Reply 21 of 256, by DosFreak
Here's a present for anyone that cares.
I looked around for a newer build of Opera and found 10.70 Build 3488
Following the below procedure I was able to run this on 95 and NT4 and browse TLS 1.2 sites without a proxy which 10.63 cannot do.
http://danika.jukor.net/opera1063win95.html
Still going through the newer builds.
Make your games work offline
Reply 23 of 256, by aqrit
Known Bugs: Nothing reported yet
I'm very surprised this doesn't crash and burn by way of an unbalanced stack.
At best, renaming "DuplicateTokenEx" to "DuplicateToken" causes the function call to always fail.
Renaming "InterlockedCompareExchange" to "InterlockedExchange" seems like a bad idea™.
Reply 24 of 256, by DosFreak
Agreed although it seems that whatever is using this functionality isn't necessary when browsing in Windows 95 since it seems stable enough. Wish the source was available. Need to look into wrapping these.
Reply 25 of 256, by DosFreak
rmay635703 wrote:
Speaking of proxy are there any 3rd party hosted WRP style proxies that convert modern web content without special software that won’t work on vintage hardware anyway
Haven't found anything except WRP yet. It does look like it's still in development with the additon of sslstrip so there's hope.
Reply 26 of 256, by DosFreak
Here's the last Opera build compatible with NT4. 1070 build 9071
    1070-9071_modified.zip
    13.22 MiB
    295 downloads
Reply 27 of 256, by DosFreak
NT 3.51, Opera and depends
http://www.nucia.eu/forum/archive/index.php/t-29983.html
https://web.archive.org/web/20130224145538/ht … apshot/windows/
https://www.kyleabaker.com/goodies/opera/down … a-downloads-win
Reply 28 of 256, by DosFreak
IE11 and Windows 2012
https://www.zdnet.com/article/microsoft-makes … et-explorer-10/
https://msfn.org/board/topic/176344-problems- … comment-1159369
ftp://ftp.fu-berlin.de/pc/security/ms-patches … tfixes-postSP5/
https://nullprogram.com/blog/2018/09/06/
Reply 29 of 256, by DosFreak
Verified, need to add to top post:
7-Zip 9.20 works with roytam1 browsers compressed with 7z
7-Zip
3.51-NT4
7-Zip 9.20
95
7-Zip 9.30
98-ME (Vanilla)
7-Zip 9.30
98-ME (KernelEx)
7-Zip 18.06
Windows 2000+
7-Zip 18.06
VideoLAN
95
v0.8.4b
98-ME (Vanilla)
v0.8.6d
98-ME (KernelEX)
v2.2.8
NT4
v0.8.6i
2000 (Vanilla)
v2.0.1
2000 (BWC)
v3.0.6
XP+
v3.0.6
Reply 30 of 256, by DosFreak
See what it would take to get Links 2.18 to work in 3.51-9x. Windows or DOS ver.
Reply 32 of 256, by DosFreak
Disable SSE in virtualbox
https://www.bountysource.com/issues/12504684- … cpu-without-sse
First of all how to setup testing environment: 1. get virtualbox 4.2 ( 4.3 did not work for me on Windows host) 2. create window […]
2. create windows xp x32 vm.
3. go to virtualbox folder and run
vboxmanage modifyvm vm_name --cpuidset 0x1 0x0001067a 0x00000800 0x00000209 0x018bf3ff
this will disable SSE and SSE2 on guest OS. To revert changes execute
vboxmanage modifyvm <name> --cpuidremoveall
First command will add next lines to vm_name.vbox file to CPUsection
<CpuIdTree>
<CpuIdLeaf id="1" eax="67194" ebx="2048" ecx="521" edx="25949183"/>
</CpuIdTree>
second command will remove changes.
Reply 33 of 256, by DosFreak
Links
http://www.crouchingtigerhiddenfruitbat.org/C … imemachine.html
Need to test in PCEM
MSVCR120.DLL patched to remove CMOV
https://msfn.org/board/topic/177125-my-build- … comment-1148105
FFDShow (v1.3.4533.0 / ffdshow_rev4533_20140929_clsid.exe KernelEx and Windows 98-ME
https://msfn.org/board/topic/152471-kernelex- … comment-1159541
Reply 34 of 256, by DosFreak
Need to go through browser list for vanilla 2000 see the following concerning uxtheme and Opera 12.10:
https://msfn.org/board/topic/177960-new-opera … comment-1159582
VLC 3.0.7 final for XP
Potplayer
Reply 35 of 256, by DosFreak
Guide - Filesharing with Microsoft Operating Systems DOS and above. What's required on client and server.
http://wp.xin.at/archives/4479 TLS v1.3 is approved: How to compile OpenSSL 1.1.1 with TLS v1.3 support and stunnel 5.45b6 for Windows 2000
FFMPEG https://ffmpeg.zeranoe.com/forum/viewtopic.ph … 8e2d203e#p14509
https://rwijnsma.home.xs4all.nl/files/
Reply 36 of 256, by DosFreak
Retrozilla 2.2 which includes roytam TLS 1.2 support from his build
https://github.com/rn10950/RetroZilla/releases/tag/2.2
OpenSSL on XP
https://msfn.org/board/topic/176131-python-35 … comment=1160989
KernelEX Core 19
https://msfn.org/board/topic/173233-kernelex- … comment=1161507
Opera 12.18 files over 12.02 except opera.dll
https://msfn.org/board/topic/178283-how-you-r … n-98me-in-2019/
http://matejhorvat.si/en/unfiled/opera12.htm
The UOC and QUOC Patch - An attempt at optimizing Mozilla based browsers for old machines
FireFox Extensions
https://github.com/JustOff/ca-archive/releases
Reply 37 of 256, by DosFreak
BlackwingCat Extended Kernel v3.0 for English released
http://blog.livedoor.jp/blackwingcat/archives/1980734.html
Extended kernel v3.0 English version is released !
Changing history is the following.
* I migrated DNS /IE 6 / Windows Installer 3.1(v2) customize package installer.
* add exKernel version customize tools.
* add MSPAINT JPEG quality tool.
* add sound recorder fixed time bug.
* add MSPAINT which supported JPEG variable qualitiy and FSUTIL, CMD, MSCONFIG, RUNDLL32, REGEDIT, as same as Windows XP version.
* add explorer.exe which supported colorful icon and avoid out of memory version.
* add MAPI2.
* add Microsoft Codec.
* add VC++2005 Runtime.
* add MS12-004 and MS17-010 , which are Emergency of critical updates.
* add IE6 KILLBITS
* replaced XP SP2 Device Manager.
setupapi.dll
* SetupVerifyInfFileA/W stubed
apphelp.dll
* add SDB about 60 functions
Reply 38 of 256, by lightmaster
DosFreak wrote:
IE11 and Windows 2012 https://www.zdnet.com/article/microsoft-makes … et-explorer-10/ […]
THank you for this!!
Reply 39 of 256, by JiaoTongNan
The 1070-9071_modified.zip build did not launch on Windows ME but the Opera_1070_3488_modified.zip launched on Windows ME and 10.
I don't have access to a 95 machine atm.
Personal Blog
