Reply 9262 of 57733, by sliderider
Lukeno94 wrote:
Put a new screen in my Powerbook G4 - that now works fine. Ironic that the old girl came apart again with no troubles, yet my crappy Acer Aspire V5-531 was a nightmare. Pro tip: do NOT buy an Acer "thin and light" laptop. The build quality is atrocious, and so is the design.
Which Powerbook G4 do you have and where did you get the screen from? I have two of the last Powerbook G4 model, the 1.64 ghz with the high resolution screen, and one of them has a cracked LCD that I have been using with an external monitor.
Reply 9263 of 57733, by retrofanatic
Some new additions to what little storage I have left...
The attachment rps20151008_210219.jpg is no longer available
The attachment rps20151008_210238.jpg is no longer available
The attachment rps20151008_210300.jpg is no longer available
The attachment rps20151008_210316.jpg is no longer available
Reply 9264 of 57733, by Lukeno94
An A1095 - 15" screen, 1.33 GHz CPU. Got the screen on eBay as a complete unit for £20. There's one on eBay UK right now for £26, but that's the same seller I got mine from - they'll accept slightly lower offers (mine was at a slightly lower starting price). There's a complete A1138 higher-res unit for £50.
Reply 9265 of 57733, by computergeek92
Just bought my first ever 386 motherboard!!! 😁
It's a the fastest ever 386Sx clocked at 40MHz and has 4MB of ram!!
It has a Cyclone chipset, 4 ISA, and the cpu is rated as being equivalent to a theoretical 386DX 30MHz! Making it an excellent high mid range gaming motherboard! I'm adding a Trident 9000C 512K vga card to it and hopefully an old Soundblaster Pro when I get the chance. I have an AT case all ready, plus 5.25 and 3.5 floppy drives. Now all I need is a larger hard drive. Tell me fellas, what were available hard drive sizes for 1992-1993 that would match this 386SX in it's level of budget? (Not a high end drive, and I want it to be 100% period correct)
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 9266 of 57733, by Robin4
for a harddisk, look around for an 200 - 540MB one..
More period correct would be around 80 - 200MB
Reply 9267 of 57733, by computergeek92
Cool! I was reading that the average 386DX 33 came with an 80MB...
Reply 9268 of 57733, by computergeek92
Does anybody recognize my new 386 board and knows any info about it? Thanks.
Reply 9269 of 57733, by nforce4max
Bought some Powerbook G4s over the past week.
12 inch 866mhz with 10.2.8 for $25 shipped, needed body work and new bat also had to order ram so total was around $40
12 inch 1.5ghz with 10.5, for almost $50 shipped but as usual seller said nothing about the keyboard nor the battery being dead.
15 inch (aluminum) but don't know the speed with missing hard drive but otherwise in Very nice almost like new condition except for a few scratches. $39 shipped
Got a spare 1.67ghz 15 inch board on hand if needed.
Expensive for their age but they won't get much cheaper these days.
Also scored a Thinkpad 701c and some Avertech 5100 for $27 shipped the other week. The butterfly needs lcd work sadly, either bad connection on the cable or bad cable or worse board or screen needs to be replaced. Boots into 3.1 on the original os install.
Reply 9270 of 57733, by Caluser2000
Don't worry about period correctness mate. I put a 240meg hdd to supplement my 286/16s original 40meg drive in 1993. Bigger the better. You'll fill a smaller drives space up fairly smartly. I run a 4 gig drive in my '89 386DX25 with DDO.
Obviously a later SX board limited to 16megs of addressable ram and 4 ISA slots. 486DX/SX series were being marketed with gusto then. If I was in your situation I'd go for a 1meg video card at least to give yourself a bit of future proofing in case you want to expand the system somewhat or decide to use Win 3.x/wfw 3.11. Nics can be useful as well. They weren't common back then in the consumer enviroment but are a worth while addition all the same.
I found an older joy stick in one of the local thrift shops today.
Reply 9271 of 57733, by computergeek92
Just found 2 Trident video cards, a 9000C and 9000i-1 plus a multi I/O card to go with my new 386SX board! I'll save one of the VGA cards for my 486SX. I got it all from the same seller, so it should arrive together the same time. Wooohooo!
Reply 9272 of 57733, by PhilsComputerLab
You will have lots of fun with that 386 😀
A real 386 is always something special to me. My very first PC was a DX-33. I even hunted down an old magazine which had the advertisement for it 🤣
Also, curious about your screenshot process. I can see Paint and some OS or skin I don't recognise.
YouTube, Facebook, Website
Reply 9273 of 57733, by computergeek92
Nice to see you again philscomputerlab! 😁 BTW, I used the print screen key in Zorin Core Linux 9. (The GUI resembles Windows 7 or XP) I've completely switched to Linux since last month, but I still use legacy Windows offline. I have yet to find a good Linux image editor that will let me save in compatible formats for this site. The Wine emulated version of Paint is pretty limited. It only saves in BMP. So at least ordinary print screen in Zorin saves images in PNG, which works. haha, i'm too lazy right now to find good alternatives for Windows software just yet...
Reply 9274 of 57733, by easy_john
Featured graph editor for linux is GIMP. But for most usual task - it's overkill.
I'm using digiKam - it's photo management software, that has an easy and lightweight editor for usual tasks - rotate, crop, resize, sharp.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 9276 of 57733, by PeterLI
New addition for the IBM PS/ValuePoint collection: 433DX/Si.
Reply 9277 of 57733, by Skyscraper
Here is a picture of the VGA card I got with the 286 computer I bought as I needed the case for a 486 project.
The systems motherboard posts but it seems battery corrosion has eaten up a couple of traces having to do with the keyboard as it wont respond to keystrokes and shows keyboard error at post.
Genoa systems Super VGA model 6400 (1990).
The attachment Genoa_systems_SVGA_model6400.JPG is no longer available
Review of the Genoa systems Super VGA model 6400
The attachment Genoa Systems SuperVGA 6400.jpg is no longer available
Reply 9278 of 57733, by 386SX
Edit: not a sound card.
Reply 9279 of 57733, by King_Corduroy
🤣 You use Zorin OS? How is it? I'm also a linux user but personally I use fedora. 😁
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
