First post, by dreamblaster
I made a new waveblaster board, PicoPango
available soon at https://serdashop.com/products/picopango
EDIT:
It features several synth engines (still working on more) :
  • Wave based synthesis (GU-Wave, Pocket)
  • FM synthesis (FM Classic, FM Classic FX)
Features :
  • Switch easily between engines, using the Pangoset utility.
  • 48-voice polyphony, all 16 MIDI channels
  • USB-MIDI, class compliant: no drivers needed on Windows, macOS or Linux
  • 3.5 mm stereo line out
  • Compact PCB : 34mm x 34mm
  • High quality Stereo DAC
  • Powered from the sound card or from USB
  • Easy firmware updates over USB: drag and drop a file (RP2350).
The attachment PicoPango_connections.jpg is no longer available
The attachment PicoPango_front_wb2.jpg is no longer available
Demo of 'Pocket' synth : https://youtu.be/TrJM8KsrYKk
Demo of 'GU-Wave' synth : https://youtu.be/3nDtdRAQKwo
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 17, by keropi
mmmm fresh wt 😁
will add it to the ever growing collection !
Reply 2 of 17, by Angus.Young
Looks great.. will Grab one from SerdaShop when available.
Reply 3 of 17, by SuperDeadite
Looks fun, but what is GU-Wave? Searching for it just gives me AI slop about the standard Microsoft Windows GS soft synth....(dead internet theory is real!)
Also, which FM source is this modeled from?
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 4 of 17, by NeoG_
SuperDeadite wrote on 2026-09-30, 00:01:
“GU-Wave” is the name of the mode on the PicoPango that uses the GeneralUser GS soundfont
Reply 5 of 17, by dreamblaster
NeoG_ wrote on 2026-09-30, 00:15:
yes it is a wave based synth engine, that uses GeneralUser GS samples as a basis. it is not literally an sf2 soundfont player, but it uses the same samples and loop points.
Reply 6 of 17, by igna78
A really interesting wavetable module... fantastic!
OT: any news on the mixer that was in development?
Reply 7 of 17, by NeoG_
dreamblaster wrote on 2026-09-30, 09:09:
Are there any features that had to be dropped from the GUGS soundfont to fit into the Pango?
Reply 8 of 17, by dreamblaster
NeoG_ wrote on 2026-09-30, 12:46:
All instruments are there, including all 13 drum kits. To fit in flash every sample is stored with ADPCM compression, mostly at 22 kHz (cymbals and hi-hats at 32 kHz), and a lot of it was tuned by ear on the hardware. It runs on my own engine, not FluidSynth — simplified, but the instruments, layers, envelopes and drum kits are all there, with 48 voices of polyphony plus reverb and chorus. Compared to the SoundFont on a PC it sounds a little warmer and grittier, more 90s. It is based on GeneralUser GS samples but it doesn't sound identical.
Reply 9 of 17, by dreamblaster
I had developed different synth engines and am still testing what will be in picopango, as i want to combine multiple engines for more choice.
so for now i change the specs to 'multiple engines' -- will update soon with the final descriptions.
Once it is more finalized, i will also record some demos. (too busy right now)
Reply 10 of 17, by FreddyV
I was suppose to write its firmware, but Serge did it (I was too busy on the PicoMEM 2)
Some of it may be back ported to the PicoMEM 2 (I hope)
Reverb ?? 😀
Reply 11 of 17, by M-HT
Is this the result of PicoRhino project or is PicoRhino still in the works ?
Reply 12 of 17, by dreamblaster
PicoPango is a first synth release, based on the same development. PicoRhino is still under development (may take much more time as i plan to add some more features)
See a first PicoPango demo here : the new 'Pocket' synth engine, playing Orcs theme 1 from Warcraft 2 : https://youtu.be/TrJM8KsrYKk
Reply 13 of 17, by digger
Cool little device. 🙂 Congrats on bringing this to production.
Are there any plans for adding support for L/A synthesis to it, specifically emulation support for the Roland MT-32 and CM-32? Perhaps by porting Munt to it?
Reply 14 of 17, by zaphod77
Any chance at programming a full AWM2 engine into something like this?
Reply 15 of 17, by dreamblaster
PicoPango demo of GU-Wave engine playing Orc Theme #1 : https://youtu.be/3nDtdRAQKwo
Reply 16 of 17, by DevanWolf
I am curious; is the Pocket bank a port of the SONiVOX Embedded Audio Synthesis?
Reply 17 of 17, by dreamblaster
DevanWolf wrote on Yesterday, 15:32:
Yes !! (as you can also see in the user manual)
