Ultimate Windows 9x PC?
First post, by bitzu101
Hello to all!
I have decided to put one of my pc s in storage... my p3... hence I will replace it with an entirely NEW build.
I have in mind a ultimate / super duper windows 9x build. The ONLY thing that will be a bit newer will be the case... But I have chosen this case because it s beige , already a bit yellow and it s super super sturdy and large. I have pictures of the case... will be fully stripped down , fully cleaned , etc...
As for the build... I would like for the PC to run windows ME as it does away with the dos subsystem loading , it s very snappy and brings a bit of a more modern feel in the way that it looks. I know I will get lots of criticism for win ME , but I already have a windows 98 se pc , fully maxed out.
Motherboard will be the Asus A7n8x v 2.0 deluxe... it s pretty much top of the line nfore 2 ultra chipset , dual channel , etc... btw... if anyone has a 3com win 9x driver for this board... please do share... as it s the only thing that i could not install on win9x for this board when I tested it....
CPU will be the legendary athlon XP 3200+. Nothing more , nothing less... Will par this with a beefy cooler that cand push some air trough...
Ram will be 512MB Micron 400 megatransfers (200 x2) in dual channel mode.
GPU - still thinking a bit... I want to go for a Geforce 6600 GT with 128 mb of ram... as i don t think there is anything windows 9x that this card cannot handle... any other thoughts? maybe you can recommend something else?
Sound card: well... this will be the pinnacle of win 9x cards... the turtle beach Aureal Vortex 2 with A3d2... AU8830... very expansive card... extremely good for the era with real hardware support. Please note that i will not be playing dos games on this as I already have a windows 98 se machine with the ultra compatible ess solo 1....
HDD - 7200 Maxtor Diamon 9 - ata 133
PSU - 500w - CIT with 30A on the 5v rail , specially bought because the cpu requires a lot of 5v amps... i know it s not very fancy , i know it s cheap... but it does have a back mounted fan and that is a MUST because a bottom mounted psu fan would take all the air from the cpu cooler... (in fact... unfortunatelly , there are no more psu's with back fans...)
standard floppy drive , standard , dvd drive...
pc will be built in the next few weeks or so... some components are yet to come... but this is the idea.... I do have the case , will need to start cleaning , etc...
what do you guys think? any thoughts? recommendations?
Reply 1 of 42, by Ozzuneoj
Looks like an awesome build!
Personally, I would use an older graphics card along side an Aureal Vortex 2. The Vortex 2's driver support ended in the first quarter of 2000 when the company shut down, and these cards were best utilized from 1998 to late 1999, so there will be very little crossover with games that make proper use of A3D 2.0 and games that work best on a DirectX 9.0c level card like the 6600GT, which is from late 2004.
If you were using, for example, an Audigy 2ZS then the 6600GT would be a better combination in my opinion.
There are some features used in a rather limited number of games that only work on Geforce FX series and older (see this huge thread for more info), but if you aren't playing those particular games then you don't need to worry about that particular issue. To be honest, most games will probably work okay on the 6600GT anyway, especially if you use somewhat early drivers, but you may run into compatibility or image quality issues that older cards won't have. A higher end FX series or a Geforce 4 Ti series may be more suitable, but if you already have the 6600GT, by all means just use that and don't worry about changing anything unless it causes you problems. Disclaimer: I haven't personally experimented with a 6-series card vs older cards in Win9x games in many years. This is just what I have gathered from various discussions over the years.
Also, if you want to play later games from say 2002-2004 then the sound card's outdated drivers and capabilities may limit you a fair amount.
One final note I would make is that the CPU will probably be fairly expensive for what you get. All of the CPUs from this generation overclocked to near the same level, so it may be cheaper to find an Athlon XP (mobile chips were popular) with a 266Mhz or 333Mhz FSB and then just run it at 400Mhz FSB to overclock to the level of a 3200+ or even higher. A lot of people did this back then. My old Abit NF7-S 2.0 + Athlon XP 1700+ build is still kicking after all these years with the CPU running at 2Ghz, up from 1.47. 😀
Should be a fun build though! Keep us posted.
Reply 2 of 42, by ChrisK
bitzu101 wrote on 2026-06-15, 00:00:
Hello to all! ... PSU - 500w - CIT with 30A on the 5v rail , specially bought because the cpu requires a lot of 5v amps... i kno […]
Hello to all!
https://theretroweb.com/misc/documentation/am … 59160417606.pdf
Read page 8.
Not sure if it's really that important, but that's what AMD says.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 3 of 42, by such
Wouldn't 6xxx have issues with rendering Splinter Cell 1 correctly as well? Too fast and new for me even outside of that particular game, but depends on what you'll be playing, ultimately.
Reply 5 of 42, by RandomStranger
I'm not a fan of GF6 for W98 either. It's not about the features it doesn't support, it's about the games that won't work with the drivers it's supported by. A lot of pre-2001 games glitch out or won't start up at all with drivers more recent then 56.64. And you need more recent drivers for a 6600GT than that. At least 66.94.
Reply 6 of 42, by bitzu101
ChrisK wrote on 2026-06-15, 06:14:
https://theretroweb.com/misc/documentation/am … 59160417606.pdf Read page 8. Not sure if it's really that important, but that's […]
Hello to all!
Read page 8.
Thanks for reply 😀
I already have the Athlon xp 3200+ and I already have a Asus A7N8X deluxe rev 2.0 , nativelly supporting 400 fsb and dual channel , so no worries on this front...
I regards to GPU... I already have a win 98 se machine with a geforce 4 ti 4200... so not looking for a lot of compatibility , this should be a system for after 2000 games till about 2004 ish...
Reply 7 of 42, by bitzu101
Hello to all!
Read page 8.
I see ur point... i disagree with amd on this ocasion even if they might be right. reason is nostagia... i don t remember any pc in that time having a psu with a bottom fan , hence i don t want one 😀
Reply 8 of 42, by bitzu101
such wrote on 2026-06-15, 14:58:
not going for splinter cell , but I could get an FX card if necessary... i have a 6600 gt coming in post , I have another 4200 ti and a few others...
the good thing is , I can always change the gpu if needed....
Reply 9 of 42, by bitzu101
So, got to assembly....
Here are some pics of the hardware assembled.
The Samsung dvd rw is brand new, I have decided to go with 768 mb ram, funny is that 512mb still work in dual channel... The board is a7n8x deluxe but I have a spox high end in the post as well...
I got the hdd today, a 120gb maxtor diamond 9 plus ata 133.... Very proud of it...
The gpu in the picture is a 4200 ti from Asus, but will have a 6660gt in the post soon...
Reply 10 of 42, by bitzu101
And a win me pic as well...
Probably need to re-install at some point, for whatever reason, this win me version (final) does not like to display the boot up logo....
Must say, this is a very very snappy system... 768 mb of ram makes a bit of a difference... The cpu is bang on as well, windows loads very quick.
Think this pc will play most games of 2003... Specially when I get the 6600gt
Reply 11 of 42, by Yoghoo
bitzu101 wrote on 2026-06-18, 09:51:
A reinstall will not fix this issue. So no need to reinstall it to try to fix this.
This is a known problem and (if I remember correctly) has something to do with the video card.
Reply 12 of 42, by such
Recently I needed to install Windows 98 on an S3 and then swap it for my GF4Ti afterwards. GF4 just completely refused to display the installer. Otherwise DOS is fine, Windows (boot logo included) is fine, no issues whatsoever.
Reply 13 of 42, by bitzu101
Yoghoo wrote on 2026-06-18, 10:29:
Thing is , I cannot even find the LOGO.SYS anywhere in the system , and I DEFENETLY did not delete it. also , there is NO MSDOS.SYS as well....
it s the final version on ME , full retail , downloaded from Archive.org
but if it s the case that reinstalling will not do anything , then it s better , because I have managed to install most things that I need for this SO now...
All I need is 1 app: AIDA64 for windows 9x version 7.6 but with a license... cannot seem to find one ...
Reply 14 of 42, by bitzu101
such wrote on 2026-06-18, 10:41:
what is an installer? what are u reffering to?
Reply 15 of 42, by such
I mean the Windows 98 Setup.
Reply 16 of 42, by bitzu101
such wrote on 2026-06-18, 16:52:
never heared of this issue... but there are so many little crappy things in the win 9x era that i am not surprised.
think most people forget that DOS is a 1981 and windows 9x is a dos operating system , just with a fancy interface on top of it...
Reply 17 of 42, by sparki
If this is the case, you might want to look into a sound blaster live or an audigy series card for eax suppport. The aureal vortex is an excellent sound card for windows 98 but as mentioned before it's best for windows 98 era games, it won't offer anything new for the newer games and it might even cause issues
Reply 18 of 42, by nd22
I can confirm that geforce 6600GT will play any game from 2003 era at max details.
Wouldn't 768mb of RAM be too much for Windows 9X?
Reply 19 of 42, by H3nrik V!
nd22 wrote on 2026-06-22, 05:56:
Yes, IIRC the general rule of thumb is no more than 512 megs, but as usual YMMV - I haven't had any issues with a gig of memory on a 440bx board running win 98, but that might as well be coincidental ..
