DOSBox Game Launcher (DOSBox Frontend)
Reply 100 of 1968, by MiniMax
Rank Moderator
Moderator
MiniMax wrote:
Let me give it a shot... I will download your frontend, and start experimenting.
Here Ronald, a replacement for dbgl.bat.
    dbgl.cmd.zip
    552 Bytes
    253 downloads
    A replacement for dbgl.bat for DBGL 0.50.
_________________
Reply 102 of 1968, by MiniMax
Rank Moderator
Moderator
MaReaDo,
Can you start a command prompt, then cd to where you have installed DBGL, and try this command:
java -Djava.library.path=lib -jar dbgl.jar
Does it show any errors?
_________________
Reply 103 of 1968, by MaReaDo^
i cant do that
command "java" doesn't work
first i had JRE 1.5 Update 8, then i unistalled this, and installed JRE 1.5 Update 9
same error =(
the last week java was working fine, now there are error =(
sorry for my bad english
Reply 104 of 1968, by MiniMax
Rank Moderator
Moderator
MaReaDo, can you start a CMD-prompt and do the
PATH
command and then
cd /d "%SystemRoot%\system32
dir java*
and post the results here?
_________________
Reply 105 of 1968, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
exe launchers for dbgl - put them where the dbgl.jar is.
    exe-launcher.zip
    294.76 KiB
    297 downloads
Reply 106 of 1968, by MaReaDo^
12/10/2006 01:35 a.m. 49.248 java.exe
28/02/2003 06:26 p.m. 187.152 javacypt.dll
28/02/2003 06:26 p.m. 139.536 javaee.dll
12/06/1998 12:00 a.m. 230.861 JAVALE.DLL
02/06/1998 11:46 a.m. 11.403 javaperm.hlp
28/02/2003 06:26 p.m. 63.248 javaprxy.dll
28/02/2003 06:26 p.m. 404.752 javart.dll
02/06/1998 11:46 a.m. 21.444 javasec.hlp
28/02/2003 04:54 p.m. 7.315 javasup.vxd
12/10/2006 01:35 a.m. 53.346 javaw.exe
12/10/2006 03:10 a.m. 127.078 javaws.exe
Reply 107 of 1968, by MiniMax
Rank Moderator
Moderator
MaReaDo - and what happens if you start a CMD-prompt, cd to the the DBGL directory, and then do a
C:> dir dbgl.jar
C:> "%SystemRoot%\system32\java" -Djava.library.path=lib -jar dbgl.jar
_________________
Reply 109 of 1968, by MiniMax
Rank Moderator
Moderator
MaReaDo^ wrote:
dbgl works when i do this
Something is wrong with your PATH then.
Please download the attached WhereIs program, and put it in the same directory as where you have installed DBGL.
Then start a command prompt, cd to where you have installed DBGL, and try this command:
whereis java
Please post the result here.
    whereis.exe
    52 KiB
    274 downloads
    Utility to figure out where Windows will load stuff from.
    By Joseph M. Newcomer.
    URL: http://www.flounder.com/whereis.htm
_________________
Reply 110 of 1968, by MiniMax
Rank Moderator
Moderator
Eh.. Why?
_________________
Reply 112 of 1968, by rcblanke
@MiniMax: Thanks for the help and suggestions. I'll update the startup batchfile for the next release to something like yours. You are also very right about database exception handling, it needs some work in order to forward the error messages towards the GUI.
@MaReaDo: For Windows, you can set your path as follows.
Press Start - Control Panel - System - Advanced tab - Environment Variables - in system variables list select path and press edit. Make sure it contains the string (assuming you installed the JRE to the default location):
C:\Program Files\Java\jre1.5.0_09\bin;
MaReaDo^ wrote:
another problem, there aren't my profiles, templates, etc
Ok, now this sounds rather scary. Can you tell me exactly what you did to update your DBGL installation?
Regards,
Ronald
Reply 113 of 1968, by MaReaDo^
in PATH there aren't java string, so i added this and now dbgl works
thanks everybody
i download de new version of dbgl and copy/past in old dbgl directory, the profiles, templates, etc files still here, but in the program don't
sorry for my bad englishj =(
Reply 114 of 1968, by MiniMax
Rank Moderator
Moderator
That is IMO a bad workaround. After the next Java update it will not work. Besides, MaReaDo has a Java in his path, in \WINDOWS\system32:
12/10/2006 01:35 a.m. 49.248 java.exe 28/02/2003 06:26 p.m. 187.152 javacypt.dll 28/02/2003 06:26 p.m. 139.536 javaee.dll 12/06/ […]
And those are fairly recent, consistent with his install of JRE 1.5.
_________________
Reply 116 of 1968, by rcblanke
I'm not sure that I fully understand what you're saying. What I believe is wrong is that the database.script file in your database subdirectory is the included default (=empty) one. I hope that you made a backup of this file prior to updating so you can restore it.
