Reply 940 of 1126, by PC@LIVE
- Oldbie
Unbelievable what happened a little while ago!!!
Lately, I've been working on some 486, including an AT Industrial UMC chipset, searching on TRW is the same as a Power Tech MB457, well to make it short, lately (years ago) I had tried to start it with an Intel 486SX25 CPU, unfortunately nothing happened, no post code on the ISA-PCI card (here obviously you can only use ISA), try various RAM both 30 and 72 PIN, an Intel 486DX33 CPU (which I was looking for but still can't find), and try and try again and nothing!
Today I finished cleaning the cache chips of the 486 PCI (Terminator), and I wanted to change CPU to temporarily install the DX33 instead of the AMD DX4-100, I managed to find all the 486 I have, except the DX33, maybe it's in a motherboard, I'll check.
So having a free space on the bench, I take the MB457 one, and I place it ready for a further startup attempt, but first I have to recover an ISA VGA and a RAM, I connect the AT keyboard and ATX-AT adapter (for the power supply), I use an old WD card for the VGA, and for the RAM I take a 70 ns 72 PIN with 8 chips, I thought it was 8 MB, in reality it is 4 MB, it doesn't matter anyway.
So I try to start it's incredible what happened: Codes appear on the post card, and you hear a beep, on the video I have the BIOS screen!!!
But why all this surprise ???
The last time it worked, was 30 years ago, then nothing!
Now I'll try to make some additions, like a controller card for disks, but maybe also the 30 PIN RAM, to have a total of 8 MB, then if it works maybe I'll try with a 72 PIN RAM of 8 or 16 MB, replacing the 4 MB one.
One last problem I'm having is that I'm almost without VGA ISA, unfortunately I've been looking for a Trident (8900) for many years, but the requests are too high, I was looking for this model because it's the same as the one I had in the early 90s, then of course it won't be identical but for me it would be fine in a PC like that, even if originally I had a Cyrix DX2-80 that was quite fast, this SX-25 I don't know but I think it's at the same level as a slightly faster 386DX, even if it has an 8 KB L1 cache, which at least does something, since the Motherboard does not have L2 cache on board.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
