First post, by Themario
Is there a way to force the VGA section of dosbox to act as a papergray screen?
It would make the purple cga screens easier on the eyes.
Thanks
Reply 4 of 17, by DosFreak
or if your monitor supports it adjust the color....
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 17, by themario
I'm using an Nvidia geoforce4 MX440 (i'm not sure how to run this one in greyscale...been looking for 3 days) and my monitor cannot go to B&W.....: )
I don't know about a TSR, but maybe a mod on the VGA driver for dosbox to add a grayscale option....
If you have any other suggestions I appreciate the help....
Reply 6 of 17, by `Moe`
Back in the dos days, I used a little program called (surprisingly) int10.com (or .exe), it was able to change various settings of the video card, including the monochrome flag. I seem to have lost it, and google wasn't helpful either, but perhaps you have more ideas how to find it.
Reply 7 of 17, by eL_PuSHeR
Rank Moderator
Moderator
Taken from Ralph Brown's Interrupt list:
INT 10 - VIDEO - PERFORM GRAY-SCALE SUMMING (VGA/MCGA) AX = 101Bh BX = starting palette register CX = number of registers to […]
AX = 101Bh
CX = number of registers to convert
Return: nothing
Desc: convert the RGB values of one or more palette registers such that the resulting values are grays with the same intensities as the original colors
And, better still.
INT 10 - VIDEO - ALTERNATE FUNCTION SELECT (VGA, MCGA) - GRAY-SCALE SUMMING AH = 12h BL = 33h AL = new state 00h enable […]
AH = 12h
BL = 33h
AL = new state
00h enable gray scale summing
01h disable gray scale summing
Return: AL = 12h if function supported
Desc: specify whether or not colors should be converted to gray scale when palette or color registers are loaded
Here you go. I tested it under NTVDM and it works. Compiled with Windows DEBUG.
    GRAY.ZIP
    123 Bytes
    182 downloads
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 9 of 17, by eL_PuSHeR
Rank Moderator
Moderator
Simply unpack it and run it before any application. I haven't tested it under DOSBox, but it WORKS under WinXP NTVDM (NT Virtual DOS Machine - The emulated dos boxes).
Intel i7 5960X
8 GB DDR4 (2100)
Reply 12 of 17, by Themario
Works nicely using Win9x in a Dos window, thanks!!
Now If I can just get it to work in dosbox so the programs slow down enough to be more enjoyable...: )
Qbix: does that mean that dosbox will either be able to run gray.com or include this fonctionality in an upcoming version???
Thanks again guys for the help.....
Reply 13 of 17, by eL_PuSHeR
Rank Moderator
Moderator
What Qbix is probably meaning is that the VGA function I used in gray.com isn't implemented yet into DOSBox and, thus, running gray.com under DOSBox DOES JUST NOTHING.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 14 of 17, by DosFreak
If this functionality is something you want without having to run a 3rd party utilitiy then requires it in the Wish List thread....
Reply 16 of 17, by HunterZ
Would it be possible to make a TSR that hooks the interrupt and grayscales the palette whenever it gets changed? I suppose that would slow things down and create lots of artifacts though, plus it'd probably be easier to just modify DOSBox at the source level to output in grayscale.
Reply 17 of 17, by vasyl
That's all fine but I will side with the original poster and go even further... I want settings for real greyscale monitor, amber, and green. The last one musthave at least one second of afterglow. VGA paperwhite (which was odd beast, not exactly greyscale) would be piece of cake after that. At this point, as they say on Slashdot, /me ducks...
