First post, by mwiik
I have this Socket 5 board: https://theretroweb.com/motherboards/s/epox-p … onix-ep-p54c-sp
And this ISA I/O controller: https://theretroweb.com/expansioncards/s/long … cs-6624g-rev-w5
I got the floppy working on a Pentium 3 board. The exact same combination of jumper settings, ribbon cable, floppy drive and floppy disk fails on the Socket 5 board. The drive is detected, no errors during POST, but after POST it sounds like three short bursts of a "rattling" noise, like if it's trying to read the disk but fails (bootable DOS disk inserted). Then it goes on to try to boot from IDE, which is the next issue:
BIOS detects CF card, but fails to boot from it (fresh DOS 6.22 install which is working on the P3 system on the integrated controller). No error messages, just a blank screen after POST.
On the P3 system, the BIOS seems to detect the IDE controller (conflict if I don't disable the onboard controller), but fails to detect drives.
I've tried:
All sorts of jumper settings.
Deoxit on the ISA slot and edge connector.
Scoured the BIOS for relevant settings.
Different CF cards and even a known working 2GB IDE hard drive.
Is this an ISA timing issue? Is there something wrong with the board (ISA data lines or something)? Or is this card just not compatible with the board?
The problem is that both the Socket 5 board and the contoller card are new to me, so none of them are known working except the floppy part of the controller. I don't have any other controller cards to test with yet. I'm comfortable with a soldering iron if that's needed, but I just don't know where to begin looking. I wouldn't mind buying another controller if it's a compatibility issue, but I don't want to waste my money if it's not.
If anyone has any insights, I'm all ears!
Reply 1 of 17, by TheMobRules
Have you replaced or modded the RTC (the black ODIN chip)? At this point, the battery is probably dead, and many motherboards that use those types of integrated RTCs are known to behave unpredictably when the battery is dead or close to dead as they are unable to properly persist the BIOS settings, even if you keep the power on.
Reply 2 of 17, by mwiik
TheMobRules wrote on 2026-03-30, 21:32:
Thanks for the reply. It doesn't have the integrated battery/rtc, but a separate battery. Not sure if it's original or modded by a previous owner though, but I think it looks factory. The battery reads 3.1V.
The attachment IMG_4397.jpeg is no longer available
Reply 3 of 17, by dionb
mwiik wrote on 2026-03-30, 19:39:
I have this Socket 5 board: https://theretroweb.com/motherboards/s/epox-p … onix-ep-p54c-sp And this ISA I/O controller: https […]
I've tried:
Have you tried with floppy only, without a HDD or CF?
2GB is possibly too big - you could be hitting a BIOS limit (this is a 1994 board, could be limited to 528MB lacking translation) or the ISA controller might not support LBA.
Reply 4 of 17, by mwiik
dionb wrote on 2026-03-31, 13:38:
Thank you for the reply. No difference with floppy only unfortunately. Even disabling the IDE part with the jumper setting doesn't help. The CF card I've tried with is 1GB, which is the smallest I have available at the moment. Both the CF card and the HDD are detected with the correct size in the BIOS though.
I noticed one thing now in the BIOS. The clock ticks very slowly. One second every 20 seconds on my stopwatch. Also, the year setting resets to 2096 on reboot, but the other date settings stick just fine. Could this be a clue? I don't have access to an oscilloscope to check frequencies of the crystals unfortunately. But it seems like the RTC is faulty somehow, but could that explain the floppy failure?
Reply 5 of 17, by dionb
That OEC12C885 is the RTC. If the battery is outputting 3.1V, measure the input pin (20) on the 12C885. If that's getting 3.1V vs pin 16 (GND), there could be an issue with the CMOS, if it's getting less, there's a bad contact somewhere between the battery and the RTC.
Reply 6 of 17, by jakethompson1
The 2096 thing (usually it's 2094) is a Y2K bug in the BIOS.
Reply 7 of 17, by mwiik
dionb wrote on 2026-03-31, 16:04:
3.11V on the spot. What could the issue be with the CMOS?
Reply 8 of 17, by mwiik
jakethompson1 wrote on 2026-03-31, 16:54:
Thanks, 2094 it is, I misremembered. Then I guess that's nothing to worry about.
Reply 9 of 17, by jmarsh
mwiik wrote on 2026-03-31, 14:55:
DOS does check if the RTC is ticking on startup, so that could explain the hanging...
Also check pin 21, it should (ideally) be pulled high or floating.
Reply 10 of 17, by mwiik
jmarsh wrote on 2026-03-31, 18:21:
That's very interesting! Could the crystal oscillator be bad? I know I have a spare one somewhere since I bought two when I replaced it on another machine, but they are small and my mess is big...
I get 4.7V on pin 21.
Reply 11 of 17, by mwiik
Ok, progress made! I changed the crystal oscillator, which did not help at the time, but later the clock just started working properly again while troubleshooting other issues. So strike that one off the list.
Also, disabling the external cache actually made it boot to DOS from the CF card. But the floppy still doesn't work on the Socket 5 board.
So there are two issues remaining. Cache (which is easy to work around, will fix later), and floppy drive not working (works on another machine with the same controller).
Any ideas on what to test next regarding the floppy drive would be appreciated!
Reply 12 of 17, by rasz_pl
mwiik wrote on 2026-03-31, 18:29:
At first I thought jmarsh meant IDE pin 21, but that would make sense with pin 28.
CF card IDE converters love to pull that high, that will screw with whole computer. I would check if IDE pin 28 isnt somehow permanently wired to CF card/ground or just cut/isolate that pin. Re: "Fixed" 386sx motherboard works but not with 16-bit VGA card
Reply 13 of 17, by jmarsh
rasz_pl wrote on 2026-04-30, 21:31:
I meant pin 21 on the RTC, some boards have it grounded because they assume a DS12887 (without "A" suffix) will be used, which doesn't have pin 21.
Reply 14 of 17, by mwiik
Update:
I replaced the cache SRAM chips, and now it boots with cache enabled as well. The floppy started working when I put a jumper across the turbo pins. Go figure.
Thanks for all the tips and thoughts! This issue has been resolved.
Reply 15 of 17, by BitWrangler
Hmmm, I think there might be something a bit hinky with your clock and clockgen still. Possible issues will flare when more cards added.
Can't see anything obvious from the datasheet
https://theretroweb.com/chip/documentation/sc … b0905274153.pdf
But I'd give a good clean to the clock setting pins and make sure they have tight jumpers on them. Am thinking along the lines that 14.318 Mhz drive strength might be low still.
Nothing I can put my finger on yet, just a kind of "been to a few rodeos and I don't like the look in that bull's eye."
Reply 16 of 17, by mwiik
BitWrangler wrote on 2026-06-02, 14:02:
Hmmm, I think there might be something a bit hinky with your clock and clockgen still. Possible issues will flare when more card […]
I ran the system board tests in Checkit Pro, and it failed the RTC tests. I have ordered a replacement RTC chip since replacing the crystal earlier obviously didn't help.
Do you think this could be a related issue? I agree that there seems to be something hinky, since I'd expect the floppy to work regardless of turbo status.
Reply 17 of 17, by BitWrangler
Yeah I'd wait to try that before anything drastic, it's flakiness in the CMOS, battery and RTC that can cause some really weird problems.
