First post, by JF_Sebastian
Hey folks,
today I want to show you my final system configuration as well as benchmark results. Maybe it could be helpful for others who like the P55T2P4.
HW-SETUP:
Asus P/I-P55T2P4 Rev. 3.10 (3.2V OK) - FSB @83MHz
AMD-K6-III/450AFX @500MHz/2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
OS:
Windows 98 SE
CPU SETTING:
The multiplier is set to 2 and is perceived as 6.
Clock: 6x83MhZ = 498MHz
Default Vcore at 2.2V, but overclocked the CPU only runs stable at 2.4V.
107.42 KiB
135.39 KiB
BIOS SETTINGS:
BIOS Version: #207 BETA 2
193.06 KiB
Some sources said that a disabled external cache in combination with the CPU's integrated L2 cache would be faster. But I have noticed slightly less performance.
214.95 KiB
DRAM runs stable with lowest timings and activated <DRAM Speculative Leadoff>
202.13 KiB
I also have problems with the USB 1.1 header that is activated during the boot process. When USB devices are connected to the header, the system resets after the bios boot. However, when the devices are connected after booting Windows 98, everything works fine. I found out that the problems are caused by the AMD K6-III. If P166MMX is used instead, the system does not reset.
.......to be continued
Boot Up or Shut Up!
________________________
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
Reply 1 of 9, by JF_Sebastian
CPU FEATURE SETTINGS:
Thanks to the BIOS, every function is automatically activated and configured. Just <write ordering> is manual set to fastest.
51.17 KiB
MEASUREMENTS:
Atto benchmark:
HDD PIO-4 performance with CF-Card Transcend 300x 2GB and IDE-adapter DELOCK 91620
73.59 KiB
Landmark system speed:
186.05 KiB
Speed Sys:
154.32 KiB
Boot Up or Shut Up!
Reply 2 of 9, by JF_Sebastian
BENCHMARKS:
Diamond Monster II runs with latest official reference driver.
Overclocked with the tweaking plugin "V2-OC" from "fastvoodoo driver v4.6" which works with reference driver without any flaws.
3dmark 99:
Diamond Monster II 8MB @default clock 90MHz
295.47 KiB
Diamond Monster II 8MB @oc clock 105MHz
300.99 KiB
Comparison:
134.86 KiB
DOSBench:
154.59 KiB
Quake 1.06 DOS:
133.18 KiB
Boot Up or Shut Up!
Reply 3 of 9, by JF_Sebastian
...last but not least, some great games.
Unreal v2.26:
149.05 KiB
GL-Quake v1.09 / GL v0.95:
140.41 KiB
Quake III Arena v1.11:
138.65 KiB
Thanks for all your help and support. If anyone has any questions, just ask. And if anyone also has benchmark results, feel free to compare and discuss them here 😉
Boot Up or Shut Up!
Reply 4 of 9, by BitWrangler
2 out of 6 graphs work for me, the ones not starting at zero are as useful as false advertising.
Reply 5 of 9, by JF_Sebastian
BitWrangler wrote on 2024-04-24, 19:59:
I don't understand what you mean. Which charts are not useful? Do you mean the benchmark results or the gaming timedemo results or the BIOS settings? I thought it would be helpful and interesting, but if not, please criticize in more detail. 🙁
Boot Up or Shut Up!
Reply 6 of 9, by BitWrangler
4 of your graphs do not start at zero, that makes them junk and misleading.
Reply 7 of 9, by JF_Sebastian
BitWrangler wrote on 2024-04-24, 20:20:
Unfortunately, I cannot understand your criticism. Whether they start at zero or not makes no difference to the result! The only reason why the diagrams do not start at zero is that the difference is better displayed. But ok 😉
Boot Up or Shut Up!
Reply 8 of 9, by BitWrangler
So if I estimated your IQ at 121 and mine at 131, you would be totally happy if I drew the bar chart like this?
IQ comparison of JWS (top) and BW (below)
120 - - - - - - 130
Reply 9 of 9, by JF_Sebastian
BitWrangler wrote on 2024-04-24, 20:34:
So if I estimated your IQ at 121 and mine at 131, you would be totally happy if I drew the bar chart like this? […]
120 - - - - - - 130
Nice example. I have correct it.
Boot Up or Shut Up!
