First post, by Brawndo
For those of you who like to build period correct systems (i.e. dream PC and all components from 1998) how do you choose the name of the PC? Since I am accumulating quite the pile of components and have built several already, and planning to build even more, I've been thinking how I'm going to name those PCs, for inventory purposes and just for identification. I know the name doesn't mean anything as far as the network goes (unless doing that good old serial connection or local LAN gaming) but I'm OCD about organization so my systems have to have a meaningful name, and also it's just fun. I've been thinking about coming up with a name based on important pop culture news or events that year or period of time, example, one of my later systems is a socket 775 build with 2008 components, and I've thought of naming it "BEIJING_GOLD" or something like that, because the Beijing summer olympics were that year and Michael Phelps set the record for swimming gold medals.
Just curious what others have come up with for names.
Reply 1 of 18, by leileilol
Can't go wrong with identifying with a "namefirstletter+CPU+clock" name on the network. so if you're steve and you got a pentium 66 you can name it Spentium67. Yes that is "period correct"
long live PCem
Debian's fucked
Reply 2 of 18, by Lylat1an
I only have one system for playing games on older operating systems.
I call it my "Retro Rig". :)
Reply 3 of 18, by SlowA
By their sockets (Socket A...) mostly.
Reply 4 of 18, by CharlieFoxtrot
I generally don't name any of my systems and some of them are big brand systems with model names anyways (like Compaq Prolinea 4/50 for example), but for something like my late 90s and early 2000s Athlon builds I use for example "early 2000 build", "autumn 2001 build" or "mid 2003 build". They are not names, just dates that highlight the differences.
Reply 5 of 18, by Errius
Everything that isn't a CPU or memory module gets a name, typically like TOSHIBA5 or SAMSUNG4 (both hard drives)
The "computer name" is the name of the motherboard, so that replacing the motherboard changes its name but moving it to a new case doesn't. (My file server over the years has had several names, but it's always been in the same case, a big Cooler Master Stacker.)
(On big systems with multiple boards, the board which the CPU plugs into is considered the motherboard.)
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 6 of 18, by Big Pink
I always like a good pop culture reference.
Tuvix
A build centered on an ASRock 775i65G board. That's LGA775 with AGP 8x - the best of two worlds, if you will.
Brundlefly
The opposite. An ASRock P4i945GC combining PGA478 with PCIe. It does have the ability to run a 64b SL7QB going for it, though. If I stick in my old HD4850 I can turn off the heating for winter.
I thought IBM was born with the world
Reply 7 of 18, by bloodem
PC-A01, PC-A02, PC-A03, etc: these are the builds that I keep in my local storage.
PC-B01, PC-B02, PC-B03, etc: these are the builds that i keep in my hometown.
And I also keep an updated database with the build specs, pros & cons for each build, benchmark results, issues I’ve encountered and how I’ve solved them, etc.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 8 of 18, by TadeusTaD
I usually go with whatever is fitting or otherwise easy to associate with the specific build timeframe, barring some line-of-sight-names (like the infamous case of Intel's "Batman's Revenge"), going either with a popculture reference, or by a distingushing mark of the specific buid.
Reply 9 of 18, by BitWrangler
Go on a usenet archive circa 1993 and you might notice by careful inspection of sig lines and comments that there are three choices...
LOTR
StarWars
Greek Mythology.
Which is probably why global DNS was invented, imagine the sheer kerfuffle if admin@skywalker.199.112.1.1 got a message intended for admin@skywalker.199.121.1.1
Reply 10 of 18, by leileilol
Mst3k was also big among usenet, at least one person must have named their computer Mitchell...
long live PCem
Debian's fucked
Reply 11 of 18, by Law212
I call them "pentium 1 , 486, other 486, second pentium, pentium 3 and pentuim 4"
Reply 12 of 18, by appiah4
I tend to pick an architecture name and a period for them, ie i486 1991-1993 Build, etc.
My daily drivers are not period correct and named Lightning, Firestorm and Avenger..
Reply 14 of 18, by Brawndo
Early on in my IT career I used to name servers after WWF wrestlers. I had servers named Hogan, Savage, Warrior, Bundy, etc, maybe I should get back to that.
One of the organizations I used to work for named their servers after Walking Dead locations, but I was always concerned they'd run out of names. I also said I'd be concerned about bit rot...
Reply 15 of 18, by BitWrangler
I am kinda random, I intend to have a theme/system but everything just temporarily permanent, so just use a name to help me remember what machine it is. Like one Acer laptop that was cobbled together and barely working was AssPyre, because it was a flaming pile of ass.
Reply 16 of 18, by douglar
With the suffix “Luvin” wherever possible.
Reply 17 of 18, by AlessandroB
I only have IBM branded pc. i use their name: Pc330DX2, Netvista ecc ecc
Reply 18 of 18, by lepidotós
I only have one that I have a name for and I haven't even built it yet, the name is just the concept rephrased slightly to sound kind of like what the '90s considered cool — "Futuresight". Basically it's just all the stuff from 1996-97 that would turn out to be more like modern stuff than the competition, so like ATX-K5-Rendition V2100 (V1000s are too expensive)-Windows NT/Linux dual boot. I guess if you include laptops I do have Cloud 9 which is my iBook G3 I bought for OS 9... for however period correct single-booting 9.2.2 on a 900MHz G3 is.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
