Help with X-Com TFTD on XP
Reply 21 of 33, by MiniMax
Rank Moderator
Moderator
I don't think it matters, but why did you write:
mrray wrote:
Z:\>mount E E:\ -t cdrom
when I told you to write:
Z:\>mount D E:\ -t cdrom
_________________
Reply 22 of 33, by mrray
i tried that and it only gets as far as this (the step before the cd speed test)
    20.49 KiB
    305 downloads
Reply 26 of 33, by mrray
here is the dxdiag report for my machine, it is not a brillinatly fast macine as it is a laptop but its quite good as laptops go. (i think)
    DxDiag.txt
    47.38 KiB
    783 downloads
Reply 27 of 33, by wd
Rank DOSBox Author
DOSBox Author
You either installed it outside dosbox, or in dosbox with e: mounted as
cdrom so you have to stick to the mount e e:\ .
Use setsound or whatever configures the sound there and
choose sb16 irq7 dma1
Reply 28 of 33, by MiniMax
Rank Moderator
Moderator
According to your screensnap the game expects the SoundBlaster card to use IRQ 5 and you have configured DOSBox to emulate IRQ 7.
Either change your DOSBox configuration, or re-configure the game to match DOSBox.
P.S: If your press ALT + PrintScreen when you grab a screenshot, you only get the current window, not the whole desktop. Saves you from cropping the picture manually.
_________________
Reply 30 of 33, by MiniMax
Rank Moderator
Moderator
Try my 60 seconds guide, and re-install the game. Once re-installed keep the drive mounts exactly the same as when you installed the game.
_________________
Reply 33 of 33, by MiniMax
Rank Moderator
Moderator
You can try adding the -ioctl option to the CD mount:
Z:\>mount D E:\ -t cdrom -ioctl
_________________
