DOSBox Game Launcher (DOSBox Frontend)
Reply 1661 of 1968, by rcblanke
Yes, you can simply select multiple .ima files in the 'mount' dialog to imgmount them. Use ctrl-F4 to change the active image. Keep in mind, though, that multiple floppy imgmount only works in recent DOSBox SVN builds (or ECE, DOSBox-X, DOSBox Staging) as this feature is not available in 0.74.
Reply 1666 of 1968, by rcblanke
gbbbs, not sure I understand your problem. Can you explain _exactly_ when DBGL is crashing, maybe with a screenshot? Or better yet, start DBGL with dbglcons.cmd and share the output of the stacktrace after the crash.
Reply 1667 of 1968, by gbbbs
no problem, here :
D:\_Games\Retro\DOS\DOSBox Game Launcher v.093beta10>java -Djava.library.path=lib -jar dbgl.jar || pause
Launching DBGL using 64-Bit VM 1.8.0_281 on Windows 10 v10.0amd64, HSQL Database Engine 2.6.0, SWT v4942win32
Starten
Akzeptiere Daten am Port 4.740
Exception in thread "main" java.lang.NoSuchMethodError: java.nio.ByteBuffer.clear()Ljava/nio/ByteBuffer;
at org.dbgl.util.fat.BootSector.read(BootSector.java:90)
at org.dbgl.util.fat.FatFileSystem.<init>(FatFileSystem.java:42)
at org.dbgl.util.FilesUtils.listExecutablesInZipOrIsoOrFat(FilesUtils.java:266)
at org.dbgl.gui.dialog.BrowseArchiveDialog.prepare(BrowseArchiveDialog.java:53)
at org.dbgl.gui.abstractdialog.BaseDialog.open(BaseDialog.java:97)
at org.dbgl.gui.controls.Button_.getResult(Button_.java:323)
at org.dbgl.gui.controls.Button_.access$1100(Button_.java:40)
at org.dbgl.gui.controls.Button_$1.widgetSelected(Button_.java:181)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1043)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4026)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3626)
at org.dbgl.gui.abstractdialog.BaseDialog.open(BaseDialog.java:113)
at org.dbgl.gui.dialog.MainWindow.doAddProfile(MainWindow.java:1525)
at org.dbgl.gui.dialog.MainWindow.access$6100(MainWindow.java:134)
at org.dbgl.gui.dialog.MainWindow$69.widgetSelected(MainWindow.java:1987)
at org.dbgl.gui.Launcher.main(Launcher.java:52)
Drücken Sie eine beliebige Taste . . .
Reply 1668 of 1968, by rcblanke
Thanks for the information gbbbs, can you please try again with this new beta build?
In other news: DBGL is moving to https://dbgl.org. The old location will remain available for the coming time. Existing DBGL users may want to edit their settings.conf and change the line
endpoint=http://www.squadrablu.nl:8080/DBConfWS/apiv1/
to
endpoint=https://share.dbgl.org/DBConfWS/apiv1/
All the latest files. To upgrade, just update dbgl.jar.
Ronald
Reply 1672 of 1968, by gbbbs
with the newest DBGL i got the ssme problem with the diskimage :
D:\_Games\Retro\DOS\DOSBox Game Launcher v.093>java -Djava.library.path=lib -jar dbgl.jar || pause
Starten
Exception in thread "main" java.lang.NoSuchMethodError: java.nio.ByteBuffer.limit(I)Ljava/nio/ByteBuffer;
at org.dbgl.util.fat.ClusterChain.readData(ClusterChain.java:131)
at org.dbgl.util.fat.ClusterChainDirectory.read(ClusterChainDirectory.java:52)
at org.dbgl.util.fat.AbstractDirectory.read(AbstractDirectory.java:83)
at org.dbgl.util.fat.FatLfnDirectory.read(FatLfnDirectory.java:158)
at org.dbgl.util.fat.FatLfnDirectory.getDirectory(FatLfnDirectory.java:70)
at org.dbgl.util.fat.FatLfnDirectoryEntry.getDirectory(FatLfnDirectoryEntry.java:75)
at org.dbgl.util.FilesUtils.listFatExecutables(FilesUtils.java:282)
Reply 1674 of 1968, by rcblanke
gbbbs wrote on 2021-05-03, 19:16:
any idea?
Yep, thanks for the heads up. It should be fixed in this new beta build, and I've implemented a rudimentary 'dark mode' for Windows users. Quite a lot of GUI code changes had to be made, so if you spot anything out of the ordinary please let me know. You can enable the dark theme via File->Preferences->Gui Options->Theme
118.48 KiB
Dark Mode
Ronald
