First post, by dreamblaster
SerdaVision - 8-bit ISA video card with HDMI output
An 8-bit ISA video card for IBM PC compatibles, from the 5150/XT to Pentium-class machines. A Raspberry Pi RP2350 functions as the video chip: it emulates the original hardware in firmware and outputs HDMI. One firmware file holds multiple video standards; the card runs one at a time, selected from DOS or with an on-screen menu.
Available for pre-order at https://serdashop.com/products/serdavision-hdmi
First orders can ship now already.
Firmware 1.00 release is ready
Video standards supported
  • VGA
  • EGA (256 KB)
  • CGA, Hercules, MDA
  • VGA-XT and EGA-XT for 8088/V20 machines
  • SVGA: VGA + VESA 1.2, up to 800x600x16 and 640x480x256, 320x200 hi-colour, optional ET4000 mode
  • Experimental: Plantronics ColorPlus, Olivetti PC1 (V6355D), Tandy 1000/PCjr, Hercules InColor
Specifications
  • Bus: ISA 8-bit, fits 8- and 16-bit slots, 4.77-8.33 MHz (12 MHz reported working)
  • Screen memory: up to 1.9 MB/s write and 1.5 MB/s read with zero-wait-state (0WS) on supporting chipsets such as the Intel 430HX; up to 1.1 MB/s without
  • Video memory: 256 KB, 320 KB with the VESA modes
  • Output: HDMI, 640x480 at 60/70 Hz, 800x600 at 56 Hz; analog VGA via a powered HDMI2VGA dongle
  • Settings, kept in flash: scanlines, phosphor colour, aspect, refresh, composite colour model (CGA)
  • Power from the slot or USB-C; firmware updates over USB-C
Limitations: 8-bit ISA slot only;mid-frame palette changes are not shown; no light pen.
Availability and price: see https://serdashop.com/products/serdavision-hdmi
Pre-orders will take approx 2 weeks to ship.
I have a few cards to ship directly, PM me if you want priority early access.
The attachment serdavision-pcb.jpg is no longer available
The attachment serdavision-bracket.jpg is no longer available
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 2 of 48, by darry
That looks really nice.
The ability to output direct composite video for CGA is the only thing not present that I would have liked to see on something like this. To be fair, I can imagine why that might have been deemed out of scope for the envisioned use cases.
Reply 3 of 48, by keropi
looking good!
regarding the composite output, I believe it is already supported
Reply 4 of 48, by dreamblaster
here's a photo of my screen : Doom, with the on screen menu, scanlines set to 1/8
on screen menu is operated by a button on the bracket, or button connected to a header (you could use your turbo button or reset button as well if you like)
The attachment 20261026_215248.jpg is no longer available
Reply 5 of 48, by Hezus
Awesome!
How do the VESA modes allocate the extra 64 kB on an 8 bit card? Is it taken from system memory?
Visit my YT Channel!
Reply 6 of 48, by dreamblaster
Hezus wrote on 2026-10-26, 21:44:
Awesome!
No system RAM is used—it dedicates 320 KB of the RP2350’s internal SRAM for video, when needed.
Reply 7 of 48, by darry
keropi wrote on 2026-10-26, 20:33:
looking good!
I meant to an actual TV/monitor with composite input.
Is that what you meant ?
Reply 8 of 48, by dreamblaster
darry wrote on 2026-10-26, 21:59:
looking good!
that is not supported, it is composite emulation on hdmi
the card only has hdmi output
Reply 9 of 48, by NeoG_
It's not often you open up the store page and the product costs less than you thought it would be
Reply 10 of 48, by dreamblaster
Here are some photos of Serdavision in CGA composite mode, on my XT computer
Space Quest 1 :
The attachment SQ1_XT_COMPOSITE_1.jpg is no longer available
The attachment SQ1_XT_COMPOSITE_2.jpg is no longer available
King's Quest 1 :
The attachment KQ1_XT_COMPOSITE_1.jpg is no longer available
The attachment KQ1_XT_COMPOSITE_2.jpg is no longer available
Here you can see the settings used for KQ1 composite :
The attachment KQ1_XT_COMPOSITE_3_SETTINGS.jpg is no longer available
Reply 11 of 48, by dreamblaster
Some testing with Alleycat
The attachment ALLEYCAT2.jpg is no longer available
The attachment ALLEYCAT1.jpg is no longer available
The attachment ALLEYCAT0.jpg is no longer available
Reply 12 of 48, by NeoG_
Given how much interest there was in the CRT terminator, I'm honestly surprised this hasn't been getting more traction
Reply 13 of 48, by Cyberdyne
You say 9x16 vs 8x16 or height 8x8. Text mode.
So it has MCGA text mode?
Reply 14 of 48, by darry
NeoG_ wrote on 2026-10-29, 22:33:
This board has been living rent-free in my head for a while and has given birth to a build idea.
So, if I do buy one, it will likely be for a "ship of Theseus" type build where I would want to combine it with a PicoGUS and as many newly made plugin substitutes for old hardware that are designed to conform to older standards and as few actual vintage/retro parts and components as possible and keeping it as modular as possible (everything in a single FPGA or running in emulation on an SOC would feel like cheating in this case).
Reply 15 of 48, by Ozzuneoj
darry wrote on 2026-10-30, 05:25:
That's a cool idea. I can't say I've ever seen anything like that before.
I can't afford to build such a thing any time soon, but my mind is going through all the possibilities now...
A modern-built retro motherboard (maybe something like this).
Some kind of hard drive sound simulator, like this.
GOTEK for floppy and maybe an IDE\CD emulator as well.
SerdaVision HDMI for video
As many modern ISA sound cards as you can find.
Put it all in a Silverstone FLP02.
... would be a very cool project. 😀
Reply 16 of 48, by dreamblaster
Cyberdyne wrote on 2026-10-29, 23:11:
Yes: 8x16 (640x400, as MCGA) is the default, and 9x16 (720x400, as a real VGA) is a possible setting in the latest firmware.
so both are possible
Reply 17 of 48, by darry
Ozzuneoj wrote on 2026-10-30, 06:32:
That's a cool idea. I can't say I've ever seen anything like that before. […]
All I need is time and money.
The former is harder to source than the latter.
Reply 18 of 48, by dreamblaster
now also VGA 9 dot font is supported,
and additional 'phosphor' color 'plasma'
Reply 19 of 48, by keropi
I have been playing with the new fw on my beta board, it works very well 😁
the plasma and amber modes bring back memories...
