Reply 100 of 758, by BdR
Actually, there is no original B/W line version. I converted the treefrog photo to a 160*200*16 colors bitmap, so that is my 'original' file. The B/W line dithered version is then generated by my BMPDITH gwbasic program, using the 16 color .BMP as input.
So, you can generate the B/W line version by running BMPDITH.BAS (see BMPDITH2.ZIP already posted here) in DOSbox, load the treefrog image and press CTRL-F5 to save a .PNG screenshot of the B/W line version. It will save a 640*400 image, so you have to pixel-resize it to 640*200. Hope that helps.
Reply 104 of 758, by nikiniki
ripsaw8080 wrote:
FYI, you can easily toggle composite color with BASIC code: […]
SCREEN 2: REM cga mode 6 (640x200x2)
OUT &H3D8,&H1A: REM enable color burst
OUT &H3D8,&H1E: REM disable color burst
Can be possible to do with screen 1 unstead screen 2?
Reply 105 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It is possible to enable color burst for SCREEN 1 (mode 4, 320x200x4) with machine=cga, but DOSBox doesn't generate a composite palette for it automatically like it does for mode 6, so another port write is needed:
SCREEN 1: REM cga mode 4 (320x200x4)
OUT &H3D9,&H3F: REM generate composite palette
However, the colors are not correct for mode 4, because the current composite palette algorithm doesn't support it.
Reply 107 of 758, by Paul_Holmlund
@BdR
That "COMPOSITE COLOR TEST" image is my current desktop image.
It's so * sniff.. * beautiful.. I look at it every day! * big silly grin *
I didn't realize that you could make the gradients, along the bottom, since the grey repeats. That is just epic. I look at it every day and get wilder and wilder ideas.
I promise to very soon, package up my *.GIF to *.CGA converter program, and the viewer, and a few example video files, and post on youtube the thing in action, so you guys can see what I did there.
~Kiyote!
Your GW-Basic program works quite well! I like it alot!
Reply 108 of 758, by Jorpho
...Would anyone like me to edit the thread title, considering this hasn't had the slightest thing to do with Fooblitzky in a very long time? 😉 (Please suggest something appropriate.)
Reply 111 of 758, by Paul_Holmlund
I asked, way back when, to put [SOLVED] on it.
"Would anyone like me to edit the thread title, considering this hasn't had the slightest thing to do with Fooblitzky"
I didn't post a new thread, because I doubted anyone would make anything out of it. I'm not exactly the most likable person on this forum. I've seen my account go "INVALID ACCOUNT" on me, behind my back. I guess either I did a big no-no, or someone remembers me, and just thinks I'm a little twerp.
~Paul Holmlund aka Kiyotewolf
Reply 112 of 758, by Paul_Holmlund
Not to mention the fact, that the moderators seem to comment, right AFTER I post too.
If you guys have an issue with me personally, don't hide it, flat out tell me.
I'll just walk away if I must, but I really like this thread, so I'd prefer to be allowed to stay.
~PRH KW
Reply 113 of 758, by wd
Rank DOSBox Author
DOSBox Author
If you derive this from nobody bothering to add a SOLVED tag to this thread
(because nobody cares anyways) or because for possibly technical reasons/flaws
your old account was invalidated, i can assure you everybody still loves you
and at least 50% of the female board visitors want children from you.
Apart from that, everybody nice again, yes?
Reply 114 of 758, by BdR
After my quick .GL animation test, I couldn't resist making a better video example. So I've created three 640*200 2 color animations that can make use of the CGA colorburst mode (including a nsfw one 🤣). The GLVIEW.EXE player cannot switch to composite mode, so you do need the COMPCGA3.EXE tool.
Each animation is an endless loop and has around 15 frames, because I assume GRASP can't handle >1MB files (I didn't test it). Besides, it was actually a lot more work than I expected converting the frames one by one, so making a .GL animation is not the preferred way.
Although it was pretty much an exercise in futility, the result looks kind of cool. It has a nice retro feel to it. 😎 It would probably be possible to create some sort of streaming video demo using CGA composite, similar to the "8088 Corruption" demo by Trixter. Though 160x200x16 color CGA mode would need a bit more data per frame, compared to 80x25 text mode.
    17.2 KiB
    frame from the HUMBIRD.GL animation
    glcga.zip
    434.14 KiB
    293 downloads
    three 640*200 2 color animations in GRASP format, especially prepared for CGA colorburst mode
Reply 115 of 758, by BdR
*kicks thread*
Someone took a Doom gameplay video in normal VGA mode and ran the video through some post-production video filter to simulate CGA modes. So this is not the CGA Doom patch, it's just made to look as if it is running on CGA.
http://www.youtube.com/watch?v=9YoqUM1ZLQ0
The "CGA composite" filter starts at 4:55, pretty nerdy but kinda cool too
Reply 116 of 758, by kiyotewolfe
http://jafile.com/uploads/kiyotewolf/cgaview2.zip
This is my *.CGA format file viewer, and 3 example videos converted to *.CGA video.
~Kiyotewolf
-Paul Holmlund
[edit]
I will package up the converter I wrote to make the *.cga files, in a day or so, with instructions.
I use short clips, from any video source, then convert to an animated gif which has a resolution less than 320x200, in SUPER VIDEO CONVERTER, then use a modified animated gif viewer to do the converting.
Reply 117 of 758, by kiyotewolfe
More screenshots
    26.75 KiB
    Title Screen of Jungle Hunt
    59.6 KiB
    Dragons Lair
    38.92 KiB
    Gauntlet
    35.35 KiB
    Gauntlet 2more
Reply 118 of 758, by kiyotewolfe
Here is the converter, as well as a sample input file, sample output file.
http://jafile.com/uploads/kiyotewolf/zoidberg.zip
This is the link to SUPER VIDEO CONVERTER which I made the animated GIF from.
http://www.erightsoft.com/SUPER.html
I recommend 240x192 resolution, 23.976 fps.
~Kiyote Wolf
Reply 119 of 758, by kiyotewolfe
Anyone interested in the source codes of both the player & the transcoder?
They require QuickBasic to be compiled into *.EXE files.
~Kiyote!
o3o Anyone like what they have to play with now?
