First post, by qalnor
I remember this game fondly from ages ago, but when I reinstalled it today using DOSBox, I found that the only monsters I ever encounter are rats, and my characters are generally incapable of hitting anything, and them onsters are similarly incapable of hitting me.
It seems like every few battles will be normal, in the sense that my party is capable of hitting them and vica versa, but generally this is not the case.
Has anyone had similar problems with this game, or any other games, and found a resolution?
I believe this is an issue with DOSBox and not the game itself, so I'm posting here, but I'm not 100% sure.
Reply 1 of 6, by DosFreak
Does Wiz 6 work in NTVDM in XP? If youi encounter the same behavior then it's not a DosBox problem.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 6, by qalnor
I'm starting to think this may have something to do with directory references. When I set my savegame directory to C:\BANE\SAVE\ earlier, it wouldn't accept it. So I tried just putting 'SAVE' in, and that seemed to work.
However, there's also another directory setting which can't be modified by any means I'm aware of that points to the scenario datafile, and I'm wondering if maybe that link is the problem.
Reply 4 of 6, by eL_PuSHeR
Rank Moderator
Moderator
I remember the same thing happened to Wizardry 7 when you used a BAD CRACK. 😵
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
