First post, by DosFreak
Output=Opengl
Shader=HDRish.pss modified
Graphics Card=X800 5.8 drivers.
Scaler=normal2x
(Shaders can only be applied via Opengl and OpenGLNB runs like crap so don't blame me for the crappy quality)
On most DOS games it pretty much has the same effect as increasing the gamma.....
Monkey Island 1 with HDR modified to 25%
Doom 1 with HDR modified to 20%
    31.14 KiB
    30.51 KiB
    37.03 KiB
    37.8 KiB
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 13, by ih8registrations
The nohdr shots look dull/dark, like the brightness is turned down too much by default since in the hdr shots shows graphic detail revealed once brightend, like the paneled walls of the building in the monkey island shots.
Reply 4 of 13, by Reckless
Interesting to see an HDR filter available but it doesn't get past the fact that HDR needs to be worked into the game from design. Personally I don't see the big deal with it - Far Cry was OK but pretty much killed anything below super PC, and the HL 'level?' Lost Coast demo videos didn't look 'that' impressive - given the massive spec PC you need to run it!
Reply 5 of 13, by GreatBarrier86
I disagee. You don't need a "massive" pc. I have a P4 2.8 with 512 ram and a radeon 9700 and it worked extremely well.
IBM ThinkPad X40
1.2Ghz with 2MB L2 cache
1.0GB DDR2 SDRAM
Intel 852/855GME Graphics Media Accelerator with 64MB
12'' LCD Screen
SoundMax Integrated Audio
Peas Pobie!
Reply 7 of 13, by Reckless
Err.... quote from Anandtech:
The golden rule of Half Life 2 is this – regardless of what sort of graphics card you have (within reason), the game will run well, but at varying levels of image quality
Your 9700 card is a DX8 part and if so configured it's not giving you the 'whole' experience 🤐 Mind you some of the differences between the DX8 and 9 paths are very small but pennies make pounds as they say 😀
Edit: Here's the DX8 vs 9 screenshots - http://www.anandtech.com/showdoc.aspx?i=2281&p=2 Just take a look at that water 😀
Reply 8 of 13, by HunterZ
Yeah, I'm tempted to get a newer ATI or nVidia card to replace my ATI Radeon 9800 Pro 256MB AGP, but I'll probably just live with it for a few months and then build a whole new computer early next year.
Reply 9 of 13, by gulikoza
anything above r9500 is dx9...
Real HDR could not be achieved by simple (or complex for that matter) shader, as it requires some 3D math of the objects and lights...something most dos games don't even do themselves (remember that anything before quake1 is not a real 3d engine)
Reply 10 of 13, by HunterZ
What about Descent? Did they just take the tricks used in Wolf3D/Doom to an extreme? I've always wondered about that, as it came out before Quake (from what I remember).
Reply 11 of 13, by GreatBarrier86
I just ran the lost coast on my 9700, which the checker confirms is a DX9 card, and i got around 40fps with HDR set to Full. Actually full was the recommended setting.
IBM ThinkPad X40
1.0GB DDR2 SDRAM
12'' LCD Screen
Peas Pobie!
Reply 13 of 13, by gulikoza
Riiight, Descent is probably a "real" 3d engine. I don't know how I forgot about it, must have read too much bragging by Id 🤣. Since the source is available and there are already opengl ports I imagine HDR descent would be possible if somebody is up to the task 😁
