trying to get my epson 286 pc to work
First post, by jude1977
Hi I’ve just brought an epson 286 pc on eBay. It powers on I can here the fan in the psu
Running but none of the floppy drives power on and when I attached a monitor it only
Shows a cursory on the screen a nothing else I’ve had a look inside the machine it doesn’t seem to have a hard drive but I’ve heard if you have a bootable copy of dos which I have you can boot it from that
But the problem is none of the floppy drives power on I’ve also tried to locate the cmos battery
But I can’t seem to find it . Would anyone one know what the issue is with the floppy drives not powering
On is and would anyone know where the cmos battery is located if anyone could share some light on this problem I’d really appreciate it if you could let me know
Reply 1 of 158, by NeoG_
The dead battery is embedded in the Dallas RTC chip, it's also what is likely preventing the system from booting. You'll need to modify it or source a replacement.
Reply 2 of 158, by jude1977
hi thanks for your message i tried pulling out all of the 3 cards and just left the monitor card in i turned it on and it booted and the floppy disk drives powered on and the there were two beeps.
i then tried every card in the machine one at a time when i put in 2 of the cards it turned on but when i put the 3rd card in it didn't turn on so the 3rd card seems to be causing the machine not to boot
Ive taken the 3rd card back out and have taken a photo of it as im not sure what its for and what its spose to do
Reply 3 of 158, by Shponglefan
jude1977 wrote on 2026-06-08, 13:37:
That's an MFM hard drive controller card: https://theretroweb.com/expansioncards/s/west … tal-wd1002a-wx1
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 158, by jude1977
Interesting I didn’t know it was a mfm hard drive controller when it’s inserted in my machine it causes the machine not to boot at all is there a reason for this is there Spose to be a ribbon cable attached to
Reply 5 of 158, by jude1977
Also I have it in the back of the machine but I noticed the part that clips in to the slot the slot is a lot
Longer in length then the part on the actual card is it spose to go somewhere else in the machine
Reply 6 of 158, by wierd_w
jude1977 wrote on 2026-06-08, 15:30:
MFM controller cards use the same resource assignments as Primary IDE controller. 😁
Reply 7 of 158, by rasz_pl
wierd_w wrote on 2026-06-08, 17:36:
no ide controller in this computer
so does the PC turn on and not boot or not turn on at all with the card? MFM controller has some tantalum caps (big black ones) and one might be shorted, or the firmware (U12) might be corrupted due to age (eproms sometimes do that).
Reply 8 of 158, by wierd_w
Oh, Silly me, I thought they were inserting it into a newer retro machine for testing.
In this case, maybe there is a collision with some other option rom at D000 , or and IRQ conflict?
Reply 9 of 158, by jude1977
hi all thanks for your reply s im needing some more info im wanting to use a hard drive on this machine as it didn't come with one
would any one know where id attache it to, would i attach it directly to the mother board or would i attach it to the mfm card
Reply 10 of 158, by myne
Use your nose!
Smell the dead card closely.
If you smell that distinctive burnt electronics smell, its easier to find the dead thing.
If you don't, post VERY HIGH resolution/clarity photos here.
It looks pretty clean on the pic above, but it can't hurt to wash it with soap and water.
Water is "the universal solvent" and can fix some shorts.
Dry thoroughly. Full sun 4-5hours recommended.
I built:
Reply 11 of 158, by jude1977
thanks for the advice ill do that and check it out to see if its ok
Reply 12 of 158, by jude1977
hi all Ive finally got my epson 286 pc working Ive even taken out the floppy drives to clean them they work fine the only trouble i had was
i tried formatting one floppy it formatted but gave a message cant use as system disk and when i put it in the floppy drive
it says non system disk or disk error so i tried another floppy disk i had an that formatted without the cant use system disk error message showing up
i then put that disk in the floppy drive and that works fine
my question is why the first disk i formatted came up with that error message and why the second disk i formatted didn't come up with the error message
if anyone knows could you let me know as i have no idea why its happening
Reply 13 of 158, by myne
Age is enough of a reason.
But just to rule it out, it's not write protected..?
I built:
Reply 14 of 158, by Capsndave
Hi. I've read the thread. I think you need to take a step back. The fact that you have it working to an error message is good. This indicates that power supply and motherboard are working. You should be able to get into the CMOS even if the the battery isn't working. The battery issue can be corrected and should be separate to the errors you are seeing. Epson set up discs don't really do a whole lot other than install dos so you should be able to get by without them. Firstly I think you should check the functionality of your floppy disks, are they any good? Then check the floppy drive. Is it working correctly? On other Epson models they use a standard floppy drive so you should be able to swap it out for a known good FDD.
Reply 15 of 158, by wierd_w
Many 286 era systems lack a builtin cmos setup program.
Getting to dos from diskette is necessary, so that something like gsetup can be run, instead.
Reply 16 of 158, by Capsndave
Try a 3 1/2 inch drive in stead of the 5 3/4'' drives
Reply 17 of 158, by wierd_w
It's true that a 720kb diskette drive (and disk) can be 'treated like' a 360kb diskette drive, by confused bioses.
Even reformatted as 360kb even.
If it came down to that, that *is* a possible option.
Reply 18 of 158, by wierd_w
I have been helping the OP via DMs for awhile now.
They have gotten the IDE card, and it successfully starts the rombios on board, as of the last DM I recieved.
They are reporting that their compact flash adapter is hanging during detection.
I suggested that they return to this thread for more eyeballs.
I suspect this to be one of 3 things.
1) Drive jumpered wrong.
2) Noncompliant CF card that's not fully ATA.
3) Incorrectly used ioready pin on the CFCard that needs clipped on the adapter.
But I want more voices, and more eyes.
Edit
Wait. This is the correct OP, .... but not the same thread I remember.
This may need merged. Let me hunt.
Yes, Mods, please merge with this thread.
epson 286 ax2e pc hard drive
In that thread, OP asks about options to install a hard disk. I suggested a 16bit ISA disk controller that has a socketted rom bios.
I have further researched that card, and found that the bios socket is 16kb/32kb selectable, with a configurable memory address (that's a bit strange).
It can live at C800 (32k size), CC00 (16k size), D800(32k size) DC00 (16k size)
I have recommended setting the address to D800. (It defaults to C800, as initially jumpered. I warned about VGA bios conflicts at this address)
I assume OP did so, because the card's bios runs.
The card's ROM suffers the 8GB limitation.
The card is already jumpered for normal primary and secondary IDE controller resources.
Reply 19 of 158, by jude1977
hi just a quick update ive but the ide card in and attached the ch ide card adapter to it in slot ide 1 as shown marked on your picture-digram
the computer starts up and shows the message
Enhanced IDE bios for c1-1050 version 1.05
and then it says scanning IDE buses
but thats all that happens it doesent continue to do anything else ive also tried turning the ide ribbion cable around the
other way but if i do that the pc wont start at all so ive put the ide ribbion cable back the way i first had it
once again it shows the above message so im pretty shure i have the ide ribbion cable the right way
its just it wont continue to do anything just shows the above message
any ideas on what i shouls do or if im doing something wrong
regards jude
