Reply 9900 of 60009, by luckybob
brostenen wrote:
It's (the dual P3 board) got an ATI Rage something onboard for what I can make out.
The colour does not really seem to fit into Asus P3-era, as far as I remember.
I could be wrong though.
It's true 99% of Asus boards are/were that special yellow. That said, they did make some boards that were the basic green. My XG-DLS is green.
Reply 9901 of 60009, by kanecvr
brostenen wrote:
kanecvr wrote:
Got a PowerColor EvilKing Voodoo 4 4500 today: […]
Sweet.... Finally you got one of the higher performing Voodoo's. Congrat's
It's a little faster then a Voodoo 3 but nothing out of the ordinary... Still glad I bought it - my first Voodoo 4. Payed 50 euro for it too... 🙁 Now if I could only find a voodoo 5 5500 AGP for about 100-110 euro shipped...
Reply 9902 of 60009, by PCBONEZ
luckybob wrote:
Oldbitcollector wrote:
A friend of mine rescued this system and said that I needed to pick it up before he scrapped it this morning. I've not had a chance to power it up, but it appears to be a very well built server of some sort.
It's a dual CPU (Pentium III / 933) with two SCSI 18GB hard drives. Can't seem to find any specs or model number silkscreened on the motherboard. Those two longer slots having me scratching my head.
IIRC, Windows 98 won't see the two CPUs, I already have an XP machine, so I'm thinking either Windows NT or Windows 2000. Any recommendations?
It's most likely an Asus CUS-DLS. The longer slots are for pci-x cards. They offer higher bandwidth than standard pci. Use them for gigabit ethernet and u320 scsi.
Great score! !
I think ASUS CUR-DLS. (vice CUS-DLS)
Yes, the presence of PCI-X slots implies it has multiple independent PCI buses on the board. The CUR-DLS manual shows two.
So long as you actually utilize both buses it has a huge PCI bandwidth compared to a typical consumer board with one PCI bus.
As long as the voltage is correct most PCI cards work in PCI-X slots so you don't actually have to have PCI-X cards to use both buses.
Note:
The whole PCI-X bus will run as fast as the slowest card in it.
IOW, if you put both a 66MHz and a 33MHZ card in one PCI-X bus they will both work but both will run at 33MHz.
Reply 9903 of 60009, by Gamecollector
There is 1 big advantage of Voodoo4 cards between Voodoo3 - big textures support. It's used in ogl games mostly (through 3dfxvgl.dll), the best example is MDK 2.
Reply 9904 of 60009, by PhilsComputerLab
And 32 bit colour support of course 😀
The 4500 is basically what many would have liked the V3 to be. But it was too little too late. I hardly see it used in retro builds, likely because it's not cheap and easy to find, the V3 on the other hand is quite cheap and easy to find.
Reply 9905 of 60009, by mwdmeyer
I love the Voodoo 4, really good image quality. But yes the Geforce 2 MX was a better purchase back in the day.
Reply 9906 of 60009, by kanecvr
I'll put the card in my Xp 2600+ rig. The KT333 board in it has a Universal AGP slot and supports 3.3V cards - it's currently running a Voodoo 3 3500TV.
Reply 9907 of 60009, by RacoonRider
Got an almost complete 286 set for free:
- a motherboard with onboard FDD/IDE controller (!)
- a 286-10 CPU and a 287-10 NPU, both from AMD
- a 8-bit I/O controller
- a 8-bit Gemini Tech G2 videocard
- a nice and clean L-shaped PSU
(off topic) I also bought several sets of plastic feet in a furniture shop. I generally intended to use them for two builds only: the one that has cracked feet that leave white dust everywhere they step and the other one that lacks them completely. However, they turned out so practical when moving rigs that now I'm going to slowly convert the rest of my fleet!
Before/after:
Reply 9908 of 60009, by Artex
Great stuff! Cute pup too. 😀
Reply 9909 of 60009, by kithylin
Yes the puppy is cute, I like the puppy more than the hardware. I'm kinda partial though we have a lovable huggable husky here.
Reply 9910 of 60009, by badmojo
Yes love the hound but could we please see more of the case than its feet please?!
Nice find!
Reply 9911 of 60009, by brostenen
RacoonRider:
That's some beautifull hardware you got there. Love it. 😜
Reply 9912 of 60009, by RacoonRider
Nice find!
I've shown these somewhere around here several times already, need to make a thread on it, yet there is so much to write about and so little time 😀 "Без паники" is "Don't panic" from one great book by Douglas Adams 😀
Reply 9913 of 60009, by Artex
Wow.. Just - wow. Awesome!
Reply 9914 of 60009, by kanecvr
That machine has great looking insides!
Reply 9915 of 60009, by dexter311
That little screw on the AWE32 is a great idea, might have to steal that and replace the shitty piece of cardboard I have supporting my CT3900!
Reply 9916 of 60009, by brassicGamer
RacoonRider wrote:
Got an almost complete 286 set for free: - a motherboard with onboard FDD/IDE controller (!) - a 286-10 CPU and a 287-10 NPU, b […]
I hope you have some SIPPs! Is that 640k in DRAM already then?
Reply 9917 of 60009, by RacoonRider
Thanks! Artex, I must admit, given your impossible collection of retro goodies, getting this feedback from you feels kinda like an achievement 😀
Feel free to use it, I stole the idea from someone as well. These are common nut-screws found in COM, VGA, LPT ports, etc. screwed together by two.
Yes, I think it has 640K DIPP memory. I've got another 286 with 1Mb DIPP memory and a faulty 386 to steal SIMM slots from.
But I don't really know what to do with extra memory on a 286. Actually, I have no idea what a 286 can do that XT and 386 can't 😀
Reply 9918 of 60009, by brassicGamer
That's a really good point. The 386 was obviously a significant step up from the 286, and we saw the first boards to use CPU cache, faster RAM speeds, etc - performance became the thing and the gap between the bus and the CPU began to widen. But, from what I understand, the 286 presented an almost 100% performance increase over the 8088 because the address and data buses weren't multiplexed (which, in theory, should double performance immediately anyway). Also the introduction of protected mode paved the way for more complex software such as multi-tasking OSes, although it wasn't really exploited in the 286 era. Some would say the 286 was just a stepping stone but, whichever way you look at it, the 386 wouldn't have happened without it.
Reply 9919 of 60009, by Ariakos
I got this HP Brio BA D75xx unit for 10€. Apparently it has some 486 CPU (DX2/66? It's under a heatsink), and SiS motherboard with 3 PCI & 1 ISA slot. It has integrated graphics and a sound chip (Crystal CS4280-CM) on board. Unit also came with couple of PCI cards (probably a modem by Telewell and some weird Lite-On card with only LINE output). Too bad about only one ISA slot, I was hoping for at least two. Oh well, the mini sized case will make for a decent project...
