Reply 640 of 760, by VileR
- l33t
wrote:On a real IBM PC with an IBM CGA card even I had trouble with Jungle Hunt getting the white status bar text all the time. It would usually cycle its location on the screen each time you died.
Well, that's what DOSBox does as well now; better than not at all. ;)
By the way, your IBM CGA is 'new-style' as well, isn't it? I wonder if you can corroborate my impression above, about the saturation/contrast/brightness adjustments. It holds true for what we've seen from Servo's card, plus Trixter and Scali (who own newstyle CGA cards that we've been testing for a final version of the demo).
Specifically, it seems that the following adjustments bring it much closer to a real new-style CGA's output:
* +30 saturation offset
* +50 contrast offset
* -30 brightness offset
(or thereabouts!)
