Problem with RAID controller when restarting
First post, by DustyShinigami
I think I did try asking if there was a way of preventing the RAID controller info from appearing during boot, but it got no response. Now this is something I really need. Or some sort of workaround. Because much like the random Windows 98 shutdown hangs I posted about, I keep getting a weird and annoying hang with the RAID controller during boot. However, this only seems to happen if I restart the PC. If I do a shutdown, it loads as normal. No issues. But if I have to restart, usually because of installing some driver or other, it's a problem. It'll get to this point...
The attachment IMG_E5519.JPG is no longer available
...and it takes just under seven minutes (I timed it) before it times out and gives me an error. And then after it initialises the autoexec and config files, it gets stuck again for a further 2-3 minutes. When it does finally load Windows, unsurprisingly, the E drive connected to the controller is missing. I figured it was the driver, but even after uninstalling it from Windows, the BIOS version number was still 1.4.1.6 during boot, and installing the one suggested to me in this thread - Re: Advice on bigger HDDs beyond 128GB - the same issue happened after restarting. Even after all resource conflicts had been cleared in the Device Manager. 🙁 That Windows driver is 1.7.2.3, but the BIOS version is 1.4.1.6. So unless there's a specific BIOS file I need to flash...?
I did download this - https://theretroweb.com/drivers/306 - but I'm not even sure if it's the correct one. I did try the BIOS flash utility, but some stages passed and a couple failed. So in the end there's no change. Same version.
I'm out of ideas.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 24, by MagefromAntares
Hi,
Can you give more detail about the HW used? The motherboard in your signature (ABit AB-BE6-II) should have a RAID controller, but it is supposed to be a HighPoint one and not an ITE one, is it the same system and a ITE based RAID card installed or another system with a motherboard using an ITE controller?
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 2 of 24, by DustyShinigami
MagefromAntares wrote on 2026-05-23, 23:43:
Hi,
Hi. Thanks for the response. Yeah, you've more or less got it. It's the motherboard in my signature. I don't think I was able to get my biggest HDD to work correctly with the HighPoint one, so yeah - it's an ITE RAID card I'm using. I believe it's some generic brand, but it's essentially the ITE8212F. I was reading through another thread and grabbed a load of BIOS updates and flasher, but I'm not sure whether they'll work. I did read mention of having to do something with unsoldering or using an EPROM...? Totally out of my skill-level if that's what's required.
OS: Windows 98 SE
Reply 3 of 24, by MagefromAntares
Hi,
If the data-sheet of the chip at https://theretroweb.com/chips/4664 to be believed (Unfortunately it is V0.3, so it might not be 100% true to the final released chip) then the EPROM path is not workable as this IC has its own integrated flashable ROM, so it will be most likely not compatible with standard EPROM writing equipment, and there doesn't seem to be pins supporting an external EPROM to be installed.
This also seem to be supported by the only card listed on that page that contains this chip https://theretroweb.com/expansioncards/s/startech-pciide2, it only contains two ICs one the ITE controller itself and another which I unable to find the exact specifications for, but it seems to be more like a interface/bridge(This is purely conjecture as I cannot find information on that second chip on the card) chip than some kind of ROM.
However if it hangs "Please wait for IDE scan.." message it is possible that one of the HDDs connected to the card is answering too slowly, have you checked the HDDs with a different RAID card, it can be used to confirm if the card is getting stuck or one of the HDDs are answering slowly? (Of course if it contains valuable data, backup that first, as connecting to a different brand of RAID card might damage the data on the HDD)
Reply 4 of 24, by DustyShinigami
MagefromAntares wrote on 2026-05-24, 00:26:
Hi, […]
Hi,
This is the card I have, which was taken from the linked thread:
The attachment IMG_5422[1].JPG is no longer available
So I'm not sure how similar it is. The writing/serials on the chips are different.
Unfortunately, I don't have another RAID card. This is my first. Though if I do ever get another, I think I'll be tracking down one of the more reputable brands. The data on my HDD are my backed up CD images, so I definitely don't want to lose them. Sometimes I can get the HDD connected to my main PC to backup, but I say sometimes as the drive hardly ever gets detected by my IDE/SATA adapter. It's likely due to it being a Deathstar model.
OS: Windows 98 SE
Reply 5 of 24, by MagefromAntares
DustyShinigami wrote on 2026-05-24, 00:46:
If by "Deathstar" you mean the infamous IBM Deskstar then I would seriously reconsider using it to store any important data, one of the few serious data loses I personally experienced was the data stored on that specific kind of drive, I have heard that the later models manufactured by Hitachi was more reliable after IBM sold the technology to them, but if it is an original IBM Deskstar I wouldn't trust it even as a 2nd line backup.
Reply 6 of 24, by PC Hoarder Patrol
If we're still talking the IC35L 120AVV207-0, that's not a so-called 'DeathStar' model (originally the 75GXP & with a different issue , the 60GXP) though yours doesn't sound in the best of health...try running the attached 'drive fitness test' app against it
The attachment Dft32_User_Guide.pdf is no longer available
The attachment DFT32V320.EXE is no longer available
Far as your raid card firmware goes, v1.4.1.6 is pretty old with the latest being v1.7.1.94 which is here... https://theretroweb.com/chip/bios/bios-8212ra … 1b664259158.zip
Can't see anything in the card manual re. suppressing the option ROM splash message and this is more likely a function of the mb BIOS rather than the card, if at all.
Reply 7 of 24, by DustyShinigami
MagefromAntares wrote on 2026-05-24, 00:51:
I think it is an Hitachi. I’d have to check. There might even be a pic of it in another thread. It is something I’ll need to replace at some point.
EDIT: Yeah, so I think it’s this one:
The attachment IMG_5520.jpeg is no longer available
OS: Windows 98 SE
Reply 8 of 24, by DustyShinigami
PC Hoarder Patrol wrote on 2026-05-24, 02:10:
If we're still talking the IC35L 120AVV207-0, that's not a so-called 'DeathStar' model (originally the 75GXP & with a different […]
Wow. You have a good memory. 😄 But yes, that’s the model; same as the one in the image. But yeah, I do suspect the health of it is flaky as connecting with my adapter to my main PC often gives me a clicking sound and it fails to detect it more often than not.
But thanks for the link to the Drive Fitness Test. I don’t think anyone shared that previously. It’d be nice to get a clearer picture on its health.
And thanks for the link to the firmware. I have downloaded quite a few, but hopefully this does the trick. Fingers crossed it eliminates the issue. 😩🤞🏻
OS: Windows 98 SE
Reply 9 of 24, by DustyShinigami
Yeah, same problem as yesterday. And this was with both versions of the update utility. 🙁
The attachment IMG_5523.JPG is no longer available
The attachment IMG_5524.JPG is no longer available
OS: Windows 98 SE
Reply 10 of 24, by DustyShinigami
Tried about 7 or so updates, as well as using update utility 2.01 and 2.02 and I get the same thing every time. It also fails on Blank Check and Verify.
OS: Windows 98 SE
Reply 11 of 24, by DustyShinigami
Just installed and ran that test and yeah, the Hitachi drive, before it even gets anywhere with the test, gives me a red box saying there's a problem with the drive. Says Disposition Code = 0x71. Not surprising really. So at some point soon I'll have to get it replaced. Back up the stuff on it and get rid of it. Hopefully that solves the issue.
OS: Windows 98 SE
Reply 12 of 24, by jmarsh
The 27C512 chip is definitely an EPROM that likely holds the card's BIOS. It's probably not possible to flash it via software without adding the missing jumpers (JP1/JP2) but would need a closer look at the connections to know for sure.
Reply 13 of 24, by DustyShinigami
jmarsh wrote on 2026-05-24, 15:57:
I see. Hmm. I don't recall seeing any jumpers on the card. I'll have to take it out and take pics of the front and back.
OS: Windows 98 SE
Reply 14 of 24, by MagefromAntares
DustyShinigami wrote on 2026-05-24, 16:02:
It is because the jumper pins are not installed on your card, their places are marked as JP1 and JP2 on the picture you have posted, the card that I linked previously(https://theretroweb.com/expansioncards/s/startech-pciide2) actually has two set of jumper pins installed in almost the same position(Both cards are most likely based on the same reference design). Unfortunately the manual on theretroweb.com doesn't mention what exactly those two jumpers do...
EDIT: Also I have found the data-sheet(https://www.alldatasheet.com/datasheet-pdf/pd … K/HT27C512.html) for that second IC on your card and it is indeed an EPROM as jmarsh said, I have misidentified it in my initial assessment of the similar StarTech PCIIDE2 card, so thanks jmarsh for correcting my misinterpretation.
Reply 15 of 24, by DustyShinigami
MagefromAntares wrote on 2026-05-24, 18:44:
Ahh, I see now. Thanks. I take it a replacement would have to be soldered on?
OS: Windows 98 SE
Reply 16 of 24, by MagefromAntares
DustyShinigami wrote on 2026-05-24, 18:59:
Yes that would be the proper way to fix it, however if that is the card's BIOS chip the issue most likely a deeper one, I have taken a look at the data-sheet of the HTR27C512 and on the first page it mentions that it is one time programmable(OTP), so it is possible that writing the BIOS to this card will fail regardless of jumper settings because the chip they have chosen for the BIOS cannot be reprogrammed.
Reply 17 of 24, by DustyShinigami
MagefromAntares wrote on 2026-05-24, 19:02:
Ahh, man, that sucks. But thanks for checking. I can only hope and presume the issue I have is because of the HDD anyway. Failing that, I'll have to look out for a RAID controller from a better company and check if the jumpers are in place.
OS: Windows 98 SE
Reply 18 of 24, by PC Hoarder Patrol
Academic now, given the Holtek OTP chip, but according to ITE their f/w update utility only supports SST, Atmel & PMC Flash (and is jumperless...believe the missing JP1, JP2 headers may be to enable / disable IDE channels).
Shame about the hdd (I've a few of this exact model and all have been faultless, both singly and as raid members). Truthfully, thee problem always sounded more like the hdd than the card anyway.
Reply 19 of 24, by DustyShinigami
PC Hoarder Patrol wrote on 2026-05-25, 02:22:
Ahh, I see. Fair enough. But you're very lucky you've had faultless models of this HDD; most have said they're notorious for having problems.
OS: Windows 98 SE
