Reply 20 of 39, by darry
AppleSauce wrote on 2024-07-05, 11:44:
I found it already , thanks though for mentioning it even being there , i had no idea it had to be manually enabled in the bios.
1.96 MiB
Huzaah we have success! 😁
Cool!
For best performance, make sur you use the one with write caching enabled (the last one posted in that thread, with wc in the zip filename).
Reply 21 of 39, by darry
AppleSauce wrote on 2024-07-05, 12:25:
I do have another issue now though , XTIDE wont detect my pioneer dvd drives.
That is a known limitation. It is mentioned in the thread. You should still be able to access the optical drive in Windows 9x and also in DOS (with proper CDROM drivers loaded), but you will not be able to boot from it.
Reply 22 of 39, by AppleSauce
darry wrote on 2024-07-05, 12:29:
The drives won't appear in WIn98 , do I manually need to reinstall the drivers?
Reply 23 of 39, by darry
AppleSauce wrote on 2024-07-05, 12:32:
Does anything have an exclamation mark in device manager ?
Is MS-DOS compatibility mode being used in Windows for disk access ? If so, plug the boot drive into the second IDE controller and the optical drives on the primary. Also make sure nothing got accidentally disconnected.
Is
Reply 25 of 39, by AppleSauce
darry wrote on 2024-07-05, 12:47:
Does anything have an exclamation mark in device manager ? […]
Is
Where is the option for compatibility mode?
I haven't installed anything dos related but its possible I missed switching it off.
Reply 26 of 39, by ux-3
I do own an ASUS P3B-F 1.04 and use an Intel 80 GB Sata SSD on primary IDE using an adapter.
Retro PC warning: The things you own end up owning you.
Reply 28 of 39, by ux-3
AppleSauce wrote on 2024-07-06, 10:04:
ux-3 wrote on 2024-07-06, 09:45:
I do own an ASUS P3B-F 1.04 and use an Intel 80 GB Sata SSD on primary IDE using an adaptor.
Which adapter is it?
I used a dual direction IDE-sata one. The type with two sata connectors, one for each direction. And I used Ghost2003 to clone the HDD to SSD.
If I were to redo it, I would partition the SSD first on a new system (alignment), then move the partitions using ghost.
Reply 29 of 39, by AppleSauce
ux-3 wrote on 2024-07-06, 10:24:
Right , btw do you know what chip it uses?
Or could you link me to the place you got it from?
I guess could partition it and try using ghost.
Reply 30 of 39, by ux-3
AppleSauce wrote on 2024-07-06, 10:46:
I bought those some 10(?) years ago. I could look up the chip when I am home again.
Reply 31 of 39, by AppleSauce
ux-3 wrote on 2024-07-06, 11:18:
Thanks a bunch , it would really help.
Reply 32 of 39, by darry
AppleSauce wrote on 2024-07-06, 12:06:
The fact that it at least works well enough to boot with XTIDE BIOS suggests that the issue is not the adapter or its converter chip, but with the P3B-F board's onboard BIOS not being happy with the SSD.
I seem to recall there being LBA related issues with some newer drives that were small enough to be expected to work (below 127GB) but still failed to due to BIOS issues unless one used a controller card with its own more robust BIOS or XTIDE.
I might be misremembering that last point.
Reply 33 of 39, by douglar
darry wrote on 2024-07-06, 14:13:
The fact that it at least works well enough to boot with XTIDE BIOS suggests that the issue is not the adapter or its converter […]
Some Bios don’t gracefully handle storage devices that report more than 65535 cylinders.
https://www.vogonswiki.com/index.php/Storage# … age_Limitations
Reply 34 of 39, by AppleSauce
How did he get a 80gig intel ssd to work on his p3b-f then? Unless he had a different model ssd?
Reply 35 of 39, by darry
AppleSauce wrote on 2024-07-07, 03:21:
It could be some subtle difference between models snd LBA implementation, I would guess.
I can't test anything right as I'm in the middle of multi-city-wide power failure and the machine I would use currently has no PSU anyway.
If you don't mind a bit of trial and error, I suggest
a) plugging the SSD to the secondary controller, the optical drive to the primary, as master. Leave only the primary controller on auto in ththe BIOS. Then boot into Windows with XTIDE and see if optical drive is there
Reply 36 of 39, by ux-3
I have board revision 1.04. I may have a different bios. I do have a different SSD (silver, iirc Postville?)
I likely have a different adapter. I partitioned into =<32GB.
And I transfered the installed system with Ghost2003. I didn't try to install on SSD.
Lots of options...
Reply 37 of 39, by AppleSauce
darry wrote on 2024-07-07, 05:10:
It could be some subtle difference between models snd LBA implementation, I would guess. […]
Sorry to hear about the power failure , we have em sometimes here in Australia and it sucks.
I might try that drive swap a bit later on.
Reply 38 of 39, by AppleSauce
ux-3 wrote on 2024-07-07, 07:18:
I have board revision 1.04. I may have a different bios. I do have a different SSD (silver, iirc Postville?) I likely have a dif […]
Lots of options...
My boards a 1.04 as well , I hunted down a 80 gig intel X25 , I'm guessing that's the postville code name you mentioned , which seems to be a pretty early SSD circa 2008 so , ill see if that has better luck than my S3510 from 2015 ish?
Reply 39 of 39, by AppleSauce
Hokay , I am reporting back , the X25 SSD came in today and it worked out of the box , booted lightning fast.
Only thing I did different was image the drive without formatting using winimage , so either that helped or it just straight up doesn't like the other 80 gig intel ssd drive I used.
