First post, by chinny22
It's the ram with flashy LED's
I've recently purchased some but having trouble finding software to control the patten.
Originally you would have used the "Ballistix MOD Utility" 2 editions of the software exist one for DDR3 and another for DDR4
I managed to find a download for version 1.3.3 which I believe is the last DDR3 edition? However the software does not recognise my memory.
Crucial have removed the software as a vulnerability was found saying just use other RGB software, but thats for the DDR4 RAM.
DDR3 isnt RGB, it's just 2 different coloured LED's mounted on the memory heatsink.
Reply 1 of 12, by red-ray
I have 8 x BLT4G3D1869DT2TXRG in my Intel Xeon E5-2696 v2 (Ivy Bridge-EP) and 1.3.3 can only see/control 4 of them.
You should also be aware MOD fails to use the Global\Access_SMBUS.HTP.Method lock so running other programs that access the SMBus at the same time as MOD will likely cause issues.
What system are you using and what is the part number of your DIMMs?
If you post the SIV [SPD] + [SMB Bus] panels I may be able to comment further
file.php?id=228000
Reply 2 of 12, by chinny22
For you does MOD only see the memory in slots 1,2,5,6 even if you swap the DIMM's
or does it always follow the same 4 DIMM's even if you move to another slot?
I have 3x BL25664TN1608.16FF (1600MHz 8-8-8-24) in an Asus P6T (x58 chipset)
OS is a clean install of Win7
Requested siv reports below
Reply 3 of 12, by red-ray
chinny22 wrote on 2025-10-05, 01:41:
For you does MOD only see the memory in slots 1,2,5,6 even if you swap the DIMM's or does it always follow the same 4 DIMM's even if you move to another slot?
The issue with my Intel Xeon E5-2696 v2 (Ivy Bridge-EP) system is that it has 4 x IMC SMBus and MOD only sees the DIMMs on the one @ [ 255 - 15 - 0], see attached.
As I recall at the time I raised the issue with Crucial and they failed to fix it along with failing to start using the Global\Access_SMBUS.HTP.Method lock.
file.php?id=228062
Reply 4 of 12, by red-ray
file.php?id=228046
chinny22 wrote on 2025-10-04, 07:29:
From the MOD screen shot you posted it does, I guess you mean it can't control the LEDs.
I also have an X58 system with Crucial Ballistix Tracer DDR3 RAM and MOD can control the LEDs of all 6 DIMMs, what happens when you select Lights?
file.php?id=228063
My DIMMs also report their temperature and from the [SPD] screen I can see yours don't as MTS is not set, further on [SMB Bus] there is nothing @ [ 0_18 ] to [ 0_1D ].
file.php?id=228066
file.php?id=228048
file.php?id=228064
I just spotted the INUSE Wait 811 of 811 ms, this does not normally happen (it should be 0 of 811 ms) and is almost certainly trigged by MOD failing to correctly process the INUSE Wait hardware semaphore.
Also notice how my part numbers are totally different and end RG or OB, further the XMP voltage is 1.50 rather than 1.65 Volts.
file.php?id=228065
file.php?id=228049
My guess is that any LEDs on your DIMMs can't be controlled by any software, where does it specify they can be?
Reply 5 of 12, by chinny22
Your response from Crucial doesn't surprise me if their "fix" for the software vulnerability was simply take down the software and tell everyone to go use something else!
I've since tried the RAM and software in a HP Z230 (C226 chipset) Same thing in MOD . Selecting temperature or lights will give an error about not finding any supported memory.
It's possible these are not controllable, I'm basing my knowledge on 15 year old reviews. But is strange as 1 DIMM is set to a different pattern to the rest and seems like the LEDs at the bottom on all 3 have been turned off where every article I read says they are included. All 3 have identical part numbers but naturally I've no history on the RAM
I'm guessing not much can be done though and we have hit a brick wall?
Reply 6 of 12, by red-ray
chinny22 wrote on 2025-10-05, 08:17:
How on earth can you say "I'm basing my knowledge on 15 year old reviews" without including a link to them?
Reply 7 of 12, by chinny22
Because I didn't save the links and doubt they are relevant anyway.
I researched the product to the best of my ability, then check availability. No point saving links to reviews that I've extracted the information I think I need from.
I'm not saying they MUST be configurable because the articles are 15 years old. I'm saying the articles will be out of date, so part numbers if any in the article will be incomplete as new modules or kits are released with new part numbers wont be reflected in the article.
As with anything second hand, a little bit of luck is always involved.
Reply 8 of 12, by PC Hoarder Patrol
Far as I recall, the original Ballistix Tracer DDR3 (red\green activity + blue ground effect LEDs) weren't programmable...that function of the MOD utility only appeared with the later Ballistix Smart Tracer DDR3. Sort of confirmed as there's no mention of it on the spec sheet
The attachment Technische-Details.pdf is no longer available
I'm still using v1.0.0.2 with my Ballistix Tactical DDR3 (4GB BLT4G3D1869DT1TX0.16FM 1866MHz) and it seems to read all the DIMMs OK
Reply 9 of 12, by red-ray
PC Hoarder Patrol wrote on 2025-10-05, 11:53:
I am trying to understand what all the different types are, do your DIMMs also report their temperature and/or can MOD control the LEDs? Please will you post the SIV [SPD] + [SMB Bus] screen shots.
I have also been looking into why MOD 1.3.3 fails to report all 8 DIMMs on my Intel Xeon E5-2696 v2 (Ivy Bridge-EP) system and found:
file.php?id=228158
Clearly it's only using [ 255 - 15 - 0 ] when it should also be using [ 255 - 29 - 0 ], further it's using the PCIEBAR address to decide which buses to read. This is incorrect and it should be using the internal bus numbers BOX buses. With a single socket it half works and with a quad socket system it's hopeless. I also just spotted for the modelId == 12032u (Haswell-E) there is no default: and I expect there should be.
file.php?id=228166
Next I wondered how MOD would do with other than Crucial DIMMs, it reported their SPD, but not their temperature. I was amused that 2.00 GB ECC DIMMs are reported as 2.25 GB.
file.php?id=228167
I wondered if it would report the temperature for Micron DIMMs, as my HP DL580 Gen8 has 96 x 36JSF2G72PZ-1G9N1 Micron DIMMs I tried to run MOD, it would not even start.
I tried to find a 1.0.0.2 download but failed, please will you post it.
Reply 10 of 12, by PC Hoarder Patrol
red-ray wrote on 2025-10-06, 07:26:
I am trying to understand what all the different types are, do your DIMMs also report their temperature and/or can MOD control t […]
file.php?id=228158
file.php?id=228166
file.php?id=228167
You can still find a download of v1.0.0.2 here... https://web.archive.org/web/*/http://www.cruc … listix_Utility* ...and if you're interested v1.2.0.0 here... https://web.archive.org/web/*/http://images.c … llistixUtility*
My own Ballistix DDR3 usage is limited to the standard & low profile / voltage versions of both the SPORT & TACTICAL parts, so no LEDs or temp sensors for any version of the utility to support.
The attachment ballistix.png is no longer available
Reply 11 of 12, by chinny22
Bugger, so bad research on my part. Oh well, thanks for the links to the older versions. they were evading me as well.
Think its worth backing up "just in case" some more come up for a fair price down the track
Reply 12 of 12, by red-ray
PC Hoarder Patrol wrote on 2025-10-07, 23:36:
Thank you, MOD 1.0.0.2 does not even support IMC SMBuses.
file.php?id=228346
Looking again @ MOD 1.3.3.0 I found:
file.php?id=228347
chinny22 wrote on 2025-10-08, 02:13:
Given the if (module.HasTemperatureSensor && module.Spd.PartNumber.StartsWith(... all the DIMMs with controllable LEDs must report their temperature and your DIMMs don't.
I just spotted https://www.ebay.co.uk/itm/235934938414 which contains a single Orange/Blue 8GB module, but I don't think it will work on your x58 system. I have never seen an x58 system with 8GB DIMMs and think the maximum is 4GB.
MOD 1.0.0.2 is not very useful, it only seems to know about two of my six DIMMs
file.php?id=228356
MOD 1.3.3.0 knows about them all
file.php?id=228063
