Reply 20 of 155, by The Solutor
Yepp!!!
It works on W7 and fixes the magnification problem in W8.1 (I assume W8 will work as well)
Two birds with one stone... 😀
Yepp!!!
Hey, cool I see you added native dpmi support. What was the reason to add this? DPMI was the most painful to get right for me and dosbox chose to remove it. Of course I can't run dos programs with IOPL=3 which is the principle part that turned it into a nightmare. I checked your DPMI isn't working properly with borland c and jazz jackrabbit (16 bit borland based dos-extender which is weird and expects different dos/bios calls to be auto translated if I remember correctly).
I got some way to try boot RetroOS in rust-dos. Unfortunately rust-dos doesn't expose an ATA so RetroOS doesn't find a disk to mount and doesn't boot further. Currently only bios int 13 is supported for directly reading an image, feature request 😁
Also my fat image is fat32 which rust-dos doesn't support. Another feature request.
Updates! v0.8.0 is available on https://rust-dos.com
Here's a brief list of the most important new features:
v0.7.0
v0.7.1
v0.8.0
Trumpet Winsock on Win3.x support only covers the NE2000, not dialup.
I should note that the networking is not compatible with dosbox or physical PCs. I was never a fan of having to faff with promiscuous mode and special system libraries. On the plus side breaking compatibility means more features like password protection and internet lobbies without the need to do port forwarding. If you do need to network with physical machines or dosbox instances, I think Dosbox-Staging or Dosbox-X is the logical choice for that.
If you just want to play multiplayer games with minimum effort, create a lobby, have the others join, and start your game.
One last thing: traffic is not encrypted, even via the internet.
gsos wrote on 2026-09-28, 05:57:Hey, cool I see you added native dpmi support. What was the reason to add this? DPMI was the most painful to get right for me and dosbox chose to remove it. Of course I can't run dos programs with IOPL=3 which is the principle part that turned it into a nightmare. I checked your DPMI isn't working properly with borland c and jazz jackrabbit (16 bit borland based dos-extender which is weird and expects different dos/bios calls to be auto translated if I remember correctly).
Some games and programs require it. Also, both Borland C and Jazz should work now - I was missing the MS-DOS vendor API and the int21h passthrough.
gsos wrote on 2026-09-28, 05:57:I got some way to try boot RetroOS in rust-dos. Unfortunately rust-dos doesn't expose an ATA so RetroOS doesn't find a disk to mount and doesn't boot further. Currently only bios int 13 is supported for directly reading an image, feature request 😁
Funny thing that... I actually implemented fat32 for dosbox-staging at https://github.com/dosbox-staging/dosbox-stag … ds/fat32support but at the time there was no real reason for the project to pick it up. So this and ATA is on my list for sure!
Dividebysandwich wrote on 2026-09-28, 12:10:Updates! v0.8.0
I confirm the generic AMD64 version fixed the windows magnification problem in W8/2012 and W8.1/2012R2
Wow. Can’t wait to give this a try.
What kind of hardware is needed to do 486 + Voodoo emulation?
BinaryDemon wrote on 2026-09-28, 15:32:What kind of hardware is needed to do 486 + Voodoo emulation?
It's probably a bit more power hungry compared to dosbox-x since their implementation had a lot more time in the oven. There's also always a chance that specific games perform much more poorly because they use certain instruction sequences that kick the dynamic recompiler out of optimizations or are simply recompiled into long loops of inefficient code. For example I had the problem that floor rendering in Heretic caused a huge amount of overhead. Such cases then have to be analyzed and fixed for the particular game in question. Unfortunately there's no one size fits all solution, at least none that I know of.
I haven't really benchmarked Voodoo between Rust-DOS and Dosbox-X yet either - I was more focused on getting things working, optimization will come in the next step.
Dividebysandwich wrote on 2026-09-28, 12:15:gsos wrote on 2026-09-28, 05:57:Some games and programs require it. Also, both Borland C and Jazz should work now - I was missing the MS-DOS vendor API and the int21h passthrough.
Which games?Dosbox doesnt need it, what makes rust-dos different?
gsos wrote on 2026-09-28, 19:05:Which games?Dosbox doesnt need it, what makes rust-dos different?
I think I first encountered this with the demo "Luminous" by scoop (https://www.pouet.net/prod.php?which=6279)
Here's dosbox-staging also failing with the same error:
Again, if it causes problems, it can be disabled even without restarting the emulator, you just have to sit at the prompt.
@BinaryDemon:
I did some benchmarking of the Voodoo implementation in software mode. The big difference is that Rust-DOS Voodoo emulation supports up to 4 worker threads.
With one worker thread to match Dosbox-X, Rust-DOS is about on-par. It's has about 10% faster pixel fill rate, it's 20% slower on triangles, but framebuffer writes are almost twice as fast.
With 4 worker threads (which is the default), Rust-DOS is faster across the board: pixel fill rate is over 4 times faster, triangles are 2.5 times faster, framebuffer is 1.7 times faster. My guess is the synchronization overhead actually lowers the framebuffer score. There was no difference between DOS and Windows.
On GPU however, Dosbox-X's fill rate is over 70 times faster, triangles are 15% faster, while framebuffer writes are three times slower weirdly enough. The 70x advantage for Dosbox-X is because I essentially always fill in software.
TLDR: In software rendering and default settings, the Voodoo in Rust-DOS is a lot faster than Dosbox-X. If you have a GPU, the situation is reversed and Rust-DOS gets essentially roflstomped. But that's something I can work on.
Note that this is Voodoo performance only. Game performance still varies because of the different implementations. If you have a favorite game that runs terribly in Rust-DOS please let me know.
Tombraider, after the 3Dfx logo shows just a black screen, maybe it's just the blink video intro that breaks things.
In VMware (differently than Vbox) the black screen is a thing as well, but there just pushing ESC twice is enough to skip the invisible videos, and go straight to the game, which then works perfectly.
Here ESC does nothing, and a blinking cursor is the only sign of life.
Edit, the above applies to W8.1, retested from Win10 seems working perfectly.
@The Solutor: I also can't reproduce this on Linux. I downloaded the CD version and it seems to work fine. Looks like another windows version specific problem 😒
Dividebysandwich wrote on 2026-09-28, 21:36:@The Solutor: I also can't reproduce this on Linux. I downloaded the CD version and it seems to work fine. Looks like another wi […]
I've spent the last half hour trying to understand what was going on.
W7, OK W10 OK, W8.1 KO both AMD64 generic and W7 version.
So I restored the GPU driver I changed yesterday for the magnification problem, still no dice.
At the end I went the Linux way, deleted the rust-dos.conf file and started from scratch. Problem fixed. Not sure what was wrong in the old one, I played from the GUI with all reasonable options, unsuccessfully....
Speaking of which, I humbly suggest an improvement: Make the program to check for rust-dos.conf in its own directory.
If the file is there, use it.
If the file isn't there look in the user's profile, and eventually create one (the current behavior)
This way the program can be either portable or normal, w/o much troubles.
The Solutor wrote on 2026-09-28, 21:51:Speaking of which, I humbly suggest an improvement: Make the program to check for rust-dos.conf in its own directory.
Good idea. Will do!
Dividebysandwich wrote on 2026-09-28, 22:07:Good idea. Will do!
Thanks, I believe it doesn't require much additional coding, while adding a good feature in return.
v0.9.0 is out! -> https://github.com/dividebysandwich/rust-dos/ … ases/tag/v0.9.0
I got something cool coming up in the next version!
One thing that always bothered me was the "auto" setting for cycles. On one hand it was way too slow for games like F117 since it simply chose a very low number, on the other hand it went straight up to max while playing Descent which makes that game unplayable.
So I implemented a control loop that checks the actual rendered framerate. This results in both extremes to work really well, and it prevents situations where the host CPU usage got excessively high for no good reason.
Also both realmode and protected mode performance is going to improve well beyond both dosbox-staging and dosbox-x.
A combined CPU benchmark that took 6.4s to complete now finishes in 3.95s, while dosbox-staging needs 5.1s and dosbox-x took 4.9 seconds.
Heretic timedemo took 31.2s before, now 21.6s. dosbox-staging takes 23.5 and dosbox-x 22.5s.
This looks fantastic. Can't wait to see the next release.
Also, you made Spoonbot for Tribes? That brings back some memories.
jh80 wrote on 2026-09-30, 13:49:Also, you made Spoonbot for Tribes? That brings back some memories.
Oh wow you found that? Guilty as charged. Tribes was such an amazing game, way ahead of the times. 64 and even 128 players in one map. I loved the mods where there was a focus on base construction stuff.
@Dividebysandwich
Can you take a look to those MC executables?
Re: Midnight Commander
They are windows executables that work in real dos using hdmpi32 / hx loader or similar, and after a bit of work by @gsos they work as well in RetroOS natively, at least the first download called just MC.zip
I don't understand if I'm doing something wrong, but I cant get MC running on Rust-DOS
Not a drama given VC works, but would be still a nice to have, also in RustDOS.
Thanks
