Reply 40 of 43, by Gwenhwyfar
It runs now 😀 But now I have no water at all, even not there, where it should be
EDIT: I was wrong... There isn't no water at all, its just at the very bottom end of the screen.
I see. In addition to that patch, this game is also timing sensitive. Try starting it with different cycle counts. For me, it works well with 6000 cycles.
I tried 6000, was a little to much. For me it runs perfectly with 5600! 😁
I can't believe that I can run this game. Thank you all so much, I would never have done this without you... I think I will play kelloggs for the whole day now! ^^
Game doesn't accept input at the main menu in 0.65 and 0.70. Works in 0.63.
The "Start-Button" should blink continually but only does once.
Tried the dyn/normal/full and loadfix.
1+1=10
