First post, by my03
Yeah, I'm terribly sorry if this is a beaten to death subject. I searched here and the verdict seems to be in both corners (performance vs. compatibility)...
I recently threw some gust of new wind at my laptop that supports (as i finally came to conclude) both the DX2-66 as well as the DX4-100 (25 and 33mhz bus speed):
What is this machine (odd clone laptop - 486 dx66)
The cooling solution consists of a fairly solid block of aluminum + fan so it doesn't seem to lack in that regard afaik. I have been running a DX4-100 in it for some time now and it appears fairly solid. The fan only comes on on occation (during game-play at times) and neither the top or bottom seem particularly hot.
But would it be wise to push for an AMD solution? I'm seeing that the AM5x86 would be the "ultimate" 486... How hot does the AMD get vs. the Intel?
Reply 1 of 12, by BitWrangler
I've got maximum power dissipation of 3.7W for the AMD-133 and 4.29W for the Intel DX4-100 ... though unless the BIOS is aware of the AMD it might not set it up quite right and performance will be a wash.
Reply 2 of 12, by my03
BitWrangler wrote on 2026-04-27, 22:56:
I think as this machine came out way before any DX4 (or i can imagine - AMD) was really official, i wouldn't think that the bios would support any quirks that came with the AMD at least... Perhaps best not to even try it 😀
Reply 3 of 12, by jakethompson1
my03 wrote on 2026-05-06, 16:16:
The BIOS doesn't control the speed of the Am5x86-133. The only potential problem is if the board is jumpered so that the Am5x86-133 is running in write-back mode, but the BIOS programs the chipset to expect it to be running in write-through mode. Jan Steunebrink has a period-correct webpage from when this upgrade was relevant to one's "daily driver" that talks about that issue http://www.steunebrink.info/amd5x86.htm
Reply 4 of 12, by akimmet
As long as the laptop supports 3.45V CPU's, there won't be any physical harm from trying an AM5x86 CPU.
The only risk would be power management crashes.
Although I can understand not wanting to buy a CPU that may not work. Not to mention the risk when pulling a 486 from a conventional socket.
Reply 5 of 12, by leileilol
the 'p75' can hit 160mhz so yes i'll take that over the iDX4. Some say the intel one was 'faster for quake' but that's been just hearsay at best from my experience (I lanned a AM5x86 @120mhz vs a iDX4/100 then, the amd shot nails faster).
long live PCem
Reply 6 of 12, by mwdmeyer
leileilol wrote on 2026-05-07, 02:01:
40mhz fsb though?
Reply 7 of 12, by BitWrangler
Yeah it's a bonus when 486 laptop boards will do 33, you get a lot of them at 25
Reply 8 of 12, by appiah4
I used to own a DX4-100 back in the day and playing Quake, even 320x200 on it, was an unbearable experience and what prompted me to upgrade to a Pentium 133 in late 1996.
Reply 9 of 12, by jesolo
Neither the Intel 486DX4-100 or AMD 5x86-133 is really suitable for playing Quake due to the poor math co-processor performance.
You really need a Pentium class CPU for that.
However, if you have a Pentium Overdrive (P24T) 83 MHz CPU then it does make for an interesting Quake experience on a "486 class" system 😁.
Reply 10 of 12, by MagefromAntares
jesolo wrote on 2026-05-07, 08:53:
In my personal experience, I had more trouble with Pentium Overdrive chips than what they were worth. Of course if you already have an Overdrive chip laying around then try it, but buying one is kind of a lottery depending on whether it works with the motherboard or not...
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 11 of 12, by jesolo
MagefromAntares wrote on 2026-05-07, 09:09:
Fortunately, I was lucky with my 83 MHz version.
I do agree you need a fairly "newer" 486 motherboard (preferably a Socket 3) to ensure proper compatibility.
From an integer performance perspective, it does perform more or less on par with that of a Pentium 75 MHz CPU and similarly with its floating point performance.
However, an AMD 5x86-133 and Cyrix 5x86 will give you better integer performance if you apply some "tweaks" to the CPU (either via overclocking for the former or some registry tweaks for the latter).
But, I digress a bit.
Reply 12 of 12, by my03
Hey guys,
thank you all for you very good input. Then i know i might not have to worry too much about the bios itself and that it could well be worth a try 😀 I'll probably try it shortly (and ping back here).
I "did" actually get a P75 overdrive for it. Unfortunately, the fins on this cpu was too tall for my laptops taste (couldn't snap it shut with it installed). This particular machine has this rectangular cooler that extends from the cpu all the way to mounting points at the back, and even with that removed (relying on the P75 fins for cooling) it was too high.
At some point i was considering trying to remove the heatsink from the CPU, but that seemed to be a lot of work (if even possible, reading about how glued on they might be). I might have some easier roads ahead by simply trying the AMD 133 😀
br
