First post, by llamafarmer2
Hey all
Had an issue (still do really) with a matrox mystique 220 that i'm working through. Thought it was a PINS issue but turns out it wasn't but in the process i made 2 tools that somebody eventually might find useful and thought Vogons is where it belongs (or gets scraped from)..
Matrox Pin Generator - a tool that allows you to pick the type of card you have and modify/create the pins.txt file to use with PROGBIOS. Scraped around most of the info i could find on what each value actually means but some are still missing. Basically go in and change to values you want (eg serial, ramdac, speeds, etc) and it will generate the .txt file to load into the card with the FW using PROGBIOS (PROGBIOS -i xxx.bin -s pins.txt). Its still pretty bare but got me past the problem i had so hopefully people will either use it or add cards that are missing (tried the compaq oem mystique 220 and it worked to a degree). HTA and DOS version available (didnt use the dos one but its there just in case, so untested).
Matrox ROM Dumper - like it says, tool to dump the ROM from these matrox cards. Can either pick or let it try and find you card and will dump it into a .bin file. Was doing a check as i believe my rom got corrupted and used it to do a comparison to the files in the setup349 package. DOS only unless somebody wants to change that.
Attached but also links in case you want to actually make it good/better.
PIN Generator : https://github.com/RealLlamafarmer2/MatroxPINGenerator
ROM Dumper : https://github.com/RealLlamafarmer2/MatroxROMDumper
Made with Claude AI (i'm not a good programmer but i can type/yell at a monitor to get what i want) just in case people were wondering so i wont take credit..
I also sent an email to Matrox themselves as a shot in the dark asking them if somebody there knew what the parameters in the PINS file meant (or if its sitting on a floppy in a drawer of the guy thats been working there for 30 years).. I'm assuming it will be a bugger off reply but worth a shot so if i do hear back i'll update..
Reply 1 of 2, by llamafarmer2
llamafarmer2 wrote on 2026-11-02, 08:37:
Hey all […]
Hey all
No Luck on getting this from Matrox (see email.jpg)
Reply 2 of 2, by analog_programmer
Not everyone has QBASIC, so I compiled PINEDIT.EXE executable for DOS by using mS-PDS 7.1:
BC PINEDIT.BAS,PINEDIT.OBJ,NUL /O /Ot /FPa /Fs /E /X
LINK /PACKC PINEDIT.OBJ,PINEDIT.EXE,NUL,,NUL
The /E and /X switches are needed for proper compilation and /Fs is essential for the program to work.
Works fine, but <F6> seems to do nothing, except showing some warning about "Expert mode".
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
