Reply 980 of 1241, by zyzzle
Did you say that you've gotten 0.9.9c working in SBEMU / VSBHDA? I've tried all manner of settings for both programs, and also in FDSETUP.EXE, and always get a "Failed to detect music card -1" and the same "Failed to detect digital sound card -1" message, and FDOOM refuses to run; the only way to get it running is to disable both music and sound. Always the -1 error message, and in the FDOOM.CFG, the music and digital sound cards are set to -1, even though I chose Sound Blaster for both music and digital effects in the setup program. Is there a specific manual way to specify the "Sound Blaster" card in the .cfg program? -1 usually means "autodetect" or, confusingly "not detected".
Has anyone gotten any version of FASTDOOM working in bare metal DOS with SBEMU? Report how you got it working, please.
Also, confusingly, the VESA modes run perfectly, even though my reported VESA memory is 32 Mb, but always crash (hard freeze the system) only when *exiting* FASTDOOM. I can get around this by getting the program to error out, for example in reporting a missing / incompatible demo file, using one from Doom2.wad for instance while using the main Doom v. 1.9 wad instread. The text mode .exes don't crash upon exit, however.
