Reply 240 of 304, by AlexZ
That is a motherboard specific problem. There are vogons members who run 4GB RAM at DDR400 in s939, probably even at 1T, but with ECC memory ( Re: Socket 939 dual core build. Decisions, decisions.... ). Asus K8N-E (s754) also allows max DDR333 with 2x 1GB modules, but it is an AGP board so it doesn't matter, if needed there is a workaround.
On Athlon 64 memory always runs in sync with the CPU. Memory divisor is chosen indirectly and typically not visible in BIOS. The memory setting in BIOS influences the divisor, but CPU frequency multiplier influences it as well. You could get around this problem by increasing base frequency.
2209Mhz CPU, 260Mhz base, 8.5x multiplier, HT 1040 (4x), memory divisor 11 (select DDR333 in BIOS, real clock will be 400) - this is the closest you can get to stock clocks, very mild HT OC - should have no effect. In this way you should be able to run 4x 1GB at DDR400. These settings were identified in Re: Battle of the platforms: socket 754!
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
