First post, by IcySon55
Wishing for a dual 5.25" bay adapter that provides three 3.5" bays to the front of the case instead of being closed for HDDs.
One of these doesn't seem to exist yet.
The case I'm using for my DOS build is the SilverStone Technology Precision Series ATX Tower Case PS13B which has some benefits for older motherboards like PSU at the top, at least one 3.5" bay and the dual 5.25" bays. Long cards like the Orpheus II and SB AWE32 also fit in the case just fine.
Example goal:
The attachment Image2.png is no longer available
Reply 1 of 9, by CC-Adam
Would be really useful, could even utilise the spare space at each side for a built-in gotek and/or SD/CF slots etc.
Reply 2 of 9, by jh80
IcySon55 wrote on 2026-05-05, 06:43:
Wishing for a dual 5.25" bay adapter that provides three 3.5" bays to the front of the case instead of being closed for HDDs. […]
Example goal:
Would be nice. I also have several of the SilverStone PS13B cases and really like them for the reasons you mentioned, and also because they are extremely compact for a full ATX case - something very rare to find nowadays. The only issue I've really had is that some older, longer CD-ROM drives don't quite fit with the PSU wires in the way.
Reply 3 of 9, by douglar
Would a 3d printer stl be good enough?
Reply 4 of 9, by IcySon55
douglar wrote on 2026-05-05, 22:11:
I guess it would be. I'd probably have to order it online like through pcbway or similar since I don't have a 3d printer (yet).
Reply 5 of 9, by douglar
IcySon55 wrote on 2026-05-05, 22:15:
Check with you local library. Around me they have some pretty high quality printers and affordable rates.
I'll see if I can put something together for you.
Reply 6 of 9, by IcySon55
I won't be needing it that soon. PicoIDE hasn't shipped yet (looks like it'll be around August) and I don't yet own a Gotek or an OpenFlopps board (a complete kit isn't easily available). It's a mid-year target.
Reply 7 of 9, by rmay635703
If one drive was vertical you could fit 4x 3.5” disk drives into a single 5.25 full height bay
Reply 8 of 9, by IcySon55
rmay635703 wrote on 2026-05-06, 17:48:
What do you mean? 3.5" drives don't fit vertically in a single 5.25" full height bay. They do fit vertically in three 5.25" bays though.
The attachment Drive_bays.jpg is no longer available
Reply 9 of 9, by rmay635703
IcySon55 wrote on 2026-05-06, 22:53:
Bleh I was thinking they were 2” tall
