First post, by meme
I'm running GNU/Linux (Athlon 2500+). I've installed DOSBox ver. 0.63 and Qemu 0.70. For fun, I made full win98 installation with qemu. Qemu has incomplete sound support, but in DOSBox sounds work ok.
Now, when I run win98 with qemu, and try to play DOS games, they run just smooth! A lot faster than with DOSBox! Qemu running win98 is in speed comparable to a pentium 2, even in DOS mode.
Qemu version I'm running is full GPL'd code, so I thought you could look at it, if you could use something of it.
DOSBox in general is fine, I ran Cannonfodder and Assault Trooper just ok, but Liero and Tapan Kaikki run slow compared to Qemu.
Qemu homepage:
[url]http://fabrice.bellard.free.fr/qemu/[/url]
Reply 1 of 3, by DosFreak
Been meaning to compare qemu to DosBox as far as speed goes but really haven't gotten into it.
Are you using KQemu too?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 3, by meme
I'm using only the GPL'd part, 'cause proprietary kernel modules do only irritate and are hard to get working (proprietary nvidia drivers are missing too.)
So, I run full in userspace. Machine is Athlon 2500+, 512KiB L2, 256MiB RAM, 266MHz FSB.
Comparing DOSBox and Qemu is meaningful, because both do full hardware emulation.
