My three retro builds showcase
First post, by Nick4
Hey guys! Just wanted to share my current retro setup.
Build #3. 2007-2008. Silver Bullet
Every part of this PC was bought new in box. It was a pleasure to build this one. Tried to capture mid 2000s spirit with all the aluminium and those ridiculous 5.25 add-ons.
Specs:
CPU: Core 2 Duo E6750 2.66 Ghz
MB: Asus P5QL-E
RAM: 4 Gb DDR2 Kingston
GPU: EVGA 8800 GTS 512 Mb
HDD: 500 Gb WD Blue + 640 GB WD Black
DVD: Sony NEC Optiarc AD-7173A
Case: Cooler Master Cavalier 1
PSU: BeQuite Pure Power 11 500 W
CPU Cooler: Cooler Master geminII M5 LED
Other: AeroCool GateWatch 2 + Thermaltake Hardcano 3
OS: Win 7 64 bit / Win XP 32 bit
I really should work on cable magement here...
Build #2. 2004. TIE Fighter
I had a similar PC back in 2004. AMD Socket A, nForce. Beautiful purple ECS mother board. Budget specs, but gets the job done. Partly NOS.
Specs:
CPU: AMD Sempron 2500+
MB: ECS Elitegroup N2U400-A rev. 1.0
RAM: 512 Mb DDR
GPU: Gigabyte ATI Radeon 9600 Pro 128 Mb AGP
HDD: 40 Gb Seagate + 80 Gb Maxtor
CD: Samsung SC-152
Case: Unknown Multimedia PC ATX Case
PSU: Cooler Master RS-380-PMSP 350 W
CPU Cooler: Speeze Socket 370/A cooler
OS: Win XP 32 bit
Build #1. 1997-1998. Boombox
I have a topic about this one: 1997 Pentium MMX Rebuild
Specs:
CPU: Intel Pentium MMX 233 MHz
MB: Asus TXP4 Motherboard
RAM: 32 Mb
GPU: S3 Virge DX + Diamond Monster 3D II 3Dfx Voodoo 2 8mb
Audio: Creative SoundBlaster AWE64 ISA
HDD: 4 Gb Seagate Medalist
CD: Asus CD-S520/A5
FDD: NEC 3,5"
PSU: Super AT 200 Watt
Case: AT Desktop Multimedia Case
OS: MS-DOS 6.22 + Win 98 SE
Reply 1 of 26, by RetroPCCupboard
The specs sound great. Though I can't see any of the images. That host doesn't show them in the UK. Quite a big jump in performance between the 2nd and 3rd builds. I feel like a Pentium III in between would slot in nicely.
Reply 2 of 26, by keenmaster486
That AT case looks really cool. I have one of those Apex badges on my 486.
World's foremost 486 enjoyer.
Reply 3 of 26, by TELVM
Very nice cases. The first picture with all of them together is awesome. 👍
Let the air flow!
Reply 4 of 26, by Irinikus
Very Nice Systems!!! 😀
YouTube
Reply 5 of 26, by dr_st
Nick4 wrote on 2026-08-07, 20:05:
Beautiful system. Silver-bezel optical drives were quite uncommon, congrats on getting one.
Is it really 24C everywhere inside? 😀
I think you succeeded. My Thermaltake Lanmoto came with a HardCano 10, and the first PSU I had in it was the Thermaltake Butterfly with its own fan controller. That one was so ridiculous I was almost relieved when the PSU had died and I replaced it with something simpler.
Reply 6 of 26, by Nick4
RetroPCCupboard wrote on 2026-08-07, 21:17:
Thanks! Thats strange... Here I'll attach some images to this post.
Actually, the AMD build should be a PIII build, but change of plans happened=)
Reply 7 of 26, by Nick4
dr_st wrote on 2026-08-08, 12:20:
Beautiful system. Silver-bezel optical drives were quite uncommon, congrats on getting one. Is it really 24C everywhere inside? […]
Yeah, I was lucky to get a boxed version of the drive with black, beige and silver bezels included. It's not 24C =) I was lazy to connect the sensors, so it shows the temperature inside the case. I just turned it on, so it was 24c=) Also, it has very simple thermal sensors that connects to radiators, so it is not a very useful info. Just a ridiculous gimmick.
You have a nice system too, I remember these Thermaltake cases were extremely popular but pretty expensive.
Reply 8 of 26, by Nick4
Thank you guys! appreciate your feedback!!
Reply 9 of 26, by AlexZ
Pentium 233 could use more RAM. I had 64MB RAM back then. You will get much better seek times from a more modern IDE drive (120-80GB) by limiting its capacity to 32GB or less.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 10 of 26, by dr_st
Nick4 wrote on 2026-08-08, 15:09:
What happened is that I built a Pentium 4 HT system back in 2004 not knowing anything about cases. Then the default case I got was such a piece of junk that I started researching the recommendations on the web at the time and cross-referencing it with what I could actually obtain in my neck of the woods for a reasonable price. I recall the Lanmoto was one of the only options. I was sold on its "tool-less" feature, which, of course, I later learned, was on the low-end of how tool-less cases go, but back then it was OK, I guess. One time I removed the side panel too harshly and ripped the cable of the side fan, so I took the opportunity to replace it with the blue LED variant fan of the same dimensions, and even an original Thermaltake part at that.
Reply 11 of 26, by RetroPCCupboard
AlexZ wrote on 2026-08-09, 08:19:
Maybe, but some games don't like too much RAM. Alien Trilogy for example works with 32Mb, but won't even install if you have more. There are workarounds of course with RAM drives etc.
Reply 12 of 26, by Nick4
dr_st wrote on 2026-08-09, 12:41:
Back in that days, I was into server/workstation aesthetic, so I had a huge tower from Cheiftec for absolutely no reason. I believe those Thermaltakes cases share same chassis.
Reply 13 of 26, by Nick4
I mostly use this build for late DOS / early Win games, so 32 Mb is OK. But I consider to upgrade.
Reply 14 of 26, by dr_st
Nick4 wrote on 2026-08-10, 11:34:
Quite possible. Years later I found myself assembling another retro PC based on a HEC 6A series case, and I was quite surprised to find out that the innards (down to the drive cage, fan holders and tool-less drive/slot options) were identical between that and the Lanmoto. It seems that many case manufacturers ordered the same chassis from whichever ODM produces it and slapped their own custom front panels/doors / side panels / decorations. This applies to a few other Thermaltake cases like the Tsunami, and maybe some Chieftec products as well.
Reply 15 of 26, by SlowA
Looks great, well done.
Reply 16 of 26, by H3nrik V!
I'm embarrassed at myself that I didn't see the Tie fighter shaped front bezel before reading the name of the system 🤣 luckily I can't unsee it now 😎
Reply 17 of 26, by Nick4
H3nrik V! wrote on 2026-08-14, 09:04:
Hahaha. Yep, once you see it... weird design, but I like it=)
Reply 18 of 26, by Nick4
Adding some unboxing pictures for 2007-2008 Silver Bullet Build. I just love NOS hardware.
Reply 19 of 26, by dr_st
Nick4 wrote on 2026-08-16, 20:27:
Adding some unboxing pictures for 2007-2008 Silver Bullet Build. I just love NOS hardware. […]
Where did that Pentium 4 HT go? 😁
