DOSBox Game Launcher (DOSBox Frontend)
Reply 1100 of 1968, by kolano
OK, some quick feedback on the config sharing...
  • When sharing a config the config changes shown besides the Explanation box is non-scrollable even though it provides scrollbars.
  • It's difficult to share only relevant config changes if your config has many changes. Need to provide a way to edit the config (though that will likely make config reviews harder) or select relevant configs to share.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 1101 of 1968, by thegeneralpanda
Could someone explain how I can make DBGL detect that the version I'm using is indeed experimental? I'm using SVN Daum but the only options I can find are to say it's 0.74.
Reply 1103 of 1968, by thegeneralpanda
All I see in the general section is: DosBox, Sent To (Requires restart), Profile defaults and Internationalization (requires restart).
I apologize if I'm blatently missing the point.
    528.23 KiB
    No downloads
Reply 1104 of 1968, by code120
@thegeneralpanda: first you need to add SVN Daum in the 'DosBox versions' tab of the main window (next to the 'Profiles' tab). Then in the general tab of the profile editing window of the game (not the general preferences) you have to choose the appropriate version of DosBox you want to use.
A small suggestion: there is the 'tiles' and 'boxes' table view, but using the boxes the images are stretched and deformed. Downloading screenshots from Mobygames, it's possible to download the box art too, but DBGL always chooses the first pic. DBGL could use a regular screenshot for the tile or table view, and the box art for the boxes view, if it could detect the size of the images and choose one whose height is higher than its width (that would be the box art).
Reply 1105 of 1968, by Sheriff Hobbes
Hello,
I'm running DBGL (latest version) on Windows XP and Debian 7 without any problems. Now I want to make it run on an older Notebook with Debian 5. Trying to do this with the system provided free Java version I get this just after launching the dbgl Script:
Launching DBGL using null-Bit VM 1.5.0 on Linux v2.6.26-2-686i386, HSQL Database Engine 1.8.1.3java.lang.NullPointerException
at org.dbgl.gui.Launcher.loadSWT(Unknown Source)
at org.dbgl.gui.Launcher.main(Unknown Source)
Exception in thread "main" java.lang.NoClassDefFoundError: org.eclipse.swt.SWT
Trying to do this with the Sun version of Java (1.5 or 1.6) I can launch the GUI, but when I try to run DOSbox, I get this:
Launching DBGL using 32-Bit VM 1.5.0_22 on Linux v2.6.26-2-686i386, HSQL Database Engine 1.8.1.3, SWT v4332gtk
Startup
/home/user/DBGL/DOSBox-0.74/dosbox -conf /home/user/DBGL/DOSBox-0.74/dosbox.conf
DOSBox stderr> /home/user/DBGL/DOSBox-0.74/dosbox: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/user/DBGL/DOSBox-0.74/dosbox)
Any ideas?
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1106 of 1968, by rcblanke
Hi Sheriff,
The DOSBox binary that comes pre-packaged with DBGL was built on an Ubuntu Linux distribution and may thus not work on other distributions. It's probably best to grab the 'generic' DBGL package, and use Debian's own package manager to install the latest DOSBox version for that platform. DBGL should autodetect DOSBox' installation location at first startup, automatically (though I didn't actually test this with Debian, myself).
Reply 1107 of 1968, by Sheriff Hobbes
Hi rcblanke,
you're right, it doesn't work because the DBGL DOSBox was compiled on a different system. Debian 5 comes with DOSBox 0.72. DBGL doesn't find it automatically, but if you tell it the path /usr/bin and the dosbox.conf from the 0.74 version, then it runs fine.
Anybody knows if there's a Debian 5 backport available for DOSBox 0.74?
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1108 of 1968, by Sheriff Hobbes
To answer myself: There's no need for a backport. I could install version 0.74 from the sources. 😎
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1109 of 1968, by pellewolf
Hello!
Need your Advice - DBGL drives me crazy for hours now, how can i activate General Midi??? Want to play some of those Lucas Games like Day of the Tentacle. If i load a soundfont
via BASSMIDI, where and what do I have to put exactly in DBGL? Would be nice if you can show me step by step, i am a noob 😀 ! thx
p.s.: i use windows + dosbox daum with DBGL
Reply 1110 of 1968, by kolano
pellewolf wrote:
Hello! […]
Hello!
1. Drop the soundfont into the dosroot folder
2. Edit your profile, under Audio\Official options\General...
- Set "Midi Device" as "synth"
- Set "Config" with the file name of the soundfont
3. Run the games setup and set them to use General Midi
Reply 1111 of 1968, by pellewolf
hi kolano!
that's exactly what i tried in thousands variations the last days.
1. i copied the soundfont '8mbgm_enhanced18.sf2' into dosroot-folder of dbgl (with scummvm (fluidsynth) this font works perfect)
2. i changed to synth in dbgl-game-profile-audio-settings and wrote in the config-field 8mbgm_enhanced18.sf2
3. when i start the setup of the games, for example indy 4 or tentacle or sam'n'max and choose general midi and than
choose "test sound" i hear...nothing. adlib works and plays the test sample. soundblaster works. only general midi - nothing to hear.
even if i let midi in the settings and start the game in spite of this it switches back to adlib.
4. i tried different soundfonts and different versions of the games so the problem can not be the games or
soundfont itself 🙁
i added an image of the sound settings from dbgl but it's like you said...
    110.26 KiB
Reply 1112 of 1968, by rcblanke
Hi all,
I've just uploaded test build 0.78f with the following changes:
* Make config settings to be shared selectable in tree structure (as suggested by kolano)
* Also added 'consult dbconfws' to wizard
* Fixed initial sort by title when browsing configurations
* For the moment use gtk2 instead of gtk3 on Linux systems to prevent gui issues
* Enlarged the about dialog a bit and made it resizable
* Some code refactoring for Java7 ('Multiple Exception Types', 'try-with-resources')
* Some Spanish translation updates from Neville
Unless any serious issues pop up, this is likely to be the last test-build prior to a new release.
All the latest files
To upgrade, grab the dbgl.jar as usual.
Regards,
Ronald
Reply 1113 of 1968, by Neville
OK, this is driving me nuts, so I'd better share...
I have a DOSROOT\<Game Name> folder.
Inside the folder, a Win95.img harddrive image and a <Game Name> ISO file.
How do I mount these images so I boot from Win95.img (as C:) while <Game Name> ISO being accesible under Windows 95.
Reply 1115 of 1968, by Neville
The profile uses Yhkwong's build. It's a Win95 game that runs from the IMG file but needs the ISO image as well.
The guy who sent it to me just emailed me back. Says the game needs these instructions in the AUTOEXEC section:
imgmount D "FolderName\CD\Game.iso" -t cdrom -ide 2m
imgmount C "FolderName\w95.img" -t hdd -fs fat
boot -l c
But also warns me that DBGL cannot export the profile properly.
Can you do anything about it?
Reply 1116 of 1968, by rcblanke
Yeah, the '-ide 2m' is not supported. Try imgmounting the w95.img, and put 'imgmount D "FolderName\CD\Game.iso" -t cdrom -ide 2m' into the custom commands tab, 'before launch' section. In the mounting tab, select Booter mode, grab the imgmounted W95.img and select the 'C'-drive as the Drive Letter.
Reply 1119 of 1968, by Neville
This is the working dosbox.conf:
[sdl] fullscreen=false fulldouble=false fullresolution=original windowresolution=original output= autolock=true sensitivity=100 […]
[sdl]
fullscreen=false
fulldouble=false
output=
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-SVN-Daum.map
pixelshader=none
usescancodes=true
overscan=0
[log]
logfile=
vga=true
vgagfx=true
vgamisc=true
int10=true
sblaster=true
dma_control=true
fpu=true
cpu=true
paging=true
fcb=true
files=true
ioctl=true
exec=true
dosmisc=true
pit=true
keyboard=true
pic=true
mouse=true
bios=true
gui=true
misc=true
io=true
pci=true
sst=true
[dosbox]
language=
machine=svga_s3
vmemsize=4
vmemsizekb=0
captures=..\captures\12
mainline compatible mapping=true
mainline compatible bios mapping=true
adapter rom is ram=false
shell environment size=0
private area size=32768
a20=fast
isa bus clock=std8.3
pci bus clock=std33.3
rom bios allocation max=0
rom bios minimum size=0
memsize=63
memsizekb=0
memalias=0
vga bios size override=0
video bios dont duplicate cga first half rom font=false
video bios always offer 14-pixel high rom font=true
video bios always offer 16-pixel high rom font=true
video bios enable cga second half rom font=true
forcerate=
sierra ramdac=true
sierra ramdac lock 565=false
page flip debug line=false
vertical retrace poll debug line=false
cgasnow=true
allow port 92 reset=true
enable port 92=true
enable 1st dma controller=true
enable 2nd dma controller=true
allow dma address decrement=true
enable dma extra page registers=true
dma page registers write-only=false
enable slave pic=true
enable pc nmi mask=true
rom bios 8x8 cga font=true
rom bios video parameter table=true
allow more than 640kb base memory=false
vesa lfb base scanline adjust=0
allow hpel effects=false
allow hretrace effects=false
hretrace effect weight=4.00
vesa vbe 1.2 modes are 32bpp=true
allow 32bpp vesa modes=true
allow 24bpp vesa modes=true
allow 16bpp vesa modes=true
allow 15bpp vesa modes=true
allow 8bpp vesa modes=true
allow 4bpp vesa modes=true
allow tty vesa modes=true
enable vga resize delay=false
enable pci bus=true
pit hack=
[render]
frameskip=0
aspect=false
linewise=false
char9=false
doublescan=true
scaler=hardware3x
autofit=true
[vsync]
vsyncmode=off
vsyncrate=75
[cpu]
core=auto
enable msr=true
ignore undefined msr=false
dynamic core cache block size=32
cputype=pentium_mmx
cycles=auto
cycleup=10
cycledown=20
non-recursive page fault=false
ignore opcode 63=true
apmbios=false
apmbios allow realmode=true
apmbios allow 16-bit protected mode=true
apmbios allow 32-bit protected mode=true
integration device=false
isapnpbios=false
realbig16=false
[keyboard]
aux=false
allow output port reset=true
auxdevice=intellimouse
[pci]
voodoo=auto
voodoomem=standard
[mixer]
nosound=false
swapstereo=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
mt32.reverse.stereo=off
mt32.verbose=off
mt32.thread=off
mt32.dac=auto
mt32.reverb.mode=auto
mt32.reverb.time=5
mt32.reverb.level=3
mt32.partials=32
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
adlib force timer overflow on detect=true
oplemu=default
oplrate=44100
hardwarebase=220
force dsp auto-init=false
force goldplay=false
goldplay=false
goldplay stereo=true
dsp require interrupt acknowledge=auto
dsp write busy delay=-1
blaster environment variable=true
sample rate limits=true
instant direct dac=false
stereo control with sbpro only=true
dsp busy cycle rate=-1
dsp busy cycle duty=-1
io port aliasing=true
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[innova]
innova=false
samplerate=22050
sidbase=280
quality=0
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=false
ps1audio=off
ps1audiorate=22050
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[printer]
printer=true
dpi=360
width=85
height=110
printoutput=png
multipage=false
docpath=.
timeout=0
[parallel]
parallel1=disabled
parallel2=disabled
parallel3=disabled
dongle=false
[glide]
glide=true
lfb=full
splash=true
[dos]
xms=true
ems=true
ems system handle memory size=384
umb=true
umb start=0
umb end=0
kernel allocation in umb=false
dynamic kernel allocation=false
keep umb on boot=false
keep private area on boot=false
private area in umb=true
automount=true
int33=true
int 13 extensions=true
biosps2=true
int15 mouse callback does not preserve registers=false
keyboardlayout=auto
dbcs=true
filenamechar=true
collating and uppercase=true
files=127
[ipx]
ipx=false
[ne2000]
ne2000=true
nicbase=300
nicirq=3
macaddr=AC:DE:48:88:99:AA
realnic=list
[fdc, primary]
enable=false
pnp=true
irq=0
io=0
dma=-1
int13fakev86io=false
instant mode=false
auto-attach to int 13h=true
mode=ps2
chip=82077aa
[fdc, secondary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, tertiary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quaternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quinternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, sexternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, septernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, octernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[ide, primary]
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
cd-rom spinup time=0
cd-rom spindown timeout=0
cd-rom insertion delay=0
[ide, secondary]
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, tertiary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quaternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quinternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, sexternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, septernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, octernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[autoexec]
imgmount D "RollerCoaster Tycoon (Castellano)\RCTYCOON.iso" -t cdrom -ide 2m
imgmount C "RollerCoaster Tycoon (Castellano)\w95.img" -t hdd -fs fat
boot -l c
Handmade changes are in bold type.
EDIT: And this is the CONF file after I made the changes you suggested:
[sdl]
fullscreen=false
fulldouble=false
output=
autolock=true
sensitivity=100
waitonerror=true
pixelshader=none
usescancodes=true
overscan=0
[log]
logfile=
vga=true
vgagfx=true
vgamisc=true
int10=true
sblaster=true
dma_control=true
fpu=true
cpu=true
paging=true
fcb=true
files=true
ioctl=true
exec=true
dosmisc=true
pit=true
keyboard=true
pic=true
mouse=true
bios=true
gui=true
misc=true
io=true
pci=true
sst=true
[dosbox]
language=
machine=svga_s3
vmemsize=4
vmemsizekb=0
a20=fast
memsize=63
memsizekb=0
memalias=0
forcerate=
sierra ramdac=true
cgasnow=true
enable port 92=true
enable pci bus=true
pit hack=
[render]
frameskip=0
aspect=false
linewise=false
char9=false
doublescan=true
scaler=hardware3x
autofit=true
[vsync]
vsyncmode=off
vsyncrate=75
[cpu]
core=auto
enable msr=true
cputype=pentium_mmx
cycles=auto
cycleup=10
cycledown=20
apmbios=false
isapnpbios=false
realbig16=false
[keyboard]
aux=false
[pci]
voodoo=auto
voodoomem=standard
[mixer]
nosound=false
swapstereo=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
mt32.verbose=off
mt32.thread=off
mt32.dac=auto
mt32.reverb.time=5
mt32.reverb.level=3
mt32.partials=32
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
hardwarebase=220
goldplay=false
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[innova]
innova=false
samplerate=22050
sidbase=280
quality=0
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=false
ps1audio=off
ps1audiorate=22050
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[printer]
printer=true
dpi=360
width=85
height=110
printoutput=png
multipage=false
docpath=.
timeout=0
[parallel]
parallel1=disabled
parallel2=disabled
parallel3=disabled
dongle=false
[glide]
glide=true
lfb=full
splash=true
[dos]
xms=true
ems=true
umb=true
umb start=0
umb end=0
automount=true
int33=true
biosps2=true
keyboardlayout=auto
dbcs=true
filenamechar=true
files=127
[ipx]
ipx=false
[ne2000]
ne2000=true
nicbase=300
nicirq=3
realnic=list
[fdc, primary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, secondary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, tertiary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quaternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quinternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, sexternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, septernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, octernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[ide, primary]
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, secondary]
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, tertiary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quaternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quinternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, sexternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, septernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, octernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[autoexec]
mount A "RollerCoaster Tycoon (Castellano)"
@REM PRE-LAUNCH
@REM /PRE-LAUNCH
boot A:\W95.img -l C
It fails to boot off Windows 95.
