Any sense buying modern PSU for old hardware?
First post, by Caesum
Hello, I need to replace a PSU in my old computer because I found out (thanks to you!) that it is insufficient for my build. From what I have seen most people recommend buying a PSU from 2000s, but I was wondering if it's possible and if it makes any sense to buy a modern PSU? Or has technology advanced so far that it'd be pointless to try?
My PC is:
AMD Duron 1.4GHz
256MB RAM
NVIDIA RIVA TNT2 M64 / Radeon 9200se (I sometimes switch them)
CMI8738/C3DX Audio Device (unplugged right now)
Gigabyte GA-7ZM
I was told that generally for these specs I'd need a 350/400 WAT PSU with 25A/30A on the 5V line at least.
I've been reading other threads here and it seems modern PSUs are a bit of hit and miss because they rarely have a good 5v line and because the size of PSUs has changed over time. Are there any other things I should consider before buying a modern PSU?
I admit I am hesitant about buying a used PSU because I am not a solderer or anything and I wouldn't be able to fix it by myself or even find out if it's faulty or not.
EDIT: Also does this PSU look good for my needs? https://www.mediaexpert.pl/komputery-i-tablet … -ak-b1-420-420w It has 28A on 5V line
Reply 1 of 215, by PD2JK
I can't tell you anything about the quality of that model power supply, but that's more than enough power for your setup.
Even 25A on the +5V rail should suffice IF from a good quality PSU.
Another option is to get a bit more modern socket A board with +12V VRM's.
has all kinds of stuff
Reply 2 of 215, by gerry
You might look for a quality decent brand i guess. In my experience power supplies are the component most likely to fail, if you treasure that set up (and a top Duron like that is cool!) then maybe look around at well regarded brands. Having said that i've had some no name PSUs that seem to last through any ordeal and keep working! For the most part i am just fine with cheaper PSUs, i accept the risks
Reply 3 of 215, by Caesum
Thank you for the answers. I looked at opinions and it seems AKYGA is not a good brand. Also I am reading that modern PSUs might not be actually okay for old PCs due to uneven charge on 5V line (whatever that means).
Instead I am wondering about buying a used PSU that been "renewed" by a shop. One option I found is a XILENCE POWER ATX 350W sps-xp350. It is used and from 2009 I believe. It seems the brand is generally ok?
Reply 4 of 215, by Mike_
I guess something like RM550x should be fine? RMx series apparently has 25A on 5V line.
Reply 5 of 215, by shevalier
Mike_ wrote on 2026-04-22, 15:49:
It will most likely work.
It’s just a bit of a problem.
It’s specified as
5V 25A
3.3V 25A
5V + 3.3V – but a total of no more than 120 watts.
In other words, something like 5V/12A + 3.3V/18A
In those days, graphics cards and RAM were mainly powered by the 3.3V rail.
In other words, it is inferior to the decent quality 250-watt models of that era.
Photo from eBay
Photo from eBay
It would take a long time and be rather tedious to explain, but if the power supply unit’s specifications mention an ‘A(ctive) PFC’, there’s a 99% chance it won’t be very suitable.
It was at that very moment that the topology and power distribution across the rails changed radically.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 215, by Mike_
shevalier wrote on 2026-04-22, 16:51:
It will most likely work. It’s just a bit of a problem. It’s specified as 5V 25A 3.3V 25A 5V + 3.3V – but a total of no more th […]
It’s specified as
5V 25A
3.3V 25A
Photo from eBay
Photo from eBay
Wouldn't Radeon 9200 SE be new enough to be supplied by 12V rail rather than the low voltage ones? It's from 2003, after all.
Reply 7 of 215, by tehsiggi
Mike_ wrote on 2026-04-22, 18:13:
It’s specified as
5V 25A
3.3V 25A
Photo from eBay
Photo from eBay
Nope, it does only use the 12V as an helper voltage for it's voltage regulators. See here: https://tehsiggi.github.io/agp-power-monitor/
Or more precise, here: https://tehsiggi.github.io/agp-power-monitor/ … s_radeon9200_64 - same is true for the SE.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 8 of 215, by Caesum
What would be the ideal 5V + 3.3V total be like for my hardware then? Something above 120W?
I'm asking because I'm checking both old and new PSUs atm and it seems most of available ones in Poland are less than 105w. Akyga seems to be a good choice on paper but their 500WAT PSU tends to blow up. On the other hand i assume people try to use it with their modern day hardware not low budget legacy one.
Reply 9 of 215, by shevalier
Caesum wrote on 2026-04-22, 18:59:
A brief history of power supply units.
- Initially, there were AT units, which contained a lot of copper and diodes on the +5V rail
- With the introduction of ATX standart, some of the copper was diverted from 5V to the +3.3V rail and diodes were added for this rail
- With the introduction of the 4-pin connector for the Pentium 4, further copper was diverted to the +12V rail
- With the advent of the 6-pin (later 8-pin) connector for graphics cards, some of the diodes were removed from the 3.3V and 5V rails and used to install additional diodes on the +12V rail
___________ This is where the APFC comes in (because modern PSUs with a power rating of over 500W are not manufactured without an APFC
- Modern PSU. A single +12V bus, with the +3.3V and 5V lines derived from it via separate converters. These may be located in rather unusual places, as modern systems have low power consumption on these lines and do not require special cooling.
And the temperature sensor monitors the 12V line.
Under a load of 150 W, the main power rail (+12 V) won’t even break a sweat, and the fan won’t kick in. Yet the converters are already overloaded.
The question is which of today’s power supplies can operate in this mode for an extended period — it is precisely these non-standard tests that need to be carried out.
That is why no one can guarantee anything.
Chinese OEMs from local brands for $20.
No one knows anything about them at all. The only thing that can be said for certain is that they are available for purchase.
Given that they lack an APFC, they are probably from the ‘Pentium 4’ era or the ‘early 6-pin graphics card’ era, i.e. more promising for retro setups.
But nobody knows where they cut corners or what they left out.
Reply 10 of 215, by momaka
Is that AMD Duron 1.4 an Applebread (aka Thoroughbred) -based core? Check the full model number in CPU-world.
Funny enough, a 1.4 GHz Applebred Duron and an ASUS Radeon 9200 SE was exactly what I had in my first "own" PC as a teenager.
No, you don't need upwards of 120 Watts for these... not even close.
The Duron Applebred is rated for max of 57 Watts maximum power use. Round that up to 60 Watts just to make the numbers easier. At 5V, that's 12 Amps from the 5V rail if your motherboard does not have a 4-pin 12V CPU connector.
The Radeon 9200 SE (or all Radeon 9200/9250 cards for that matter) are light power sippers at most. You're looking at around 10 Watts under max load, most of which is from the 3.3V and 5V rail. I don't remember which one actually powered the GPU on mine... but let's assume the 5V rail for an even worse case 5V load for your machine. 10 Watts = 2 Amps @ 5V. Add that to the 12 Amps for the CPU and you'll be at 14 Amps. Add 1A more for 2 mechanical HDDs (worst case power draw for them on the 5V rail) and another 3 Amps for RAM + chipset on the motherboard (typically, most motherboards will use a combination of the 5V and 3.3V rail for these, but let's assume it's all or mostly from the 5V rail here, just to take into account the worst possible case)... the result would be 18 Amps max under full system load.
With that said, a PSU with a 20 Amp rating on the 5V rail should more than suffice for your system. If it's a quality-made older OEM PSU, probably even down to 15 Amps would be OK... though probably running the PSU's 5V rail on the limits, which isn't a good idea for long-term usage.
If there are confirmed cases of these blowing up rather than shutting down gracefully when overloaded, then 99.99% chance these are cheap crap half-ass'ed half-bridge design with half of the components missing and not worth half a sh**. 😁
My gut feeling: skip this one.
Not sure how things are in Poland, but here you can go to a local metal recycler place and buy old computers/parts by the kilogram. If they don't do that where you are... just wait outside and see if you can intercept anyone who brings some e-scrap. I did that back in the USA, since most scrap yards didn't allow buying of PCs and electronics directly. 😉
Caesum wrote on 2026-04-22, 10:29:
No, that's way too overspec for your system and would make finding such a PSU really hard to find.
A lot of people haven't actually measured power draw on their systems, so they always tend to overspec.
The only time I would ever recommend a PSU with more than 22 Amps on the 5V rail is if it's a higher-end (or just more power-hungry) Athlon /XP CPU that's -combined- with an ATI R300/R350/R360 -based video card (aka Radeon 9500, 9700, or 9800). Actually, I have this combo right now (Athlon XP 2500+ and Radeon 9700 non-Pro) running on a Dell/Chicony/HiPro HP-P2507F3P (also nearly the same as a HP-P2507FWP in case the previous model doesn't show anything for anyone) 250 Watt PSU. These are rated for only 22 Amps on the 5V rail, but it's a rock-solid rating.
Further, the only more 5V power-hungry setups than the above are the dual Athlon MP systems, since with these, you can have each CPU drawing up to 70 Watts from the 5V rail... which will translate to roughly 150 Watts from the 5V rail with all the other hardware on the mobo... aka 30 Amps.
The absolute worst case for a 5V-heavy system would be the above combined with a Radeon 9500/9700/9800. Now you're just adding another 50-60 Watts of power draw, most of which from the 5V rail and 3.3V rail. For these cards, close to 2/3 of the power draw is from the 5V rail, so you can expect to need another 6-8 Amps more on the 5V rail... which will bring the grand total very close to 40 Amps.
But you're not building THAT system, so rest assured you don't need such heavy-duty oldschool PSUs. 😉
If it's not a brand I know, chances are the label could be (and likely is) a complete lie.
I would definitely NOT trust that PSU to be capable of 28 Amps on the 5V line. If by some miracle it is, chances are it wouldn't be possible without some heavy load on the 12V rail as well, as it's more than likely a group-regulated PSU (which means the 5V and 12V rail voltage regulation depends on each other.)
gerry wrote on 2026-04-22, 11:22:
If that's an Applbred Duron, then that's the lowest in the seires, with 1.6 and 1.8 GHz being the "mid" and "high" range.
However, all of these have only 92 Kb of L2 cache (IIRC), so they are pretty poor performers out of the box. How I know? - I had one between 2004 and 2007. It was an underwhelming chip even for its time, akin to the P4 Celeron. Unlike the Netburst Celerons, at least on these you could theoretically re-enable the full 256 kb L2 cache by closing some of bridges on the CPU. My Duron, however, came with a green PCB mask and so the contacts on the L bridges are not exposed, thus not easy to close from what I have read. I have vowed to attempt it, though... some day! 😁
I do too, but I open and check all PSUs that come across my bench of what they should be capable of theoretically... and if time allows, test them too.
So no issue with using cheaper PSUs, so long as they get rebuilt with proper output filtering (as many usually lack this part) and get tested how well they cross-load.
Now some of you may find this surprising, but not all "old" PSUs are good at cross-loading with a 5V-heavy load.
Caesum wrote on 2026-04-22, 15:10:
No idea, haven't opened or seen one of these inside before so I can't tell you anything about it.
I don't think that particular PSU is from 2009, though. With only 13 Amps on the 12V rail and much more on the 5V rail, that is probably a mid-2000's PSU at best... which would be good in your case.
Actually, this might be what you need for your system. But first, ask your shop what they mean by "renewed". If it's just the dust blown out and PSU only "tested" on a cheap PSU tester.... well, that's not really any better than buying a quality OEM 200-250 Watt PSU in unknown condition and doing up the cleaning and testing yourself.
I know you said you don't want to deal with soldering, so I'll refrain from pushing you in that direction for now. But in all honesty, getting an old quality 200-250W PSU that -possibly- needs a recap might be easier (and cheaper) than looking for something else.
Well, Yes and No. 😀
I've been doing GPU power draw analysis (though not as accurate/precise as tehsiggi's) on old/"retro" GPUs for a number of years.
And you might be surprised what draws power from what.
Generally speaking, you are correct that the older (2003<) GPUs tend to draw power mostly from the 3.3V and 5V rails... but it still depends.
For example, if I remember correctly, the higher-end GeForce FX cards (FX 5700, 5800, and 5900) draw power from the 12V rail for the GPU and 3.3V for the RAM. RAM power draw is generally under 10 Watts.. so you'll be looking at no more than 3-4 Amps on the 3.3V rail. Only if some parts of the GPU are powered from that you might see more (usually GPU also draws some power from the RAM Vdd/Vddq rails as its memory controller uses the same voltage to communicate with the RAM chips.)
But even then, it depended on who made the board. At least I think OEM/reference design did it the above way. And if I am not mistaken, even the GeForce 4 TI 4400/4600 were the same or very similar. Only GF 3 and I don't know much about, since I still don't have one (poor me!) :p
Now, as for the lower-end stuff like GeForce 2/4 MX, ATI Radeon 7000/7200, RIVA TNT/64/M2 and etc.... you can tell the GPU draw pretty much by the size of the GPU heatsink. If it's a GPU with a small (usually around 40x40 mm) passive heatsink or one with a tiny fan, usually the total power draw of the entire card will be under 15 Watts (for some cards, even less than 10 Watts)... that is, under full load.
So regardless if that power comes from the 5V or 3.3V rail or a combo of the two... it's just not going to add that much relative to what the CPU will pull on a more 5V-heavy PC.
Agreed.
In particular, with those old PSUs, it's not only that they are capable of providing more power on the 3.3V/5V rails, but also how well the PSU will regulate when it is loaded this way.
Old(er) PSUs that are from the 5V-heavy era will give greater priority to regulating the voltage on the 5V rail closer to 5V and not as much on the 12V rail. With these PSUs, the 5V rail will almost always read very close to 5V regardless of how the PSU is loaded. Meanwhile, the 12V rail can appear to swing quite a bit. It's not uncommon to even hear the system fans revving up and down as the 12V rail goes up and down when the CPU transitions between load and idle.
Indeed.
In fact, the only old/retro PSU I've come across that had APFC but still provided a hefty 5V rail and was good with a 5V-heavy system was an FSP400-60PFN (I believe I have it posted on badcaps.net somewhere, for those curious to see what it's like inside.)
shevalier wrote on 2026-04-22, 19:29:
- Modern PSU. A single +12V bus, with the +3.3V and 5V lines derived from it via separate converters. These may be located in ra […]
Actually, it's probably only these types of modern PSUs that should be better-suited towards providing stable power for an old 5V-heavy system.
But yes, it really is a question of how hot the 3.3V and 5V buck regulator modules will get inside these PSUs and thus how long they will last.
I have the same suspicion as you that they will cook in thus not make the PSU last too long. But again, that will depend on the PSU's fan controller, as you noted.
I personally despise "ECO" PSUs that turn their fans off. Ever put a thermal camera on those? It's like the Radeon 3870/4850/4870 stock cooling profiles all over again: they literally wait until stuff is too hot and then they turn on - as if really done on purpose to guarantee the product will eventually fail (but not before the warranty expires, of course!) IMO/IME, the fan should always be running on a PSU. It's there already! Why have it sit around and do nothing?! (Yes, I know, the "noiseless PC" crowd will probably like to insert a few words here... but honestly, that crowd can go f- themselves for all I care.) Even when barely turning, it will provide much needed cooling on certain components (namely, the APFC inductor and input cap, which tend to be the hottest stuff.)
Anyways, I guess I'm just ranting about modern PSUs at this point, so I'll stop here. Just to be on-point, though - even such PSUs would still be an OK option for an old system, though I suppose with a cooling/fan modification: either open the PSU and wire the fan to run permanently on some set voltage -OR- just "rig it" with another fan on top of the PSU's fan so that the DC-DC buck regulators for the 3.3V and 5V rails are always getting some cooling (along with the APFC filter cap.)
Reply 11 of 215, by cyclone3d
Please don't buy or use any of those junky chinesium power supplies.
At best, you will end up with something that works ok but will most likely not last.
At worst, it will catch fire.
The middle ground is when something in it dies, it will kill other components in your computer.
It is best to only use good quality brands. If buyong used, make sure that you get a brand and model that you can find actual reviews for where they put the PSU through actual stress tests with a real power supply load tester and that has results that also show the efficiency, ripple, etc.
Pretty much all chinesium PSUs are rated way above what they can actually output reliably.
Almost all that I have seen properly reviewed have failed spectacularly during the load testing.
Brands such as Seasonic, Antec, Thermaltake, Super Flower, Corsair, Cooler Master, and SilverStone are generally good though I would really only trust Seasonic and Super Flower as they manufacture their own PSUs. The other brands generally outsource the manufacturing to various OEMs and you really need to find out the OEM as well as find reviews for that specific model and revision because some are not that good.
If is also good to look for at least 80+ bronze rating as well as for these specific brands. Most modern PSUs will, at the minimum have an 80+ bronze rating and that is really the bottom of the barrel for good brands.
Also, never trust junky brands that claim some sort of 80+ rating as most / all of them do not have that actual certification and those trash brands just include it on the stickers as there really is no way of keeping them from lying about it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 12 of 215, by shevalier
cyclone3d wrote on 2026-04-23, 05:49:
Houston, we have a problem.
Following the introduction of PSU efficiency ratings (those Bronze, Silver, Gold, Titanium and other "Platinum" grades), there is now just one remaining topology.
A +12V bus with synchronous rectifiers instead of diodes and converters from +12V to 3.3/5V.
Otherwise, efficiency is around 80%, because the component that generates the most heat in a classic PSU is the rectifiers using Schottky diodes.
And in all such PSUs, the 3.3/5V outputs are up to 25A with a total power of 100–120W maximum, even in 1.5kW models...
5 yeard old 450W model 110W for 3.3&5V summary
https://www.techpowerup.com/review/corsair-cx … m-series-450-w/
1450W model 125W for 3.3&5V summary
https://www.techpowerup.com/review/seasonic-p … x-1600-atx-3-0/
Reply 13 of 215, by Mike_
shevalier wrote on 2026-04-23, 07:19:
Houston, we have a problem. Following the introduction of PSU efficiency ratings (those Bronze, Silver, Gold, Titanium and other […]
It's not quite *that* bad. For aforementioned RM550x 3,3V/5V outputs have combined total power of 130W and from RM750x up it's 150W. It's not optimal, but should be usable for most old ATX setups.
https://assets.corsair.com/image/upload/corsa … 2018_Manual.pdf
Reply 14 of 215, by shevalier
Mike_ wrote on 2026-04-23, 07:55:
Isn't this PSU actually an EOL?
And then there’s the cooling.
For some people, with three 120mm fans in the case, it’ll manage even with an ASUS TUSL2-C or CUBX.
But for others, even with a Duron, PSU go into thermal shutdown.*
*The full CUBX (not -E or -L) and TUSL2 motherboards are so idiotic that they do not use the +3.3V bus from the ATX power supply at all. The 3.3V is generated locally on the board from +5V rail.
Simple boards with SDRAM, which have no voltage regulation on them, simply connect the memory power supply to the 3.3V bus of the PSU’s ATX power supply.
Reply 15 of 215, by Caesum
Okay, thanks for your answers! Now I see that there's no point testing modern PSUs as most likely their 3.3V and 5V lines wouldn't be able to handle old hardware. Point noted!
I understand now that I should be looking for a good old brand with at least 20A, maybe 22A on 5V line (so around 120 watts on 3.3 & 5V combined). A 250W overall PSU should be sufficient for my specs as it's a cheap PC. It shouldn't be an Active PFC type.
Would that still apply for a Voodoo card if I wanted to buy one eventually? I assume Voodoo 1 wouldn't be too power hungry but newer Voodoos are probably way more demanding.
Noted! Are we talking about old or new PSUs though? Or both?
Reply 16 of 215, by Mike_
shevalier wrote on 2026-04-23, 08:35:
Isn't this PSU actually an EOL? And then there’s the cooling. For some people, with three 120mm fans in the case, it’ll manage e […]
*The full CUBX (not -E or -L) and TUSL2 motherboards are so idiotic that they do not use the +3.3V bus from the ATX power supply at all. The 3.3V is generated locally on the board from +5V rail (RM550x is discontinued).
Looks like you are right, it's EOL, but they should be readily available in second hand market. New RM750x apparently still has 150W for combined 3,3V and 5V power, but just 20A limit for 5V.
However, is the PSU so dumb that it will throttle fan based on power use rather than temperature? It doesn't say whether that graph is just a measured graph based on how a modern computer uses power.
Reply 17 of 215, by cyclone3d
Caesum wrote on 2026-04-23, 09:00:
Okay, thanks for your answers! Now I see that there's no point testing modern PSUs as most likely their 3.3V and 5V lines wouldn […]
Both off and new. If you are looking at used, older PSUs, BFG made some pretty awesome ones as well. Their line that had the 1200w or 1250w one was the most efficient PSU throughout the load range ever made and is still up there in those terms.
When there was a huge stock of the older Seasonic ATX PSUs on eBay I bought a bunch of them (350w-550w). At that time they were going for $20-$30 a piece. They were new system pulls.
For older Antec, make sure to verify that they were not in the era of the capacitor plague. The TruePower line and a couple other lines had capacitor issues and you literally cannot find good replacement capacitors that will fit in the space that they put them in. I ended up having to run wires from the board to a few of the replacement capacitors and hot glue them in place.
YMF7x4 Guide
Reply 18 of 215, by AlexZ
I have the following PSUs for such cases:
  • Eurocase 350X, 350W, 14A on 3.3V, 30A on 5V, 12A on 12V, 3.3V+5V=185W - it has PFC written on it, P4 connector but still relatively strong 3.3V+5V rails. Designed for Athlons and P4.
  • FSP Group (Fortron) 350W, 20A on 3.3V, 16A on 5V, 10A on 12V1, 13A on 12V2, 3.3V+5V=130W - it has W/PFC sticker, this one is clearly for late Athlon XP boards with P4 connector, or socket 754 with AGP
  • Chill CP-510A - 510W, 33A on 3.3V, 45A on 5V, 25A on 12V, 3.3V+5v=330W - this is Active PFC PSU, but has extra strong 3.3V+5V rails. That's why I got it.
I used the Chill PSU for s754 until I decided to get GTX 275 and swapped in a 800W PSU. Now I only use it for testing boards as it can handle everything.
I do have a few KT133 boards and Athlon 1200 CPUs and for those I would use the 1st PSU with 185W max load on 3.3V+5V.
Locally I see Maxpower 400W PSU on sale, it has 255W max load on 3.3V+5V.
In your case I would just buy 2nd hand 350-400W PSU that isn't too dusty and has at least 180W max load on 3.3V+5V. Such PSU will have strong 3.3V and 5V rails.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 19 of 215, by Caesum
AlexZ wrote on 2026-04-23, 19:30:
Aren't these a little too power hungry for my specs though? Others said a good brand 250W PSU should be sufficient for as long as it has over 20A on 5V line. My computer is a budget build.
I found a Seasonic PSU that's been renewed (whatever that means) and it seems it would have been perfect for my build at a first glance and it's not too pricy (80PLN == 19 EUR). What do you guys think? One thing I have noticed about is the AC Input. Most PSUs I checked have 200-240VAC 3A 50/60Hz but this one has 4.5A, but I guess this shouldn't really be an issue?
