First post, by Sandy
i have XP Pro SP2 and i want to install Destruction Derby.
If I the DOSbox use come the following error...
"MSCDEX needed to Install the game"
if i mount my cdrom, i write
"mount g g:\ -t cdrom -ioctl"
the following message comes
"MSCDEX istalled"
"G: mounted for CDrom"
but it doesnt work.
who can help me ?
PS: plz write your text in easy english. U can see my English is very bad 🙁
Thx guys
Reply 2 of 5, by LoneLines
try:
"mount d g:\ -t cdrom -usecd 0 -ioctl"
"d:"
"install"
this *should* work, though I did encounter a game that refused to install this way in DOSBox...
LoneLines list of workarounds for various games in DOSBox:
http://ADogsBox.jellofishi.com
Reply 3 of 5, by Sandy
"d:"
"install"
this doesnt work also 🙁
look at the attachment... i have taken a screenshot from the error msg
If u want to try it self, so u can download the game hier ( 9 MB large)
http://rapidshare.de/files/15131053/derby.rar.html
    49.48 KiB
Reply 5 of 5, by Jiri
You can install the game in CVS of DOSBox
http://cvscompile.aep-emu.de/dosbox.htm
But if you have only the version from rapidshare, it will not run anyway after installation, because it needs CD in drive. You may try to find another version or no-cd patch, then the game should run in DOSBox, but it will be probably slow. You could also try to run it in XP with VDMSound.
