VSBHDASF: Fork of VSBHDA with Soundfont support
Reply 160 of 166, by DoutorHouse
Just a quick update to report that the new VSBHDA 1.9 also doesn't seem to work with my HP t5720. Like the 1.8 version it seems to recognize everything but I get no sound at all on any games. Like before, the 1.7 version does work... Could someone maybe share their working AUTOEXEC.BAT and CONFIG.SYS files as I'm probably setting up VSBHDA wrong?
Reply 161 of 166, by AaronS
Haven't tested 1.9 yet, will try it later, but works with 1.8. I only have Cute Mouse in my autoexec file which is unrelated, my config:
DEVICE=C:\JEMMEX.EXE
DOS=HIGH,UMB
FILES=40
start.bat:
@echo off
C:\VSBHDA\jload -q C:\VSBHDA\qpiemu.dll
C:\VSBHDA\jload -q C:\VSBHDA\jhdpmi.dll
lh C:\VSBHDA\hdpmi32i -x2 -r
set blaster=A220 I5 D1 H5 T6 /P330
C:\VSBHDA\vsbhda.exe
C:\VSBHDA\uninst
C:\VSBHDA\vsbhda.exe /VOL9 /SF:C:\VSBHDA\CT8MGM.SF2
Reply 162 of 166, by DoutorHouse
AaronS wrote on 2026-06-13, 15:28:
Haven't tested 1.9 yet, will try it later, but works with 1.8. I only have Cute Mouse in my autoexec file which is unrelated, my […]
DOS=HIGH,UMB
FILES=40
start.bat:
@echo off
C:\VSBHDA\uninst
Thanks! It seems very similar to my own settings. What really puzzles me is that the 1.7 version works but both 1.8 and 1.9 no longer do, using the exact same settings... Maybe it's my SIS7012...
Reply 163 of 166, by AaronS
For me I have to load JEMMEX with NOE820 when using my Audigy card, onboard it works without it.
DEVICE=C:\JEMMEX.EXE NOE820
You probably won't need it though but give it a go?
Slightly unelated but does VSBHDA work alongside a MT32-pi? I checked out some videos on it and it seems like a great device, very accurate MT32 and can use General Midi soundfonts. The latter works with VSBHDA of course but if a game requires slowing the CPU down it will struggle or crash, using an external device and just using VSBHDA for SoundBlaster SFX would get around this I think? I talked about this in the CPUSPD thread.
AaronS wrote on 2026-05-12, 22:35:
I'm now trying to use this with VSBHDA (loading a soundfont for General Midi port 330) however the game locks up. I'm assuming this is because it's using additional CPU as well as RAM to run this in the background which, if I just use Soundblaster for both SFX and music, it works fine. In the following case I'm testing Star Wars Dark Forces (this game is 99.9% fine but is speed sensitive on the ice level where, you can basically get stuck and move really slowly), anyway if I load only VSBHDA with only SoundBlaster SFX and music, it works fine and you can see I am able to move around on the ice @ 250Mhz, but then if I load a soundfont the game crashes even going up to 400mhz (too fast at this point as I get stuck). Not sure if you have tried cpuspd with VSBHDA soundfonts but I guess we can't have it all on these newer platforms 🤣 but I wanted to ask anyway
https://youtu.be/3l83_FHNOO4
For the record you can easily get passed this part of the game with a fast CPU you just need to get the ice cleats as soon as possible, but its a good level to test.
Anyone have such a setup?
Reply 165 of 166, by DarthSun
The latest version works well with the Chinese MR9S board(also). HDA detection, Roland 26MB SF.
I took some photos, even though my monitor was a bit dusty.
The attachment VSBHDASF_MR9S.jpg is no longer available
The attachment MR9S.jpg is no longer available
SBEmu is fine, too.
The attachment SBEmu_MR9S.jpg is no longer available
I use them on many different machines, and they work perfectly on all of them.
They are brilliant—big thanks to the developers!
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 166 of 166, by AaronS
Testing the latest pre release that adds support for X-Fi and it works amazingly over lineout, not able to get anything out of the S/PDIF out though, not sure if this is known about or I need a certain flag?
https://youtu.be/ordwmX4qnTE
UPDATE: I was using my Audigy 2 ZS until this point and, on my motherboard I needed to use the NOE820 flag with Jemmex otherwise I'd get terrible buzzing when starting VSBHDA (I assume the driver was crashing immediately), that is no longer needed with the X-Fi (I retested the Audigy with this new pre release but it still needs NOE820).
